Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-10-2013, 16:24   #46 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,279
Originally Posted by allumts View Post
This is a Small Tutorial for alls Customer of OCTOPU/OCTOPLUS whith Imei and S/N problem for Restore, PHONE IN EMERGENCY MODE, in this Case I9100, SOLVED, SUCCESSFULLY
LOOCK GOOD THIS CONFIGURATION from "DIAG WINDOW", this phone is was be manegged in 1000 wrong mode from one user, HW Damaged but restored all Sw side from me, whith OCTOPUS:
ERRATE DIAG CONFIG, but the unique for repair phone!!!
MAIN MENU --> COMMON --> DIAG CONFIG
[1] LOG VIA USB *
[2] LOG VIA UART
[3] LOG VIA IPC
[4] SPEED 115200
[5] SPEED 921600 *
[6] DBG MSG OFF (toggle)
[7] RAMDUMP OFF (toggle)
[8] DUMP ALL TRACE
RIGHT CONFIG.
[1] LOG VIA USB
[2] SPEED 115200
[3] DBG MSG OFF
[4] RAMDUMP OFF
[5] DUMP ALL TRACE
Phone in Wrong DIAG CONFIG. is detected in Emergency Mode and whith this Config., is working only whith MicroUsb Cable, Uart Cable cannot working becouse the MODEM is Corrupted, SO, i have repaired the same all, but in USB mode, phone can work same, but whith HW damaged, loock LOGs first connection and when is was be repaired, after my changes:
INFO  : 01/08/2013 20.10.10 > Platform: Samsung Android
INFO  : 01/08/2013 20.10.10 > Selected port: COM17
INFO  : 01/08/2013 20.10.10 > Selected model: GT-I9100
INFO  : 01/08/2013 20.10.14 > Phone was not found on the selected port!
INFO  : 01/08/2013 20.10.14 > Searching for USB diagnostic port...
INFO  : 01/08/2013 20.10.14 > Connecting to phone on COM17
INFO  : 01/08/2013 20.10.43 > Mode: Emergency
INFO  : 01/08/2013 20.10.58 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.10.58 > Platform: Samsung Android
INFO  : 01/08/2013 20.10.58 > Selected port: COM17
INFO  : 01/08/2013 20.10.58 > Selected model: GT-I9100
INFO  : 01/08/2013 20.11.28 > Mode: Emergency
ERROR : 01/08/2013 20.11.28 > NVM canít be read for GT-I9100 phone in emergency mode
INFO  : 01/08/2013 20.11.34 > Platform: Samsung Android
INFO  : 01/08/2013 20.11.34 > Selected port: COM17
INFO  : 01/08/2013 20.11.34 > Selected model: GT-I9100
INFO  : 01/08/2013 20.11.34 > Searching for a phone. Please wait...
INFO  : 01/08/2013 20.12.38 > Phone found.
WARN  : 01/08/2013 20.12.39 > If Screen lock removed and phone not found by software then do next steps:
WARN  : 01/08/2013 20.12.39 > Go to Menu->Settings->Applications->Development.
WARN  : 01/08/2013 20.12.39 > Turn on "USB Debugging" option.
WARN  : 01/08/2013 20.12.39 > When message is appear press "Yes".
INFO  : 01/08/2013 20.12.39 > Searching for a phone. Please wait...
INFO  : 01/08/2013 20.12.39 > Firmware compiled date: Mon Jan 14 16:51:42 KST 2013
INFO  : 01/08/2013 20.12.40 > Phone SN: 00000000000
INFO  : 01/08/2013 20.12.40 > Android version: 4.1.2 (JZO54K)
INFO  : 01/08/2013 20.12.40 > Detecting Screen Lock parameters...
ERROR : 01/08/2013 20.13.04 > Reset Screen Lock failed.
INFO  : 01/08/2013 20.13.21 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.13.21 > Platform: Samsung Android
INFO  : 01/08/2013 20.13.21 > Selected port: COM17
INFO  : 01/08/2013 20.13.21 > Selected model: GT-I9100
INFO  : 01/08/2013 20.13.50 > Mode: Emergency
ERROR : 01/08/2013 20.13.50 > Unlock for GT-I9100 phone in emergency mode canít be done
INFO  : 01/08/2013 20.14.49 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.14.49 > Platform: Samsung Android
INFO  : 01/08/2013 20.14.50 > Selected port: COM17
INFO  : 01/08/2013 20.14.50 > Selected model: GT-I9100
WARN  : 01/08/2013 20.14.50 > To put GT-I9100 phone into download mode you have to perform the following steps:
WARN  : 01/08/2013 20.14.50 > 1. Reconnect phone battery.
