07-10-2013, 19:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 93292 Status: Offline Sonork: www.paypal.me/FGSM Thanks Meter: 83 | OTHER PROBLEM i9505 not unlocked NOT SUPPORTED ----------------------------------------------------------------------------------- To connect GT-S6500 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#9090#" number. 7. Set "Diag config" to "USB" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to dial window. 9. Enter "*#9090#" number. 10. Select "[4] DM over UART(*)". 11. Restart phone. 12. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Mode: Normal Phone model: ACEFWTAZ Phone model is not supported Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM3 Mode: Normal Phone model: ACEFWTAZ Phone model is not supported Mode: Normal Phone model: ACEFWTAZ Phone model is not supported Phone connection failed Selected action can’t be performed |
07-10-2013, 20:27 | #2 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
-install correct drivers from Manualy directory, - put the phone in the 2 section of Diag window Right, - Root the phone manualy - try for unlock after Diag Window set right -when reeboot and power on totaly connect the Uart cable* *Change Uart cable if phone isn't detected, test 525/530K, if not see try whith Octopus 330K whith inside 530 resistor, if not is detected restart from step one, Br allumts | |
07-10-2013, 21:06 | #4 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Strange it, becouse yesterday whith one I9300 always done whith Uart Rextore cable 530K resistor, have waste a couple of the time, for Imei and Serial number restore, when have tryed whith Gpg cable 330K and inside resistor of 530/35K resistor phone done in 1 min.s |
07-11-2013, 06:18 | #5 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | As You can see, your phone detects as ACEFWTAZ, not as GT-I9505: Quote:
07-11-2013, 08:45 | #6 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Yes, ACEFWTAZ is the platform of the phone not the model, Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Mode: Normal Phone model: ACEFWTAZ Phone model is not supported * *For Direct UNLOCK in the Read Codes GT-I9505, is showened Br |
