10-25-2014, 00:15 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | It seems lik yur modem part is damaged . 1st try to fix yur unkwn baseband by flashing latest build firmwares if baseband is unknown yu can not repair imei. After flash firmware if imei null must b hardware issue . Sent from my SM-G900F using Tapatalk |
10-25-2014, 00:59 | #4 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | 1st flash vit latest at&t n900a firmware and check . imei null and baseband uknown issues are cause by wrong firmware flashing and hardware issues . Sent from my SM-G900F using Tapatalk |
10-25-2014, 07:21 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ thejmf Try to do the next: 1. Install the latest Software version (Software). 2. Re-flash the phone with the latest firmware from the Support Area. 3. Make Factory data reset and wipe cache partition. 4. Root the phone. 5. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 6. Write QCN file. 7. Write Certificate ("Write cert" button). 8. Write here the result. Also, please check your PM, we have sent to You several Cert files and QCN for You. |
10-26-2014, 23:51 | #6 (permalink) |
Insane Poster Join Date: Oct 2014
Member: 2279699 Status: Offline Thanks Meter: 41 | I did it but i cant make the repair security/wipe security 1. Install the latest Software version (Software). 2. Re-flash the phone with the latest firmware from the Support Area. 3. Make Factory data reset and wipe cache partition. 4. Root the phone. 5. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). Plataforma: Samsung Android Puerto seleccionado: COM11 Modelo seleccionado: SM-N900A Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Modelo del teléfono detectado: SM-N900A Fecha de creación del firmware: Sat Jan 4 19:10:49 KST 2014 PDA version: N900AUCUCMLG CSC version: N900AATTCMLG Versión del SW: Unknown IMEI del teléfono: Unknown Android version: 4.4.2 (KOT49H) Reading info... ¡En el puerto seleccionado el teléfono no fue detectado! What can I do? thank in advance |
10-27-2014, 07:34 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | As You can see from your Software log, phone's modem part is damaged: Quote:
At first, You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then perfrom steps 3-8. | |
12-14-2014, 18:29 | #8 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Honduras-Comayagua Age: 35
Member: 1163489 Status: Offline Thanks Meter: 23 | Welcome to Octoplus/Octopus Box Samsung software version 1.7.7 ----------------------------------------------------------------------------------- To connect SM-N900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SM-N900A Port is busy Phone was not found on the selected port! Searching for USB diagnostic port... No diagnostic ports found! Connecting to phone on COM9 Phone connection failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM47 Selected model: SM-N900A ADB server killed. Detected phone model: SM-N900A Firmware compiled date: Sat Mar 15 17:48:27 KST 2014 PDA version: N900AUCUCNC2 CSC version: N900AATTCNC2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM47 Selected model: SM-N900A ADB server killed. Detected phone model: SM-N900A Firmware compiled date: Sat Mar 15 17:48:27 KST 2014 PDA version: N900AUCUCNC2 CSC version: N900AATTCNC2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM46 Selected model: SM-N900A Detected phone model: SM-N900A Firmware compiled date: Sat Mar 15 17:48:27 KST 2014 PDA version: N900AUCUCNC2 CSC version: N900AATTCNC2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Reading info... Phone was not found on the selected port! somebody know how to repair the modem hardware issue ?? |
12-14-2014, 19:21 | #9 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | Quote:
thx | |
12-14-2014, 19:36 | #10 (permalink) | ||
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ yordan Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). | ||
