08-18-2018, 14:04 | #739 (permalink) |
No Life Poster Join Date: Apr 2014 Location: istanbul
Member: 2171555 Status: Offline Thanks Meter: 129 | Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\18-08-2018_15-46-58.log" created (18.08.2018 15:47:01). INFO : 18.08.2018 15:47:18 > Set up system language English (file: English.ini) INFO : 18.08.2018 15:47:18 > Welcome to Octoplus Box Samsung software version 2.7.0 INFO : 18.08.2018 15:47:31 > ----------------------------------------------------------------------------------- INFO : 18.08.2018 15:47:31 > To connect SM-G935F phone you have to perform the following steps: INFO : 18.08.2018 15:47:31 > 1. Disconnect USB cable from phone. INFO : 18.08.2018 15:47:31 > 2. Go to Menu->Settings->More->About Device. INFO : 18.08.2018 15:47:31 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 18.08.2018 15:47:31 > 4. Go to Menu->Settings->More->Developer options. INFO : 18.08.2018 15:47:31 > 5. Turn on "USB Debugging" option. INFO : 18.08.2018 15:47:43 > ----------------------------------------------------------------------------------- INFO : 18.08.2018 15:47:43 > To connect SM-G920F phone you have to perform the following steps: INFO : 18.08.2018 15:47:43 > 1. Disconnect USB cable from phone. INFO : 18.08.2018 15:47:43 > 2. Go to Menu->Settings->More->About Device. INFO : 18.08.2018 15:47:43 > 3.Tap on "Build number" 7 times to enable developer options. INFO : 18.08.2018 15:47:43 > 4. Go to Menu->Settings->More->Developer options. INFO : 18.08.2018 15:47:43 > 5. Turn on "USB Debugging" option. INFO : 18.08.2018 15:48:00 > Selected AP file: G:\001 - flaş samsung\g920f\00 7.0 Root ve yazılım\chimera root\7.0\sm-g920f_mroot_700_5.tar.md5 WARN : 18.08.2018 15:48:01 > Please put the phone into Download Mode and connect USB cable. WARN : 18.08.2018 15:48:01 > To put SM-G920F into Download Mode, You have to perform the following steps: WARN : 18.08.2018 15:48:01 > 1. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 18.08.2018 15:48:01 > 2. When phone turns on, press "Volume+" key. INFO : 18.08.2018 15:48:17 > Found phone on WARN : 18.08.2018 15:48:17 > Advanced mode! INFO : 18.08.2018 15:48:19 > Firmware write started. INFO : 18.08.2018 15:48:19 > Writing BOOT section... INFO : 18.08.2018 15:48:21 > BOOT section has been written successfully. INFO : 18.08.2018 15:48:21 > Firmware writing successfully completed. INFO : 18.08.2018 15:48:21 > Performed by 2.7.0.3 Software version. INFO : 18.08.2018 15:49:29 > ----------------------------------------------------------------------------------- INFO : 18.08.2018 15:49:30 > Platform: Samsung Android INFO : 18.08.2018 15:49:30 > Selected port: COM1 INFO : 18.08.2018 15:49:30 > Selected model: SM-G920F INFO : 18.08.2018 15:49:30 > Operation: Repair IMEI A WARN : 18.08.2018 15:49:32 > Please, press "OK" button on the phone to allow USB debugging. INFO : 18.08.2018 15:49:34 > Detected phone model: SM-G920F INFO : 18.08.2018 15:49:34 > Firmware compiled date: Mon Mar 12 17:04:20 KST 2018 INFO : 18.08.2018 15:49:34 > PDA version: G920FXXU6ERC9 INFO : 18.08.2018 15:49:34 > CSC version: G920FVFG6ERCA INFO : 18.08.2018 15:49:34 > SW version: G920FXXU6ERC9 INFO : 18.08.2018 15:49:35 > Phone SN: RF8G4027FFY INFO : 18.08.2018 15:49:35 > Android version: 7.0 (NRD90M) INFO : 18.08.2018 15:49:35 > Sales code: VD2 INFO : 18.08.2018 15:49:35 > Country: Germany INFO : 18.08.2018 15:49:35 > HW platform: exynos5 INFO : 18.08.2018 15:49:35 > HW Chip: exynos7420 INFO : 18.08.2018 15:49:35 > HW Modem: SHANNON333 INFO : 18.08.2018 15:49:35 > Security patch level: 2018-03-01 INFO : 18.08.2018 15:49:35 > Warranty Void: 1 INFO : 18.08.2018 15:49:35 > SIM 1 status: absent INFO : 18.08.2018 15:49:36 > Codename: zerofltexx INFO : 18.08.2018 15:49:36 > Checking Root: INFO : 18.08.2018 15:49:36 > Phone is Rooted. INFO : 18.08.2018 15:49:36 > Reading security backup, please wait... INFO : 18.08.2018 15:50:09 > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G920F-RF8G4027FFY-18-08-2018_15-49-35-.asec file INFO : 18.08.2018 15:50:09 > Initializing exploit... INFO : 18.08.2018 15:50:23 > OK INFO : 18.08.2018 15:50:32 > Executing exploit... ERROR : 18.08.2018 15:51:08 > Executing exploit failed INFO : 18.08.2018 15:51:08 > Initializing exploit... INFO : 18.08.2018 15:51:31 > Executing exploit... INFO : 18.08.2018 15:52:30 > Exploit has been executed successfully INFO : 18.08.2018 15:52:33 > New IMEI: 