WARN  : 01/08/2013 20.14.50 > 2. Press and hold "Volume - "  + "Home" + "Power" buttons.
WARN  : 01/08/2013 20.14.50 > 3. When phone turns on press "Volume+" button.
INFO  : 01/08/2013 20.15.02 > Repairing EFS...
INFO  : 01/08/2013 20.15.02 > Searching for a phone. Please wait...
WARN  : 01/08/2013 20.22.22 > Repair EFS Failed
After a small Tips by DIAG WINDOW
INFO  : 01/08/2013 20.33.17 > Platform: Samsung Android
INFO  : 01/08/2013 20.33.17 > Selected port: COM3
INFO  : 01/08/2013 20.33.17 > Selected model: GT-I9100
INFO  : 01/08/2013 20.33.21 > Phone was not found on the selected port!
INFO  : 01/08/2013 20.33.21 > Searching for USB diagnostic port...
INFO  : 01/08/2013 20.33.21 > Connecting to phone on COM17
INFO  : 01/08/2013 20.33.50 > Mode: Emergency
INFO  : 01/08/2013 20.34.06 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.34.06 > Platform: Samsung Android
INFO  : 01/08/2013 20.34.06 > Selected port: COM17
INFO  : 01/08/2013 20.34.06 > Selected model: GT-I9100
INFO  : 01/08/2013 20.34.09 > Detected phone model: GT-I9100
INFO  : 01/08/2013 20.34.09 > Firmware compiled date: Mon Jan 14 16:51:42 KST 2013
INFO  : 01/08/2013 20.34.10 > Phone SN: 00000000000
INFO  : 01/08/2013 20.34.10 > Android version: 4.1.2 (JZO54K)
INFO  : 01/08/2013 20.34.10 > Checking Root:
INFO  : 01/08/2013 20.34.12 > Phone is Rooted.
INFO  : 01/08/2013 20.34.12 > Reading Security, please wait...
INFO  : 01/08/2013 20.34.45 > Security read successfully.
INFO  : 01/08/2013 20.34.55 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.34.55 > Platform: Samsung Android
INFO  : 01/08/2013 20.34.55 > Selected port: COM17
INFO  : 01/08/2013 20.34.55 > Selected model: GT-I9100
INFO  : 01/08/2013 20.34.57 > Detected phone model: GT-I9100
INFO  : 01/08/2013 20.34.57 > Firmware compiled date: Mon Jan 14 16:51:42 KST 2013
INFO  : 01/08/2013 20.34.58 > Phone SN: 00000000000
INFO  : 01/08/2013 20.34.58 > Android version: 4.1.2 (JZO54K)
INFO  : 01/08/2013 20.34.58 > Checking Root:
INFO  : 01/08/2013 20.35.00 > Phone is Rooted.
INFO  : 01/08/2013 20.35.00 > Reading EFS, please wait...
INFO  : 01/08/2013 20.35.17 > EFS read successfully.
INFO  : 01/08/2013 20.36.58 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 20.36.58 > Platform: Samsung Android
INFO  : 01/08/2013 20.36.58 > Selected port: COM17
INFO  : 01/08/2013 20.36.58 > Selected model: GT-I9100
INFO  : 01/08/2013 20.37.28 > Mode: Emergency
CRIT  : 01/08/2013 20.37.28 > Critical error has encounted. Error message: Access violation at address 00778BCC in module 'OctoplusSamsung.exe'. Read of address 00000004
WARN  : 01/08/2013 20.37.59 > Please switch your phone to the download mode and connect it to a PC.
WARN  : 01/08/2013 20.37.59 > To put GT-I9100 phone into download mode you have to perform the following steps:
WARN  : 01/08/2013 20.37.59 > 1. Reconnect phone battery.
WARN  : 01/08/2013 20.37.59 > 2. Press and hold "Volume - "  + "Home" + "Power" buttons.
WARN  : 01/08/2013 20.37.59 > 3. When phone turns on press "Volume+" button.
