11-21-2014, 17:38 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | please how will I root s4 (sgh-i337) android 4.4.2 [Solved] Last edited by Octopus box; 11-22-2014 at 11:08. |
11-21-2014, 18:31 | #3 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
it didnt work or am I making mistakes? for the recommended one on the software am having this error below [*][*] Motochopper: Android root exploit (Windows version)[*] v1.1[*] by Dan Rosenberg (@djrbliss)[*][*] Tested on the Motorola Razr HD, Razr M, Razr Maxx HD, and Atrix HD.[*] Supports lots of other devices as well. ;-)[*][*] Before continuing, ensure that USB debugging is enabled, that you[*] have the latest USB drivers installed, and that your phone[*] is connected via USB.[*][*] WARNING: This will likely void the warranty on your device. I am[*] not responsible for any damage to your phone as a result using this[*] tool.[*][*] Press enter to root your phone... Press any key to continue . . .[*][*] Waiting for device... * daemon not running. starting it now on port 5037 * * daemon started successfully *[*] Device found.[*] Pushing exploit... 2496 KB/s (1283460 bytes in 0.502s)[*] Pushing root tools... 2421 KB/s (366952 bytes in 0.148s) 2730 KB/s (1867568 bytes in 0.668s) 3224 KB/s (1578585 bytes in 0.478s) pkg: /data/local/tmp/Superuser.apk Failure [INSTALL_FAILED_ALREADY_EXISTS][*] Rooting phone... [+] This may take a few minutes. [-] Failure.[*] Cleaning up...[*] Exploit complete. Press enter to reboot and exit. Press any key to continue . . . | |
11-21-2014, 20:20 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Recommended root was compatible with older versions of Android, we have not tested it for 4.4.2. Try to root the phone with Towelroot, then download SuperSU application from Play Market. Open SuperSU (update SU binary, disable KNOX if will be prompted) and Enable Superuser on "Settings" tab of the application. |
11-22-2014, 06:37 | #5 (permalink) | |
It coould'nt disable KNOX and always says "failed to disable KNOX!" please could it be the version of the superSU is low or what? I get the superSU from here => SuperSU Download somebody help and check to know whether is from the version? | |
11-22-2014, 08:27 | #8 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | try here bro ,i tested it work well How to Root AT&T/Verizon Galaxy S4 and S4 Active on Android 4.4.2! | GalaxyS4Root.com |
11-22-2014, 11:01 | #9 (permalink) | |
Thanks but before you shared it I have seen it and I was about to share it and see that you have share it. Thanks all, it worked here How to Root AT&T/Verizon Galaxy S4 and S4 Active on Android 4.4.2! | GalaxyS4Root.com! | |
