01-25-2015, 08:57 | #1 (permalink) |
Major Poster Join Date: Dec 2013
Member: 2087773 Status: Offline Thanks Meter: 11 | Please help me with GT-I9515 [Solved] ----------------------------------------------------------------------------------- To connect GT-I9515 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM175 Selected model: GT-I9515 Detected phone model: GT-I9515 Firmware compiled date: Wed Mar 5 21:20:18 KST 2014 PDA version: I9515XXU1ANC2 CSC version: I9515OJV1AND1 SW version: I9515XXU1ANC2 Phone IMEI: 355847060309429 Phone SN: R58F815R5GE Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! Phone was not found on the selected port! i try on 2 pc Last edited by Octopus box; 01-25-2015 at 11:46. |
01-25-2015, 10:53 | #2 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To connect (to configure) the phone, perform steps 1-14 from the Software log above. Instead of steps 11 and 12: Quote:
01-25-2015, 11:42 | #3 (permalink) |
Member: 2087773 Status: Offline Thanks Meter: 11 | I do the next steps: Quote: 11. Enter "*#9090#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. Write here the result. Welcome to Octoplus/Octopus Box Samsung software version 1.8.2 ----------------------------------------------------------------------------------- To connect GT-I9515 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM175 Selected model: GT-I9515 Detected phone model: GT-I9515 Firmware compiled date: Wed Mar 5 21:20:18 KST 2014 PDA version: I9515XXU1ANC2 CSC version: Unknown SW version: I9515XXU1ANC2 Phone IMEI: 355847060309429 Phone SN: R58F815R5GE Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Mar 5 2014 Firmware released time: 22:03:35 SW Version: M9615A-CEFWTAZM-4.0.17135 Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\QCN-GT-I9515-355847060309429-25-01-2015_17-13- 10-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9515-355847060309429-25-01-2015_17-20- 09-.asec file Wiping EFS... EFS wipe successfully Phone will restart now. Please don't disconnect cable! Searching for a phone. Please wait... Reading info... Mode: Normal Firmware compiled date: Dec 24 2013 Firmware compiled time: 00:00:00 Firmware released date: Mar 5 2014 Firmware released time: 22:03:35 SW Version: M9615A-CEFWTAZM-4.0.17135 Send SPC... SPC send successfully Writing QCN... Writing NV items... NV items write successfully Writing NV SIM1 items... NV SIM1 items write successfully Writing NV SIM2 items... NV SIM2 items write successfully Wrting EFS... EFS write successfully Writing provisioning items... Provisioning items write successfully. Writing QCN done Wipe security successfully complete. Phone will restart now. Please don't disconnect cable! ----------------------------------------------------------------------------------- ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM175 Selected model: GT-I9515 Selected file: C:\Program Files\Octoplus\Octoplus_Samsung\i9515\cert- gt-i9515_352168062519086_rf8f7069gkw.cert Detected phone model: GT-I9515 Firmware compiled date: Wed Mar 5 21:20:18 KST 2014 PDA version: I9515XXU1ANC2 CSC version: I9515OJV1AND1 SW version: I9515XXU1ANC2 Phone IMEI: Unknown Phone SN: R58F815R5GE Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- very big thanks sir,... |