INFO  : 01/08/2013 20.38.39 > Found phone on
INFO  : 01/08/2013 20.38.39 > Reading PIT...
INFO  : 01/08/2013 20.38.40 > PIT was read successfully.
OK, Now Try whith Downgrade whith ORIGINAL FW whith CSC, FW HOME.TAR V 4.0.4, selecting only PDA, (Unique FW), Warning, first BKP all DATA if have or are Important, when try whit WIPE/FACTORY RESET, not forgot this Step, and Here, phone Successfully Repaired by MicroUsb Cable:
INFO  : 01/08/2013 23.05.04 > Platform: Samsung Android
INFO  : 01/08/2013 23.05.04 > Selected port: COM3
INFO  : 01/08/2013 23.05.04 > Selected model: GT-I9100
INFO  : 01/08/2013 23.05.08 > Phone was not found on the selected port!
INFO  : 01/08/2013 23.05.08 > Searching for USB diagnostic port...
INFO  : 01/08/2013 23.05.08 > Connecting to phone on COM17
INFO  : 01/08/2013 23.05.10 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.05.10 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.05.10 > Phone IMEI: 004999-01-064000-0
INFO  : 01/08/2013 23.05.10 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.05.11 > Phone SN: 00000000000
INFO  : 01/08/2013 23.05.11 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.06.43 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.06.43 > Platform: Samsung Android
INFO  : 01/08/2013 23.06.43 > Selected port: COM17
INFO  : 01/08/2013 23.06.43 > Selected model: GT-I9100
INFO  : 01/08/2013 23.06.44 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.06.44 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.06.45 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.06.46 > Phone SN: 00000000000
INFO  : 01/08/2013 23.06.46 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.06.46 > Old IMEI: 004999-01-064000-0
INFO  : 01/08/2013 23.06.46 > New IMEI: 358490-04-529647-3
INFO  : 01/08/2013 23.06.56 > Creating NVM backup
INFO  : 01/08/2013 23.07.01 > Backup saved as C:\Programmi\Octoplus\Octoplus_Samsung\BACKUP\NVDATA-GT-I9100-004999010640000-01-08-2013_23-06-56-.nvm file
INFO  : 01/08/2013 23.07.01 > Erasing old IMEI. It can take some time. Please wait...
WARN  : 01/08/2013 23.07.13 > Phone will restart now. Please don't disconnect cable!
INFO  : 01/08/2013 23.07.39 > Searching for a phone. Please wait...
INFO  : 01/08/2013 23.08.08 > Phone found.
INFO  : 01/08/2013 23.08.08 > Writing new IMEI. Please wait...
INFO  : 01/08/2013 23.08.26 > Please, restart the phone to apply changes
INFO  : 01/08/2013 23.08.26 > New IMEI successfully written.
INFO  : 01/08/2013 23.11.24 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.11.24 > Platform: Samsung Android
INFO  : 01/08/2013 23.11.25 > Selected port: COM17
INFO  : 01/08/2013 23.11.25 > Selected model: GT-I9100
INFO  : 01/08/2013 23.11.25 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.11.25 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.11.25 > Phone IMEI: 358490-04-529647-3
INFO  : 01/08/2013 23.11.25 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.11.27 > Phone SN: 00000000000
INFO  : 01/08/2013 23.11.27 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.11.28 > Repairing Serial Number. It can take some time. Please wait...
WARN  : 01/08/2013 23.11.42 > Phone will restart now
INFO  : 01/08/2013 23.11.42 > SN repaired successfully.
INFO  : 01/08/2013 23.12.43 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.12.43 > Platform: Samsung Android
INFO  : 01/08/2013 23.12.43 > Selected port: COM17
INFO  : 01/08/2013 23.12.43 > Selected model: GT-I9100
INFO  : 01/08/2013 23.12.44 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.12.44 > HW Version: XXXXXXXXXXXXXX
INFO  : 01/08/2013 23.12.44 > Phone IMEI: 358490-04-529647-3
INFO  : 01/08/2013 23.12.44 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.12.45 > Phone SN: RGIB812276H
INFO  : 01/08/2013 23.12.45 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.13.25 > -----------------------------------------------------------------------------------
INFO  : 01/08/2013 23.13.25 > Platform: Samsung Android
INFO  : 01/08/2013 23.13.25 > Selected port: COM17
INFO  : 01/08/2013 23.13.25 > Selected model: GT-I9100
INFO  : 01/08/2013 23.13.28 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.13.28 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.13.29 > Phone SN: RGIB812276H
INFO  : 01/08/2013 23.13.29 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.13.29 > Checking Root:
INFO  : 01/08/2013 23.13.30 > Phone is Rooted.
