Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-01-2011, 08:10   #31 (permalink)
kerug-bali's Avatar
Member: 762348
Sonork: 100.1617133
Thanks Meter: 231
Originally Posted by Vansy View Post
after unlocked "Invalid Card in this region "
br.
same like me...repair nvm not work..like pic
try store the number in your SIM and named it My Number...number should be in international format like +63917....just try and post reply.
international format im indonesia auto +62 not wok
for gsm server how to fox this problem
thanks
Old 08-01-2011, 16:43   #32 (permalink)
kerug-bali's Avatar
Member: 762348
Sonork: 100.1617133
Thanks Meter: 231
thanks
succes unlocked by octopus..heheheh
http://forum.gsmhosting.com/vbb/f684...ml#post7584893
Old 01-11-2012, 05:10   #33 (permalink)
Member: 212634
Hi Team Octopus. I have Anycall SWH-A200s, need unlock network. However, this model not support in Octopus box Samsung software version 1.2.0, plz hepl me.
Old 01-11-2012, 07:38   #34 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 24,109
Hello.
To add this phone we need to have it in our hands for researching. Can You sell us this phone or send us for researching?
The Following User Says Thank You to Octopus box For This Useful Post:
Old 08-21-2012, 14:45   #35 (permalink)
Member: 1797487
Sonork: 036209898
Thanks Meter: 2
hii octopus. can i put flash files of i9300 on samsung i747m? its the same phone no?
Old 08-22-2012, 16:48   #36 (permalink)
Member: 1146942
Sonork: 100.1587278
Hello.
No, these phones have some differences.
Old 06-01-2013, 17:39   #37 (permalink)
Member: 1830446
Sonork: thedigital
Thanks Meter: 2
Please tell me how to read security code on samsung phones> for example if i want to unlock or read user code. The octoplus box will say go to settings or enter some digit number, my point is that their no way to go in or type any thing, allows noting only the security code, because it lock. Thanks
Old 06-03-2013, 06:44   #38 (permalink)
Member: 1146942
Sonork: 100.1587278
This depends on phone model. Read user (phone) code option is not supported for all phones. What phone do You have exactly?
Old 07-12-2013, 15:07   #39 (permalink)
Member: 1865763
need help how to get into Normal instead of emergency mode tried alot of times but nothing....
thanks
Welcome to Octoplus/Octopus Box Samsung software version 1.1.9
To connect GT-S7560M phone you have to perform the following
steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#9090#" number.
7. Set "Diag config" to "USB" value.
8. Restart phone.
9. Press "Read Info" in software.
Platform: Samsung Anycall
Selected port: COM1
Selected model: GT-S7560M
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM15
Mode: Emergency
Selected port: COM15
Mode: Emergency
Unlock for GT-S7560M phone in emergency mode canít be done
Port is busy
No diagnostic ports found!
Connecting to phone on COM4
Phone connection failed
Selected port: COM4
Old 07-12-2013, 15:58   #40 (permalink)
Member: 1146942
Sonork: 100.1587278
Please install all neccessary drivers and carefully perform all of these steps:
steps:
8. Restart phone.
Old 07-13-2013, 09:52   #41 (permalink)
Member: 1865763
steps:
8. Restart phone.
thank you for reply,did all,tried with new computer,latest drivers,latest octo version,the same,had that kind of problem also with samsung i5800,the same, solved that with other box,also could not unlock e2600 regardless octoplus informed phone unlocked,it was not....am I doing something wrong?...I put the debugging on,rooted the s7560m,diag config to usb setting and I allways get the emergency so cannot unlock?
Old 07-15-2013, 06:37   #42 (permalink)
Member: 1146942
Sonork: 100.1587278
Please contact us to Sonork or to Yahoo! Messenger, we will try to help You remotely via team Viewer. Our contacts You can find in our profile.
