01-07-2017, 15:07 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: india
Member: 2035093 Status: Offline Sonork: 100-1577177 Thanks Meter: 100 | please help allumts sir [Solved] Selected firmware file: A510FXXS3BPL5_A510FOJV3BPK1 _A510FXXU3BPK2_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. Last edited by Octopus box; 01-09-2017 at 10:34. |
01-08-2017, 05:24 | #3 (permalink) |
Member: 2035093 Status: Offline Sonork: 100-1577177 Thanks Meter: 100 | hello sir,flashing befor henset is frp lock problum. i am tray to frp reset option but hend set is blink, iam tray full flash but hend set not solution. |
01-08-2017, 08:09 | #6 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | bro do this find cobination file of a510 in support Quote:
01-08-2017, 09:18 | #7 (permalink) |
Member: 2035093 Status: Offline Sonork: 100-1577177 Thanks Meter: 100 | i am try only boot image wright but not solution, any idea.Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A510F Connecting to server... Could not connect to the server! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Boot section... Boot section has been written successfully. Searching for a phone (waiting for ADB device)...timeout Phone not found. Operation was failed! Performed by 2.4.7 Software version. Selected firmware file: A510FXXS3BPL5_A510FOJV3BPK1 _A510FXXU3BPK2_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A510F Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-A510F Searching for a phone (waiting for ADB device)...timeout Phone not found. Operation was failed! Performed by 2.4.7 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Performed by 2.4.7 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Performed by 2.4.7 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Performed by 2.4.7 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Performed by 2.4.7 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Performed by 2.4.7 Software version. -------------------------------------------------------------------------------------- Selected interface: USB Searching for device. Please wait... Waiting for device... Device was not found! Operation was cancelled! Performed by 2.4.7 Software version. Selected firmware file: combination_a510f_a510fxxu2apg1_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Selected firmware file: A510FXXS3BPL5_A510FOJV3BPK1 _A510FXXU3BPK2_HOME.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. Selected firmware file: combination_a510f_a510fxxu2apg1_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing Firmware Failed Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing Firmware Failed Performed by 2.4.7 Software version. |
01-08-2017, 09:24 | #8 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,804 | bro reflash phone with original stock firmware then when u flash combintaion firmawre tick advanced mode and select Write only "boot.img" of Combination firmware |
01-09-2017, 05:08 | #9 (permalink) |
Member: 2035093 Status: Offline Sonork: 100-1577177 Thanks Meter: 100 | thank you very much prokefah sir my prolum frp lock solution is ok,thank very much you are sugestion.thank--------- thank------------ thank----------- you. |
The Following User Says Thank You to mukesh kumar ch For This Useful Post: |