INFO  : 01/08/2013 23.13.30 > Reading Security, please wait...
INFO  : 01/08/2013 23.14.03 > Security read successfully.
INFO  : 01/08/2013 23.14.09 >
INFO  : 01/08/2013 23.14.09 > Platform: Samsung Android
INFO  : 01/08/2013 23.14.09 > Selected port: COM17
INFO  : 01/08/2013 23.14.09 > Selected model: GT-I9100
INFO  : 01/08/2013 23.14.11 > Detected phone model: GT-I9100
INFO  : 01/08/2013 23.14.11 > Firmware compiled date: Fri Oct 26 16:04:15 KST 2012
INFO  : 01/08/2013 23.14.12 > Phone SN: RGIB812276H
INFO  : 01/08/2013 23.14.12 > Android version: 4.0.4 (IMM76D)
INFO  : 01/08/2013 23.14.12 > Checking Root:
INFO  : 01/08/2013 23.14.13 > Phone is Rooted.
INFO  : 01/08/2013 23.14.13 > Reading EFS, please wait...
INFO  : 01/08/2013 23.14.30 > EFS read successfully.
SAMSUNG I9100 ORIGINAL IMEI and S/N REPAIRED WHITH SUCCESSFULLY, thank to Octopus Box and a small of knowing, All is working now, can remain in this mode, but i want Repair also the HW side, solution requiere other Program and knowing over modem and COMMAND specific to send in phone by PC,
Max
Ripgsm
How had promitted, have also repaired Hardware Area whith only RX-TX-GND and small sw procedure, at the end have flashed fw 4.1.2 Here:
INFO  : 05/08/2013 19.03.16 > To connect GT-I9100 phone you have to perform the following steps:
INFO  : 05/08/2013 19.03.16 > 1. Disconnect USB cable from phone.
INFO  : 05/08/2013 19.03.16 > 2. Go to Menu->Settings->Applications->Development.
INFO  : 05/08/2013 19.03.16 > 3. Turn on "USB Debugging" option.
INFO  : 05/08/2013 19.03.16 > 4. When message is appear press "Yes".
INFO  : 05/08/2013 19.03.16 > 5. Go to dial window.
INFO  : 05/08/2013 19.03.16 > 6. Enter "*#7284#" number.
INFO  : 05/08/2013 19.03.16 > 7. Set "USB" radio button to "PDA" value.
INFO  : 05/08/2013 19.03.16 > 8. Close window.
INFO  : 05/08/2013 19.03.16 > 9. Go to dial window.
INFO  : 05/08/2013 19.03.16 > 10. Enter "*#9090#" number.
INFO  : 05/08/2013 19.03.16 > 11. Set "Diag config" to "USB" value.
INFO  : 05/08/2013 19.03.16 > 12. Restart phone.
INFO  : 05/08/2013 19.03.16 > 13. Press "Read Info" in software.
INFO  : 05/08/2013 19.08.03 > Platform: Samsung Android
INFO  : 05/08/2013 19.08.03 > Selected port: COM36
INFO  : 05/08/2013 19.08.03 > Selected model: GT-I9100
INFO  : 05/08/2013 19.08.03 > Reading info, please wait...