357932004106764 INFO : 18.08.2018 15:52:33 > Writing new phone IMEI... WARN : 18.08.2018 15:53:04 > Please make "Repair Network" operation after reboot! INFO : 18.08.2018 15:53:04 > IMEI successfully repaired. INFO : 18.08.2018 15:53:13 > Performed by 2.7.0.3 Software version. INFO : 18.08.2018 15:53:52 > ----------------------------------------------------------------------------------- INFO : 18.08.2018 15:53:53 > Platform: Samsung Android INFO : 18.08.2018 15:53:53 > Selected port: COM1 INFO : 18.08.2018 15:53:53 > Selected model: SM-G920F INFO : 18.08.2018 15:53:53 > Operation: Repair Network INFO : 18.08.2018 15:53:54 > Detected phone model: SM-G920F INFO : 18.08.2018 15:53:55 > Firmware compiled date: Mon Mar 12 17:04:20 KST 2018 INFO : 18.08.2018 15:53:55 > PDA version: G920FXXU6ERC9 INFO : 18.08.2018 15:53:55 > CSC version: G920FVFG6ERCA INFO : 18.08.2018 15:53:55 > SW version: G920FXXU6ERC9 INFO : 18.08.2018 15:53:55 > Phone SN: RF8G4027FFY INFO : 18.08.2018 15:53:55 > Android version: 7.0 (NRD90M) INFO : 18.08.2018 15:53:55 > Sales code: VD2 INFO : 18.08.2018 15:53:55 > Country: Germany INFO : 18.08.2018 15:53:55 > HW platform: exynos5 INFO : 18.08.2018 15:53:55 > HW Chip: exynos7420 INFO : 18.08.2018 15:53:55 > HW Modem: SHANNON333 INFO : 18.08.2018 15:53:55 > Security patch level: 2018-03-01 INFO : 18.08.2018 15:53:55 > Warranty Void: 1 INFO : 18.08.2018 15:53:55 > SIM 1 status: absent INFO : 18.08.2018 15:53:55 > Codename: zerofltexx INFO : 18.08.2018 15:53:55 > Checking Root: INFO : 18.08.2018 15:53:56 > Phone is Rooted. INFO : 18.08.2018 15:53:56 > Initializing exploit... INFO : 18.08.2018 15:54:22 > Executing exploit... INFO : 18.08.2018 15:54:29 > Repairing network... ERROR : 18.08.2018 15:56:03 > Repairing network failed. INFO : 18.08.2018 15:56:03 > Performed by 2.7.0.3 Software version. INFO : 18.08.2018 15:57:06 > ----------------------------------------------------------------------------------- INFO : 18.08.2018 15:57:07 > Platform: Samsung Android INFO : 18.08.2018 15:57:07 > Selected port: COM1 INFO : 18.08.2018 15:57:07 > Selected model: SM-G920F INFO : 18.08.2018 15:57:07 > Operation: Repair Network INFO : 18.08.2018 15:57:08 > Detected phone model: SM-G920F INFO : 18.08.2018 15:57:08 > Firmware compiled date: Mon Mar 12 17:04:20 KST 2018 INFO : 18.08.2018 15:57:08 > PDA version: G920FXXU6ERC9 INFO : 18.08.2018 15:57:08 > CSC version: G920FVFG6ERCA INFO : 18.08.2018 15:57:08 > SW version: G920FXXU6ERC9 INFO : 18.08.2018 15:57:09 > Phone SN: RF8G4027FFY INFO : 18.08.2018 15:57:09 > Android version: 7.0 (NRD90M) INFO : 18.08.2018 15:57:09 > Sales code: VD2 INFO : 18.08.2018 15:57:09 > Country: Germany INFO : 18.08.2018 15:57:09 > HW platform: exynos5 INFO : 18.08.2018 15:57:09 > HW Chip: exynos7420 INFO : 18.08.2018 15:57:09 > HW Modem: SHANNON333 INFO : 18.08.2018 15:57:09 > Security patch level: 2018-03-01 INFO : 18.08.2018 15:57:09 > Warranty Void: 1 INFO : 18.08.2018 15:57:09 > SIM 1 status: absent INFO : 18.08.2018 15:57:09 > Codename: zerofltexx INFO : 18.08.2018 15:57:09 > Checking Root: INFO : 18.08.2018 15:57:10 > Phone is Rooted. INFO : 18.08.2018 15:57:10 > Initializing exploit... INFO : 18.08.2018 15:57:35 > Executing exploit... INFO : 18.08.2018 15:57:42 > Repairing network... ERROR : 18.08.2018 15:59:51 > Repairing network failed. INFO : 18.08.2018 15:59:53 > Performed by 2.7.0.3 Software version. Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\18-08-2018_15-46-58.log" closed (18.08.2018 16:00:08). |
09-16-2018, 14:41 | #743 (permalink) |
Junior Member Join Date: Aug 2016 Location: dahranwala. distt bahawalnager
Member: 2608611 Status: Offline Thanks Meter: 5 | download firmware via torrent is off.in our area always network problem.so file is damaged.kindly do some thing for that.if there are any charges i will pay for that |
09-24-2018, 07:19 | #746 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
Try to use Software version 2.7.1.5 (https://octoplusbox.com/en/download/software/) and perform "Read Codes" operation on your SM-A605G. Post the result. | |
10-24-2018, 01:33 | #749 (permalink) |
Insane Poster Join Date: Dec 2012 Location: Colombia
Member: 1858778 Status: Offline Thanks Meter: 32 | Please add FRP Reset for Samsung G930F Android 8.0, Binary 3, tried to flash full COMBINATION, stuck on Bootloader Exception error, tried flashing only "sboot" and/or "boot.img", doestn works, same error. Thanks guys |
