04-10-2017, 04:44 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2675445 Status: Offline Thanks Meter: 0 | Octopus me dice "card not found" Me está pasando esto con la Octopus. Seguramente alguno podrá ayudarme con este inconveniente. Al conectarla y querer inicial el programa de samsung o lg me dice "card not found". Lo llamativo es que hasta unas horas estaba andando bien. Si pudieran responder en español sería mejor. Gracias! Hello people! This is happening to me with Octopus. Surely some can help me with this inconvenience. When I connect and want to start the program samsung or lg says "card not found". What is striking is that even a few hours was walking well. If they could respond in Spanish it would be better. Thank you! Last edited by -NicEch-; 04-10-2017 at 04:47. Reason: mejorar el post |
04-10-2017, 04:58 | #2 (permalink) |
No Life Poster Join Date: Sep 2014 Age: 46
Member: 2260435 Status: Offline Thanks Meter: 118 | ve a Administrador de dispositivos en tu PC y verifica si aparece la smartcard, en ese caso tendrías que desarmar la caja y limpiar el lector de smartcard (cuidado con dañar la misma). si luego de limpiar no funciona ponla en otra caja y prueba |
The Following User Says Thank You to myciviczc For This Useful Post: |
04-10-2017, 08:11 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please isntall the following card driver, restart PC, then check whether You can start the Software. card |