INFO  : 05/08/2013 19.08.03 > Detected phone model: GT-I9100
INFO  : 05/08/2013 19.08.03 > Firmware compiled date: Thu Jan 31 14:30:29 KST 2013
INFO  : 05/08/2013 19.08.04 > Phone SN: RGIB812276H
INFO  : 05/08/2013 19.08.04 > Android version: 4.1.2 (JZO54K)
Max
Old 08-13-2013, 20:02   #47 (permalink)
allumts's Avatar
Member: 1564612
How to put in "debug usb" samsung i9505 s4
For All,
can be many peoples not find the "Debug Button" in Samsung Galaxy S4 I9505, ok read and apply these easy Step by Step:
1) Power On the Phone,
2) Go in "APPLICATIONES" from Menu',
3) Go in "SETTING" tabulate,
4) Have 4 Sub menu, loock "OTHER",
5) Go in "INFO DEVICE",
6) Loock for "BUILD VERSION",
7) Click here 7 (seven) Times,
8) OK, Now u can see "You are Development Now"
9) Back Key, select "DEVELPMENT OPTION",
10) Ceck "DEBUG USB"
Now have Put I9505 in "DEBUG USB" MODE,
Max
Old 08-13-2013, 20:14   #48 (permalink)
allumts's Avatar
Member: 1564612
For Root this Phone, use only the file "ROOT I9505.oct" from Bootloader, any other Attempt whith Odin or other tools get always "MODEM FAIL ERROR", we are Lucky having OCTOPUS/OCTOPLUS BOX,
Max
Edit, if Command *#7284# isn't Work, for put in MODEM value I9505, try whith Good UART cable from Power Off phone, when it power on w/o action, now we can digit in the keyboard *#7284# and select MODEM...
Old 08-30-2013, 13:39   #49 (permalink)
gencom's Avatar
Member: 1918391
Thanks Meter: 61
[1] LOG VIA USB *
[2] LOG VIA UART
[3] LOG VIA IPC
[4] SPEED 115200
[5] SPEED 921600 *
[8] DUMP ALL TRACE
RIGHT CONFIG.
[1] LOG VIA USB
[2] SPEED 115200
[3] DBG MSG OFF
[4] RAMDUMP OFF
[5] DUMP ALL TRACE
Max
Ripgsm
i dont understand anything
downgrade required for escape emergency mode?
Old 08-30-2013, 18:11   #50 (permalink)
allumts's Avatar
Member: 1564612
@gencom, olny Right phone prepair and when 1 procedure fail, ceck Carefully that all is was done correctament, in this case,
DIAG CONGIG. was totally Wrong and modem Damaged, i've repaired all in Usb mode, also IMEI, w/o UART CABLE and OCTOPUS, but isn't right for normal I9100.
For escape EMERGENCY MODE,
-ceck always that NO OTHER ANDROID DRIVER or SW are running togheter whith Octopus,
-ceck always phone is in correct Dial and Diag Window,
-ceck always "USB DEBUG" is abilitated,
-ceck if other program FREE or cracked for Rootting or other is Open for ADB SERVER, use CTRL+ALT+CANC in keypad and see which program are running, EMERGENCY MODE can give for various thinghs,
NO, now I9100 is Full Supported from OCTOPUS in V. 4.1.2, no downgrade needed,
Max
Old 09-13-2013, 18:52   #51 (permalink)
allumts's Avatar
Member: 1564612
SAMSUNG i527 AT&T ROOTTING PROCEDURE
For alls,
the Rootting procedure for Samsung i527M AT&T i527 can be available only whith carefully procedure, please who NOT KNOW what are doing NOT USE this procedure, risk of BRICK your Phones.
NOT USE RE-PARTITION BUTTON IN ODIN, who use it... is only a big lol.....
This link is ok for others Samsung, (not supported too), root by Odin:
Root Samsung Mega I527 in feeds
Max
Old 09-20-2013, 12:16   #52 (permalink)
allumts's Avatar
Member: 1564612
HOW INSTALL CARD DRIVERS in WIN7 32 BIT in EASY STEPS
HOW INSTALL CARD DRIVERS in WIN7 32 BIT in EASY STEPS:
- Exstract in C:/ Box Drivers_V5 (remember this path)
- Open "Device Manager" by Control Pannel
- Connect OCTOPUS whith Card
- NOT USE "SMART CART" of DEFAULT in "DEVICE MANAGER"
- Now u see "ESV Card"
- Then u see "ESV" Card Request Drivers (Card Drivers, no Box Drivers)
- Choise Manual Installaction, NO Automatic, (if window ask for Admin and permission put OK)
- Put the Path Directory where are "Box Drivers_V5>TOP GX4>X32", press next, u will see ESV Smart Card Drivers Installed,
- Now u have ""Generic PC/SC Usb Smart Card Reader" whith SZCCID.Sys File inside, OCTOPUS S.CARD Installed, Remember always Choise MANUAL Install NO AUTOMATIC,
Nota: Can install these S.Card Driver whith "Egate Readers" first, (found in the same Folder), and after X32 where have the SZCCID.Sys file, but if have other Box that use "Egate Drivers" can goes in conflict.
