01-20-2018, 19:16 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 600846 Status: Offline Thanks Meter: 2 | Please help me to re-flash SM-G950u unlocked Last edited by Octopus box; 01-22-2018 at 08:54. |
01-20-2018, 21:33 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Flash binary rev 2 not binary 1 firmware or combination IF YOU LIKE WHAT I POST PRESS THANKS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
01-21-2018, 18:58 | #5 (permalink) |
Member: 600846 Status: Offline Thanks Meter: 2 | The following is the problem that still have after flashing g950u1 on my unlock boost mobile phone, BTW I soft bricked the phone and I was able to get it back but Im stock on the security patch of december 2017. I just want to unlock this model, dont care if I have to keep G950u1 firmware as long is unlocked, The following is what I have from octopus... Welcome to Octoplus Box Samsung software version 2.6.3 ----------------------------------------------------------------------------------- To connect SM-G930P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G930P Please, press "OK" button on the phone to allow USB debugging. Warning: Selected model (SM-G930P) differs from the detected one (SM- G950U1)! If you want select (SM-G950U1) as (SM-G930P) model, please check "manual select". Can't detect android kernel version. Phone unlocking failed Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-G930P Detected phone model: SM-G950U1 Firmware compiled date: Tue Dec 5 14:27:19 KST 2017 PDA version: G950U1UES2AQL1 CSC version: G950U1OYM2AQL1 SW version: G950U1UES2AQL1 Phone SN: R28J81RM6DK Android version: 7.0 (NRD90M) Sales code: XAA Country: USA HW platform: msm8998 HW Chip: MSM8998 HW Modem: MSM8998 Security patch level: 2017-12-01 SIM 1 status: ready Codename: dreamqlteue Checking Root: Phone is not Rooted. Installing service app... Unlocking phone... Finalizing... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- To connect SM-G935P phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected BOOT file: C:\Users\Gateway\Desktop\BL_SAMPWND_S8 _PLUS.tar Please put the phone into Download Mode and connect USB cable. To put SM-G935P into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABL section... ABL section has been written successfully. Writing Firmware Failed Performed by 2.6.3 Software version. Selected AP file: C:\Users\Gateway\Desktop\s8\COMBINATION_FA70 _G950USQU1AQCF_CL11021239_QB13008157_REV00 _user_mid_noship_MULTI_CERT.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G935P into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BKSECAPP section... BKSECAPP section has been written successfully. Writing XBL section... XBL section has been written successfully. Writing Firmware Failed Performed by 2.6.3 Software version. Selected AP file: C:\Users\Gateway\Desktop\s8\CF-Auto-Root- dreamqltesq-dreamqltesq-smg950u.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G935P into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Writing Firmware Failed Performed by 2.6.3 Software version. Selected AP file: C:\Users\Gateway\Desktop\s8\ENG_ROOT_G950U.tar Please put the phone into Download Mode and connect USB cable. To put SM-G935P into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing ABL section... ABL section has been written successfully. Writing Firmware Failed Performed by 2.6.3 Software version. No register on network or emergency calls, THanks |
01-21-2018, 19:39 | #7 (permalink) |
Member: 600846 Status: Offline Thanks Meter: 2 | Thanks for your help, whats the combination u2 ? just google it like that, I know sometimes is frustrating for you guys with more experience trying to tell us something that we should know, but the only way I will learn os by asking . thanks for all your help |
01-21-2018, 19:43 | #8 (permalink) | |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
IF YOU LIKE WHAT I POST PRESS THANKS BUTTON | |
