09-25-2014, 02:15 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Melbourne Aussy
Member: 192176 Status: Offline Sonork: 100.1646924 Thanks Meter: 35 | Please Help Samsung SM-N900 always stuck in SYSTEM ----------------------------------------------------------------------------------- To connect SHV-E160S phone you have to perform the following steps: 1. Go to dial window. 2. Enter "319712358" number. 3. Enter "996412" password. 4. Go to System->SIO mode. 5. Select "Modem" radio button for USB section. 6. Go to dial window. 7. Enter "*#9090#" number. 8. Set "Diag config" to "USB" value. 9. Restart phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: N900XXUDNA6_N900OLBDNA2 _XSE_Indonesia_Android_4.4.2.oct Please switch your phone to the download mode and connect it to a PC. To put SM-N900 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... Writing Firmware Failed i try with other firmware always stuck in proces write system?now phone only stuck in logo samsung |
09-25-2014, 07:09 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Fully charge phone's battery by using external charger and try to write firmware again. Try to write other firmwares. Try to write firmwares on another PC. Connect the phone directly to PC motherboard USB port, don't use any USB hubs or USB PCI extention cards, this is important. If the problem is the same - check HW. |