Now are Ready For install BOX Drivers if just not are installed, if have Specific problem, OCTOPUS SUPPORT can HELP YOU or can Post Screeshoot of the ERROR, Always Post Screen , i hope it can help and To help many other Users of OCTOPUS BOX,
Max
Old 09-20-2013, 12:32   #53 (permalink)
allumts's Avatar
Member: 1564612
Thumbs up Error in configuraction card reader, here:
ERROR IN CONFIGURACTION CARD READER, HERE:
Whith This configuraction you are Just ERRATED in STARTING, (to post Big Pictures), how you can see you has installed one readers: "MICROSOFT USBCCID SMARTCARD READER" can see from "WUDF" and TOKEN READER, it's WRONG.
SOLUCTION:
- Disconnect OCTOPUS whith CARD
- Unistall all these readers from win7, (from where has installed can Uninstall),
- reeboot Pc, ceck "Device Manager" that All TOKEN and M.Usbccid are unistalled,
- Connect now OCTOPUS whith CARD in USB 2.0
- Now u can see ? in Card, whith request for "ESV Card"
NOTE: IF "SZCCID" file isn't Inside, choise "Update Drivers" and MANUALLY, select this .Sys File, press OK and Next, all done!!!
LOOCK HERE where You are Wrongs, if after install CARD OCTOPUS DRIVERS, YOU have this in "Device Manager":
Max
The Following User Says Thank You to allumts For This Useful Post:
Old 10-04-2013, 18:57   #54 (permalink)
allumts's Avatar
Member: 1564612
RIGHT UART CABLE JIG and PINOUT
FOR ALL CUSTOMERS WHITH UART CABLE PROBLEM, AFTER MY RESEARCH BECOUSE MY UART CABLE WAS WORKING GOOD AND OTHERS NO, HERE A PICTURE HOW IS RIGHT UART CABLE:
Now, which are colours Right?, which resistor we needed?, easy,
Resistor colours Right are Green-Blue-Yellow whith a other Band that can be "gold", this is all in one side and is TOLLERANCE +/- 5%, this is GOOD resistor 4 Bands and Total get Out 560K whith 5% + o - of tollerance, who want to calcular his Resistor go here: Codici delle resistenze elettriche - Calcolare il valore della Resistenza dal Codice dei Colori , is in Italian but only enter colours and the System show EXACT Value of your resistor, loock the Picture and make yourself u UART CABLE or Ceck which have if is Right
I want to hope this small explanaction can be of help,
Regards
Max
Old 11-11-2013, 02:03   #55 (permalink)
Member: 370972
Thanks Meter: 7
some button no active
hello,
i'm new user octopus with lg+samsung act.
want to ask about some button can be click (no active), can anybody explain that!
like reset screenlock, factory reset, all aditional option, all repair option, all bkup option, etc.
i'm try to gt-s6500 normal (via usb and uart cable)
just for first try and learning
Old 11-11-2013, 07:13   #56 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 24,109
If button in Software is inactive, this means, that this option is not supported for selected device or it is necessary to connect the device before by pressing "Connect" button.
What is the problem with your device? Which actions do You want to perform with your GT-S6500 exactly?
Old 11-11-2013, 08:13   #57 (permalink)
Member: 370972
Thanks Meter: 7
nothing problem sir! i just want to know how to remove google account, rooting device, read user code without full flashing with this box
read info, write firmware, and all button show active, i'm try it's normal
Welcome to Octoplus/Octopus Box Samsung software version 1.4.0
To connect GT-S6500 phone you have to perform the following steps:
6. Enter "*#9090#" number.
7. Set "Diag config" to "USB" value.
8. Restart phone.
9. Press "Read Info" in software.
Platform: Samsung Anycall
Selected port: COM162
Selected model: GT-S6500
Mode: Normal
Phone model: GT-S6500
Firmware compiled date: Dec 23 2011
Firmware compiled time: 11:00:00
Firmware released date: Apr 9 2012
Firmware released time: 20:16:36
Phone IMEI: 356728-05-026648-1
SW Version: 76XXU-USMSKRLYM-109806
Old 11-14-2013, 20:09   #58 (permalink)
allumts's Avatar
Member: 1564612
Thumbs up RIGHT OCTOPUS BOX and CARD DRIVERS IN WIN7 32BIT
How many peoples has request post here a small tutorial whith Pictures of CORRECT Octopus Box and Car Installed in SO Win7 32 BIT.
