05-11-2016, 10:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Please help to reset FRP SM G361F [Solved] Please help to reset FRP lock for G361F Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- To connect SM-G530F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM176 Selected model: GT-S7390G Connecting to phone on COM176 Phone connection failed Connecting to phone on COM177 Detected phone model: GT-S7390G ADB server killed. Proper android device not found. Make shure that "USB debug" option on the device is turned on. Detected phone model: GT-S7390G SW version: S7390GXXUAOB1/S7390GFTMAOB1/S7390GXXUAOB1/S7390GXXUA OB1 HW Version: GT-S7390MKFFTM Phone IMEI A: 352905-06-825690-2 Proper android device not found. Make shure that "USB debug" option on the device is turned on. Phone connection failed Phone was not found on the selected port! Performed by 2.2.5 software version ----------------------------------------------------------------------------------- Platform: Samsung Broadcom Selected port: COM177 Selected model: GT-S7390G Detected phone model: GT-S7390G SW version: S7390GXXUAOB1/S7390GFTMAOB1/S7390GXXUAOB1/S7390GXXUA OB1 HW Version: GT-S7390MKFFTM Phone IMEI A: 352905-06-825690-2 Firmware compiled date: Thu Jan 29 12:37:13 KST 2015 Phone SN: R21F93CPQCD Android version: 4.1.2 (JZO54K) Reading phone unlock codes. It can take some time, please wait... Connecting to server... Connect successfully to server. Checking smart card... Smart card successfully checked. Checking operation... Operation successfully checked. Freeze unlock code: 81638418 NCK unlock code: 20914936 NSCK unlock code: 00000000 SPCK unlock code: 00000000 CPCK unlock code: 00000000 MultiCK unlock code: 00000000 Performed by 2.2.5 software version ----------------------------------------------------------------------------------- To connect SM-G530F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Restart phone. 11. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM177 Selected model: SM-G361F To put SM-G361F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Operation was failed! Performed by 2.2.5 software version Last edited by Octopus box; 05-12-2016 at 14:23. |
05-11-2016, 11:03 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Problem with reset of FRP lock can occur if phone has latest firmware. Samsung disabled ability to remove FRP lock in latest firmwares. You can try to reflash the phone with older (by release date) firmware, then repeat "Reset FRP/Reactivation/EE" operation. |
05-11-2016, 13:55 | #5 (permalink) | |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Quote:
Code: Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 Selected firmware file: G361FXXU1AOG1_G361FDHX1AOG2 _G361FXXU1AOGD_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-G361F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Found phone on Firmware write started. Writing SBOOT section... SBOOT section has been written successfully. Writing SBOOT2 section... SBOOT2 section has been written successfully. Writing LOKE2ND section... LOKE2ND section has been written successfully. Writing LOKE1ST section... LOKE1ST section has been written successfully. Writing KERNEL section... KERNEL section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing Firmware Failed Performed by 2.2.5 software version | |
05-11-2016, 14:04 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to perform "Reset FRP/Reactivation/EE" operation after this attempt to write a firmware. If problem will remain - try to write another firmware and perform "Reset FRP/Reactivation/EE" operation again, disregard the result of writing of a firmware. |
05-12-2016, 13:16 | #7 (permalink) | |
problem solved wiyh your help Welcome to Octoplus/Octopus Box Samsung software version 2.2.5 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM49 Selected model: SM-G361F To put SM-G361F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" +"Power"+''Home" keys. Searching for a phone. Please wait... Phone found. Initializing.. Resetting FRP lock..success Resetting EE lock..success Resetting Samsung Account lock..not supported Reset operation completed! Performed by 2.2.5 software version | |
The Following User Says Thank You to said4 For This Useful Post: |
