Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 02-18-2014, 18:58   #61 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,279
Originally Posted by iplus.acs View Post
i have a problem .
my pc work with windows 7 ultimate 64 pit operating system.
i cant install driver for
smart card
mdsj
iam downloaded the BoxDrivers_v5 و and Followed the instructions that you're talking about, but I did not succeed in that
Can you guide me how to install it on the system
no needed any Guide, only Read carefully post and Photos.
In these photo above the CARD is in one Reader but you have inside the BOX, so if has installed All FTDI drivers for X64 NO X32, when you see the point "?" yellowe in Device Manager and ASK for CARD DRIVERS, you get these from MANUALLY DIRECTORY, get first the Path where do u have Smart card Driver>Next and chise other time Have Disk> find SZCCID file and next other time, ready...
Old 03-01-2014, 11:42   #62 (permalink)
titanium83's Avatar
Member: 1958886
Thanks Meter: 25
sorry for same fale is correct file
Platform: Samsung Swift
Selected model: GT-S5610
Selected port: USB
Please reconnect, press "2" and "5" and connect usb cable
Connecting...
Phone found.
Chipset version : 11
SCROM version : 3C
Sending loaders...
Preloader send successfully
Conecting to pipes...
Writing firmware...
Writing Firmware
Writing Firmware Failed
Old 03-01-2014, 11:46   #63 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 24,109
Try to write other firmwares.
Old 03-05-2014, 15:41   #64 (permalink)
Member: 584915
Thanks Meter: 3
HI OCTOPUS BOX
ihave problem regarding rebuilding imei it stock on Repairing IMEI ...
Executing exploit...
almost 1hr see logs
Welcome to Octoplus/Octopus Box Samsung software version 1.5.0
To connect GT-I9300 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Reboot phone.
10. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM1
Selected model: GT-I9300
Searching for a phone. Please wait...
Phone found.
Firmware compiled date: Tue May 22 22:06:19 KST 2012
PDA version: I9300XXALEF
CSC version: I9300OJVALEC
SW version: I9300XXLEF
Phone IMEI: 004999010640000
Phone SN: 00000000000
Android version: 4.0.4 (IMM76D)
Selected port: COM1
Detected phone model: GT-I9300
Checking Root:
Phone is Rooted.
Writing EFS, please wait...
Phone will restart now
EFS write successfully.
Selected port: COM1
ADB server killed.
Phone SN: RF1C63FMRPH
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung
\BACKUP\Security-GT-I9300-Unknown05-03-2014_18-25-12-.asec file
Cheking security type...
Old security type is detected
Old IMEI: 004999-01-064000-0
New IMEI: 353328-05-838234-0
Repairing IMEI ...
Old 03-05-2014, 21:01   #65 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by c0ldbUrn View Post
HI OCTOPUS BOX
almost 1hr see logs
9. Reboot phone.
Selected port: COM1
Phone found.
Selected port: COM1
Checking Root:
Phone is Rooted.
Selected port: COM1
ADB server killed.
Checking Root:
Phone is Rooted.
Repairing IMEI ...
Hi, why have repaired EFS????
Try whith Fw 4.1.2 from support Area or try whith OLD Sw version Octopus
post result
allumts
Old 03-06-2014, 11:46   #66 (permalink)
Member: 584915
Thanks Meter: 3
post result
allumts
the device used to be deadboot...
i've repair the boot and now i been working with changing imei as well as it network, i've notice that as i uses higher update of the tool it stop or hang with "executing expliot" only for 4.0.4 version of the device, while updating the device with ver.4.1.2 works (it executes writing imei) but imei still 004, it does not change as well as the network won't work
Old 03-06-2014, 19:47   #67 (permalink)
allumts's Avatar
Member: 1564612
Hello, try whith Last 4.3 version New Security, you can repair Imei and if not had signal then Repair Network option.
Remember whith New Security you Cannot re-write any other Fw or Wipe/Reset itc... becouse lost other time network and will do other time "Repair Network" for signal, tested by me over 10 devices
Old 05-10-2014, 17:42   #68 (permalink)
titanium83's Avatar
Member: 1958886
Thanks Meter: 25
Product Supporter octopus help for s5610 flashing error
error
Welcome to Octoplus/Octopus Box Samsung software version 1.5.6
Selected port: USB
Please reconnect the battery, press "2" + "5" buttons and connect USB
cable
Connecting...
Phone found.
SCROM version : 3C
Sending loaders...
Writing firmware...
Old 05-10-2014, 17:46   #69 (permalink)
titanium83's Avatar
Member: 1958886
Thanks Meter: 25
I have tried all the Writing did not give any result
and more wire to another s5610
thx
Old 05-15-2014, 09:06   #70 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 136
i need a litle help after update 4.1.2 s3 mini i8190 no wifi and bluetooth.
Old 05-15-2014, 13:29   #71 (permalink)
Member: 1681817
Sonork: 9005050152081
hi octopus team i wana repair s2 i9100 imei is null im trying with z3x nspro and octopus boxs but all asking during repair *#9090# when i type it i cant see something ther on phone screen please help me thanks
Old 05-15-2014, 13:59   #72 (permalink)
Member: 392182
Thanks Meter: 4
my lg not activated and country problem
Dear Sir
I Buy my OCTOPUS BOX FROM INDIA with lg activation but now i have problem of country and LG activation.
follow is my log of update card.
the card is valid card (TOP). Activations: Samsung
Selecetd card 0000000
Updates count : 1
Updates limit : 15
Conection from country : South Africa
Destination Country : IN
Destination country doesn`t correspond to IP
[email protected]
Old 05-15-2014, 14:13   #73 (permalink)
Member: 1146942
Sonork: 100.1587278
Your Box is for INDIA market only:
Please, contact to your reseller.
Old 05-15-2014, 19:52   #74 (permalink)
allumts's Avatar
Member: 1564612
try to repair via Medusa Jtag and solve you problem...
Old 06-03-2014, 15:06   #75 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 155
Exclamation Samsung gt-c782 flash problem
Hi octoplus team. I try to flash samsung c3782.....i choose the flash file and press write firmware.....in log ox writing press volume up and lock button and connect phone via usb without battery....where is lock button on samsung gt-c3782? I am unable find this button ))) can you help me? And which cable i need? Uart or simple micro usb cable?
Questions about Dejan's flasher interface SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 9 01-15-2001 08:31
8890 questions spongebob Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-10-2001 00:04
I have that soft if smb need ask for testing.. Nec Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-01-2000 22:47
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-06-1999 23:47
Page generated in 0.27689 seconds with 9 queries