Old 07-16-2013, 11:16   #43 (permalink)
Member: 1865763
Thank you octoplus team,I solved it,had to select manual and the phone is canadian 7560m,octoplus setting was for 7562,ond on my computer com 8 everything worked fine..
thnx
Old 08-05-2013, 12:21   #44 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,279
Arrow DIAG WINDOW WRONG I9100, PHONE EMERGENCY MODE, IMEI and S/N RESTORED SUCCESSFULLY
This is a Small Tutorial for alls Customer of OCTOPU/OCTOPLUS whith Imei and S/N problem for Restore, PHONE IN EMERGENCY MODE, in this Case I9100, SOLVED, SUCCESSFULLY
LOOCK GOOD THIS CONFIGURATION from "DIAG WINDOW", this phone is was be manegged in 1000 wrong mode from one user, HW Damaged but restored all Sw side from me, whith OCTOPUS:
ERRATE DIAG CONFIG, but the unique for repair phone!!!
MAIN MENU --> COMMON --> DIAG CONFIG
[1] LOG VIA USB *
[2] LOG VIA UART
[3] LOG VIA IPC
[4] SPEED 115200
[5] SPEED 921600 *
[6] DBG MSG OFF (toggle)
[7] RAMDUMP OFF (toggle)
[8] DUMP ALL TRACE
RIGHT CONFIG.
[1] LOG VIA USB
[2] SPEED 115200
[3] DBG MSG OFF
[4] RAMDUMP OFF
[5] DUMP ALL TRACE
Phone in Wrong DIAG CONFIG. is detected in Emergency Mode and whith this Config., is working only whith MicroUsb Cable, Uart Cable cannot working becouse the MODEM is Corrupted, SO, i have repaired the same all, but in USB mode, phone can work same, but whith HW damaged, loock LOGs first connection and when is was be repaired, after my changes:
INFO  : 01/08/2013 20.10.10 > Platform: Samsung Android
INFO  : 01/08/2013 20.10.10 > Selected port: COM17
INFO  : 01/08/2013 20.10.10 > Selected model: GT-I9100
INFO  : 01/08/2013 20.10.14 > Phone was not found on the selected port!
INFO  : 01/08/2013 20.10.14 > Searching for USB diagnostic port...
INFO  : 01/08/2013 20.10.14 > Connecting to phone on COM17
INFO  : 01/08/2013 20.10.43 > Mode: Emergency
INFO  : 01/08/2013 20.10.58 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.10.58 > Platform: Samsung Android
INFO  : 01/08/2013 20.10.58 > Selected port: COM17
INFO  : 01/08/2013 20.10.58 > Selected model: GT-I9100
INFO  : 01/08/2013 20.11.28 > Mode: Emergency
ERROR : 01/08/2013 20.11.28 > NVM can’t be read for GT-I9100 phone in emergency mode
INFO  : 01/08/2013 20.11.34 > Platform: Samsung Android
INFO  : 01/08/2013 20.11.34 > Selected port: COM17
INFO  : 01/08/2013 20.11.34 > Selected model: GT-I9100
INFO  : 01/08/2013 20.11.34 > Searching for a phone. Please wait...
INFO  : 01/08/2013 20.12.38 > Phone found.
WARN  : 01/08/2013 20.12.39 > If Screen lock removed and phone not found by software then do next steps:
WARN  : 01/08/2013 20.12.39 > Go to Menu->Settings->Applications->Development.
WARN  : 01/08/2013 20.12.39 > Turn on "USB Debugging" option.
WARN  : 01/08/2013 20.12.39 > When message is appear press "Yes".
INFO  : 01/08/2013 20.12.39 > Searching for a phone. Please wait...
INFO  : 01/08/2013 20.12.39 > Firmware compiled date: Mon Jan 14 16:51:42 KST 2013
INFO  : 01/08/2013 20.12.40 > Phone SN: 00000000000
INFO  : 01/08/2013 20.12.40 > Android version: 4.1.2 (JZO54K)
INFO  : 01/08/2013 20.12.40 > Detecting Screen Lock parameters...
ERROR : 01/08/2013 20.13.04 > Reset Screen Lock failed.