a) Download and extract .Rar BOX DRIVERS V5 in a Path of your preference, more good in C:/ principal directory of your Pc,
b) install all OCTOPLUS/OCTOPUS SW do you have need,
c) connect Box to a NO HUB Usb Port of your Motherboard pc, NO HUB,
d) now do you can see 3 point ? yellow, are "Usb Serial Converter", "Usb Serial Port" and last but very Important "Smart Card Readers/driver", ok let's go,
e) for any drivers not use Windows path but MANUALLY Directory where do you have saved and extract the "OCTOPUS BOX DRIVERS V5",
f) Start, for example for "Usb Serial Converter" , put this manually path for example: C:\BoxDrivers_v5\BoxDrivers_v5\FTDI\CDM v2.08.28 Certified, then select next and driver install automatic, if have problem select "Disk Driver" and put i386 then "serial converter. inf" or "Ftdi Bus .inf" or "Ftdi Port.inf" which do you have need and press ok and next, all done
g) same thingh for "Usb Serial Port" manually same Directory above,
h) for "Smart Card Drivers" use the general Smart card readers in windows7 and always Manuallu get this Path: C:\BoxDrivers_v5\BoxDrivers_v5\TOP GX4\x32 then select "disk Driver" and from the above path use the .Sys file "SZCCID" press OK and next, now u can see fron "Device Manager", do you not have more point ? yellow, alls OCTOPUS DRIVERS ARE INSTALLED CORRECTAMENT
Here 2 screenshoot of drivers installed correctament, in my case i've other Smart Card, "Egate Readers" that i not use for OCTOPUS, not to see the my yellow not istalled driver, becouse i use a Card Readers for MEDUSA and OCTOPUS, OK?, but in normal condition w/o reader external use "Egate Readers Card" and "Card Drivers":
IT'S MY CASE, BUT I WORK WHITH OTHER CARD, IF YOU HAVE THIS WHITH CARD INSIDE THE OCTOPUS, ARE NOT WORKING:
IT'S CORRECT INSTALL WHITH EXTERNAL READERS BUT IS OK ALSO WHITH CARD INSIDE THE OCTOPUS ONLY CHANGE THE READERS THAT COMPARE:
In this case i've one device connected and Octopus connected, i hope can help anybody all this,
Max
Old 11-29-2013, 16:21   #59 (permalink)
allumts's Avatar
Member: 1564612
Thumbs up I9505 whith NEW SECURITY V. 4.3, FLASH THIS FOR IMEI REPAIR, SMALL TIP
How many of you cannot Unlock/repair Imei in Samsung Galaxy I9505 vers. 4.3 whith NEW SECURITY?, i think many of you, ok use this small TIP and AFTER ROOTTED you I9505 CAN REPAIR IMEI W/O PROBLEM, tested by me over 6/8 of these, no need downgrade from 4.3:
- Perform all steps for prepare phone in Samsung Sw first of all,
- Flash this Patch in Phone, (put in Download Mode Vol - Home Power then put Vol +), whith note Flasher program:Download I9505_modem_patch_File_for_Unlock_and_imei_repair_ 4.3.tar from mirrorcreator.com
- ROOT the Phone, (if not root not continue),
- Continue whith Normal procedure for Unlock/Imei Repair
Alls ok now phone accept you Unlock and Imei repair w/o issues, FW 4.3 No Downgrade
Post resultated please, if this is of utility thanked,
Max
Old 02-18-2014, 17:40   #60 (permalink)
Member: 2131217
helo there
i have a problem .
my pc work with windows 7 ultimate 64 pit operating system.
i cant install driver for
smart card
mdsj
iam downloaded the BoxDrivers_v5 و and Followed the instructions that you're talking about, but I did not succeed in that
Can you guide me how to install it on the system
Questions about Dejan's flasher interface SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 01-15-2001 08:31
8890 questions spongebob Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-10-2001 00:04
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-01-2000 22:47
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-06-1999 23:47
Page generated in 0.28290 seconds with 9 queries
