04-14-2016, 11:40 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try switching the auto network switch on or off to see if that will make any difference. You can go to go to Settings>Wi-Fi>Menu>Advanced to do this. You can also try to disable apps that uses Wi-Fi radio like the Wi-Fi Direct and Wi-Fi Direct Share under Settings>Applications manager on the All tab. If problem will remain the same - try to write different firmwares one by one. Currently no other solution. |