INFO  : 01/08/2013 20.13.21 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.13.21 > Platform: Samsung Android
INFO  : 01/08/2013 20.13.21 > Selected port: COM17
INFO  : 01/08/2013 20.13.21 > Selected model: GT-I9100
INFO  : 01/08/2013 20.13.50 > Mode: Emergency
ERROR : 01/08/2013 20.13.50 > Unlock for GT-I9100 phone in emergency mode can’t be done
INFO  : 01/08/2013 20.14.49 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.14.49 > Platform: Samsung Android
INFO  : 01/08/2013 20.14.50 > Selected port: COM17
INFO  : 01/08/2013 20.14.50 > Selected model: GT-I9100
WARN  : 01/08/2013 20.14.50 > To put GT-I9100 phone into download mode you have to perform the following steps:
WARN  : 01/08/2013 20.14.50 > 1. Reconnect phone battery.
WARN  : 01/08/2013 20.14.50 > 2. Press and hold "Volume - "  + "Home" + "Power" buttons.
WARN  : 01/08/2013 20.14.50 > 3. When phone turns on press "Volume+" button.
INFO  : 01/08/2013 20.15.02 > Repairing EFS...
INFO  : 01/08/2013 20.15.02 > Searching for a phone. Please wait...
WARN  : 01/08/2013 20.22.22 > Repair EFS Failed
After a small Tips by DIAG WINDOW
INFO  : 01/08/2013 20.33.17 > Platform: Samsung Android
INFO  : 01/08/2013 20.33.17 > Selected port: COM3
INFO  : 01/08/2013 20.33.17 > Selected model: GT-I9100
INFO  : 01/08/2013 20.33.21 > Phone was not found on the selected port!
INFO  : 01/08/2013 20.33.21 > Searching for USB diagnostic port...
INFO  : 01/08/2013 20.33.21 > Connecting to phone on COM17
INFO  : 01/08/2013 20.33.50 > Mode: Emergency
INFO  : 01/08/2013 20.34.06 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.34.06 > Platform: Samsung Android
INFO  : 01/08/2013 20.34.06 > Selected port: COM17
INFO  : 01/08/2013 20.34.06 > Selected model: GT-I9100
INFO  : 01/08/2013 20.34.09 > Detected phone model: GT-I9100
INFO  : 01/08/2013 20.34.09 > Firmware compiled date: Mon Jan 14 16:51:42 KST 2013
INFO  : 01/08/2013 20.34.10 > Phone SN: 00000000000
INFO  : 01/08/2013 20.34.10 > Android version: 4.1.2 (JZO54K)
INFO  : 01/08/2013 20.34.10 > Checking Root:
INFO  : 01/08/2013 20.34.12 > Phone is Rooted.
INFO  : 01/08/2013 20.34.12 > Reading Security, please wait...
INFO  : 01/08/2013 20.34.45 > Security read successfully.
INFO  : 01/08/2013 20.34.55 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.34.55 > Platform: Samsung Android
INFO  : 01/08/2013 20.34.55 > Selected port: COM17
INFO  : 01/08/2013 20.34.55 > Selected model: GT-I9100
INFO  : 01/08/2013 20.34.57 > Detected phone model: GT-I9100
INFO  : 01/08/2013 20.34.57 > Firmware compiled date: Mon Jan 14 16:51:42 KST 2013
INFO  : 01/08/2013 20.34.58 > Phone SN: 00000000000
INFO  : 01/08/2013 20.34.58 > Android version: 4.1.2 (JZO54K)
INFO  : 01/08/2013 20.34.58 > Checking Root:
INFO  : 01/08/2013 20.35.00 > Phone is Rooted.
INFO  : 01/08/2013 20.35.00 > Reading EFS, please wait...
INFO  : 01/08/2013 20.35.17 > EFS read successfully.
