01-12-2014, 03:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: venezula, maracaibo
Member: 991599 Status: Offline Thanks Meter: 85 | Please help with my octoplus box uart problem [Solved] my box does not detect any phone via UART all drivers are installed please help with my problem Last edited by Octopus box; 02-10-2017 at 10:39. |
01-12-2014, 10:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. There can be three reasons of this problem: 1. Box has HW problem (problem with UART connector or other HW problems). 2. Problem with Samsung Micro UART cable (try to use another cable to be sure, that the cable is OK). 3. Problem with phone's or Software's settings (You have not correctly performed all of phone's settings before connecting the device or selected incorrect COM port in Software). |
05-25-2014, 19:00 | #3 (permalink) |
Junior Member Join Date: Sep 2013 Location: USA
Member: 2032466 Status: Offline Thanks Meter: 1 | Same issue I can't seem to get my N900T connected via UART to my Octoplus box. I have been reading every forum thread but nothing works. I've installed the drivers, used about 8 different C3300k 530kOhm cables. I've only clicked OK when the phone is connected to the UART via the box. Are we suppose to change PDA to modem? I'm trying to narrow it down. Creating NVM backup Reading NVM done! Connecting to ADB, please waite... ADB server killed. Firmware compiled date: Fri Sep 13 23:52:13 KST 2013 PDA version: N900TUVUBMI7 CSC version: N900TTMBBMI7 SW version: N900TUVUBMI7 Phone IMEI: Unknown Phone SN: ************* Android version: 4.3 (JSS15J) Cheking Root Erasing old IMEI. It can take some time. Please wait... Reading security backup, please wait... Backup saved as ********* Phone will restart now. Please don't disconnect cable! After phone being rebooted and powered on perform the following steps: 1. Disconnect USB cable. 2. Wait for 1-2 minutes. 3. Connect phone via UART cable to the Box. Serching phone... |
05-26-2014, 07:08 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Why IMEI in your device is "Unknown"?: Quote:
05-26-2014, 07:21 | #5 (permalink) |
No Life Poster Join Date: Oct 2006 Location: ..::Johannesburg::.. Age: 37
Member: 380464 Status: Offline Thanks Meter: 141 | same this my box uart cable not work ithink hw problem in box .................. |
The Following User Says Thank You to ..:::Gsm india:::.. For This Useful Post: |
05-28-2014, 00:25 | #6 (permalink) | |
Member: 2032466 Status: Offline Thanks Meter: 1 | Drivers - Unknown - Multi-Selector Cable Quote:
I attempted to flash the 4.3 and then even flashed 4.4. I've been able to successfully root each version. It just hangs that that same point. I have tried my Z3X box but it doesn't register as well. What should I see in the Driver Manager? I see a Samsung COM port if my phone is plugged in otherwise with just the box plugged in I see "USB Serial PORT (COM8)". All my drivers seem to be fine except for "MDSJ" under Other Devices. I'd include a screenshot but I don't have enough posts to do so. Also my phone says Unknown because after it reset the IMEI and was unsuccessful it has said Unknown. I have attempted this on two N900T Note 3's. What suggestions do you have? I have purchased the multi-selector UART cable and am waiting for it in the mail. Thank you for your help. | |
05-28-2014, 06:30 | #7 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Quote:
06-08-2014, 05:03 | #8 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Brazil Age: 30
Member: 1963068 Status: Offline Sonork: amauri.tec Thanks Meter: 81 | Staff found the solution to this problem .. First download the drivers from FTDI edited specifically for OCTOPLUS: http://www.4shared.com/rar/SWtFXMWJc...plus_Uart.html First run FTClean file to clean all FTDI drivers pc, restart the pc and update the drivers Usb Serial Converter (found in USB controllers category (universal serial bus)) and Drive Usb Serial Port (COM and LPT ports) with the link. Last edited by Octopus box; 06-08-2014 at 08:46. |
06-08-2014, 16:32 | #9 (permalink) | |
Freak Poster Join Date: Feb 2014
Member: 2127241 Status: Offline Thanks Meter: 7 | work? Does that solution work? The driver install and all? Can anyone give approval Quote:
03-10-2016, 06:21 | #10 (permalink) |
Crazy Poster Join Date: Dec 2007
Member: 641627 Status: Offline Thanks Meter: 3 | Platform: Samsung Android Selected port: COM3 Selected model: SM-G850F Selected file: C:\Users\umar zaini\Desktop\sert 850f\Cert-SM-G850F- RF8FA0KBQA-355210062690603.cert Detected phone model: SM-G850F Firmware compiled date: Wed Sep 2 13:14:34 KST 2015 PDA version: G850FXXU2COI1 CSC version: G850FOJPCOI1 SW version: G850FXXU1COI1 Phone SN: RF8FA0KBQAK Android version: 5.0.2 (LRX22G) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-G850F-Unknown10-03-2016_10-37-48-.asec file Phone will restart now. Please don't disconnect cable! Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed Performed by 2.2.1 software version Last edited by fairooos; 03-10-2016 at 06:23. Reason: check for 5 UART cable same result |
03-10-2016, 13:43 | #11 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | In order to connect the phone via UART, You need to block highlighted pin with a tape/paper and use Samsung C3300k/C3303k micro UART cable with 525-530kOm resistor for connection. |
The Following 2 Users Say Thank You to Octopus box For This Useful Post: |
03-15-2016, 21:24 | #12 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Mexico
Member: 1547027 Status: Offline Thanks Meter: 42 | i have the same problem, i think it may be a problem with the latest updates, test it on two different computers and two octopus boxes, i had a note 2 and had to install version 1.6.8 and it work, please fix this problem |
The Following User Says Thank You to elmaniatiko For This Useful Post: |