INFO  : 01/08/2013 20.36.58 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.36.58 > Platform: Samsung Android
INFO  : 01/08/2013 20.36.58 > Selected port: COM17
INFO  : 01/08/2013 20.36.58 > Selected model: GT-I9100
INFO  : 01/08/2013 20.37.28 > Mode: Emergency
CRIT  : 01/08/2013 20.37.28 > Critical error has encounted. Error message: Access violation at address 00778BCC in module 'OctoplusSamsung.exe'. Read of address 00000004
WARN  : 01/08/2013 20.37.59 > Please switch your phone to the download mode and connect it to a PC.
WARN  : 01/08/2013 20.37.59 > To put GT-I9100 phone into download mode you have to perform the following steps:
WARN  : 01/08/2013 20.37.59 > 1. Reconnect phone battery.
WARN  : 01/08/2013 20.37.59 > 2. Press and hold "Volume - "  + "Home" + "Power" buttons.
WARN  : 01/08/2013 20.37.59 > 3. When phone turns on press "Volume+" button.
INFO  : 01/08/2013 20.38.39 > Found phone on
INFO  : 01/08/2013 20.38.39 > Reading PIT...
INFO  : 01/08/2013 20.38.40 > PIT was read successfully.
OK, Now Try whith Downgrade whith ORIGINAL FW whith CSC, FW HOME.TAR V 4.0.4, selecting only PDA, (Unique FW), Warning, first BKP all DATA if have or are Important, when try whit WIPE/FACTORY RESET, not forgot this Step, and Here, phone Successfully Repaired by MicroUsb Cable:
INFO  : 01/08/2013 23.05.04 > Platform: Samsung Android
INFO  : 01/08/2013 23.05.04 > Selected port: COM3
INFO  : 01/08/2013 23.05.04 > Selected model: GT-I9100
INFO  : 01/08/2013 23.05.08 > Phone was not found on the selected port!
INFO  : 01/08/2013 23.05.08 > Searching for USB diagnostic port...
INFO  : 01/08/2013 23.05.08 > Connecting to phone on COM17
INFO  : 01/08/2013 23.05.10 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.05.10 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.05.10 > Phone IMEI: 004999-01-064000-0
INFO  : 01/08/2013 23.05.10 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.05.11 > Phone SN: 00000000000
INFO  : 01/08/2013 23.05.11 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.06.43 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.06.43 > Platform: Samsung Android
INFO  : 01/08/2013 23.06.43 > Selected port: COM17
INFO  : 01/08/2013 23.06.43 > Selected model: GT-I9100
INFO  : 01/08/2013 23.06.44 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.06.44 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.06.45 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.06.46 > Phone SN: 00000000000
INFO  : 01/08/2013 23.06.46 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.06.46 > Old IMEI: 004999-01-064000-0
INFO  : 01/08/2013 23.06.46 > New IMEI: 358490-04-529647-3
INFO  : 01/08/2013 23.06.56 > Creating NVM backup
INFO  : 01/08/2013 23.07.01 > Backup saved as C:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\NVDATA-GT-I9100-004999010640000-01-08-2013_23-06-56-.nvm file
INFO  : 01/08/2013 23.07.01 > Erasing old IMEI. It can take some time. Please wait...
WARN  : 01/08/2013 23.07.13 > Phone will restart now. Please don't disconnect cable!
INFO  : 01/08/2013 23.07.39 > Searching for a phone. Please wait...
INFO  : 01/08/2013 23.08.08 > Phone found.
INFO  : 01/08/2013 23.08.08 > Writing new IMEI. Please wait...
INFO  : 01/08/2013 23.08.26 > Please, restart the phone to apply changes
INFO  : 01/08/2013 23.08.26 > New IMEI successfully written.
INFO  : 01/08/2013 23.11.24 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.11.24 > Platform: Samsung Android
INFO  : 01/08/2013 23.11.25 > Selected port: COM17
INFO  : 01/08/2013 23.11.25 > Selected model: GT-I9100
INFO  : 01/08/2013 23.11.25 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.11.25 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.11.25 > Phone IMEI: 358490-04-529647-3
INFO  : 01/08/2013 23.11.25 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.11.27 > Phone SN: 00000000000
INFO  : 01/08/2013 23.11.27 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.11.28 > Repairing Serial Number. It can take some time. Please wait...
WARN  : 01/08/2013 23.11.42 > Phone will restart now
INFO  : 01/08/2013 23.11.42 > SN repaired successfully.
INFO  : 01/08/2013 23.12.43 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.12.43 > Platform: Samsung Android
INFO  : 01/08/2013 23.12.43 > Selected port: COM17
INFO  : 01/08/2013 23.12.43 > Selected model: GT-I9100
INFO  : 01/08/2013 23.12.44 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.12.44 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.12.44 > Phone IMEI: 358490-04-529647-3
INFO  : 01/08/2013 23.12.44 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.12.45 > Phone SN: RGIB812276H
INFO  : 01/08/2013 23.12.45 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.13.25 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.13.25 > Platform: Samsung Android
INFO  : 01/08/2013 23.13.25 > Selected port: COM17
INFO  : 01/08/2013 23.13.25 > Selected model: GT-I9100
INFO  : 01/08/2013 23.13.28 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.13.28 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.13.29 > Phone SN: RGIB812276H
INFO  : 01/08/2013 23.13.29 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.13.29 > Checking Root:
INFO  : 01/08/2013 23.13.30 > Phone is Rooted.
INFO  : 01/08/2013 23.13.30 > Reading Security, please wait...
INFO  : 01/08/2013 23.14.03 > Security read successfully.
INFO  : 01/08/2013 23.14.09 >
INFO  : 01/08/2013 23.14.09 > Platform: Samsung Android
INFO  : 01/08/2013 23.14.09 > Selected port: COM17
INFO  : 01/08/2013 23.14.09 > Selected model: GT-I9100
INFO  : 01/08/2013 23.14.11 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.14.11 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.14.12 > Phone SN: RGIB812276H
INFO  : 01/08/2013 23.14.12 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.14.12 > Checking Root:
INFO  : 01/08/2013 23.14.13 > Phone is Rooted.
INFO  : 01/08/2013 23.14.13 > Reading EFS, please wait...
INFO  : 01/08/2013 23.14.30 > EFS read successfully.
SAMSUNG I9100 ORIGINAL IMEI and S/N REPAIRED WHITH SUCCESSFULLY, thank to Octopus Box and a small of knowing, All is working now, can remain in this mode, but i want Repair also the HW side, solution requiere other Program and knowing over modem and COMMAND specific to send in phone by PC,
Max
Ripgsm
The Following User Says Thank You to allumts For This Useful Post:
Old 08-10-2013, 15:50   #45 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Thumbs up Did you know how is composed a imei, read here !!!
Many errors when the REPAIR IMEI of a phone, may result from NO knowledge of how it is composed, with this little explanation, maybe you can go back to your original IMEI, SO REPAIR and understand why you often have mistakes, by written a Serial wrong, SW phone incorrect, itc...
International Mobile Equipment Identity, IMEI more commonly called, is nothing more than the
serial number identifier of the cell, is composed of a 15-digit, through which you can back
to the year and the place of manufacture and the date of purchase and is located inside the
cell, usually in the battery compartment.
The IMEI number has a structure "fixed" and is divided into 4 parts:
AAAAAA-BB-CCCCCC-D
where AAAAAA is the TAC (Type Approval Code) that identifies the manufacturer and model of
your mobile phone, BB represents the FAC (Final Assembly Code) that identifies the location
of the building or assembling, CCCCCC indicates the serial number of the phone and D defined
SP (Spare) or CD (Check Digit) and is given a figure of control that checks the correctness
of the IMEI number.
Since April 2004, however, the FAC has been eliminated and it became 00.
Some IMEI codes that are displayed on the display of the mobile phones are also composed of
a further part, formed by 2 digits, called SV (Software Version), indicating the software
version of the device.
Wbr
Questions about Dejan's flasher interface SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 01-15-2001 08:31
8890 questions spongebob Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-10-2001 00:04
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-01-2000 22:47
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-06-1999 23:47
Page generated in 0.47188 seconds with 9 queries
