10-10-2018, 12:18 | #1 (permalink) |
Insane Poster Join Date: Aug 2010 Location: Bulgaria , Burgas Age: 50
Member: 1357771 Status: Offline Thanks Meter: 39 | Please I need S7 SM-G930F S3 Combination for FRP [Solved] Please I need S7 SM-G930F S3 Combination for FRP. I can not find old sboot from september 20, 2018. firmware G930FXXS3ERI1. any ideas ? Thanks. Last edited by Octopus box; 10-11-2018 at 09:10. Reason: add firmware info |
10-10-2018, 14:18 | #6 (permalink) |
Member: 1357771 Status: Offline Thanks Meter: 39 | not ok Welcome to Octoplus Box Samsung software version 2.7.3 ----------------------------------------------------------------------------------- To connect SM-G930F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected AP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \COMBINATION_FA60_G930FXXU3ARI2_CL7964511_QB196355 01 _REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOT section... BOOT section has been written successfully. Firmware writing successfully completed. Performed by 2.7.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G930F Operation: Reset FRP - ADB Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 2.7.3 Software version. Selected AP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \COMBINATION_FA60_G930FXXU3ARI2_CL7964511_QB196355 01 _REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Firmware writing successfully completed. Performed by 2.7.3 Software version. |
10-10-2018, 19:14 | #7 (permalink) |
Member: 1357771 Status: Offline Thanks Meter: 39 | After flash 1. After flash only boot = logo only, no adb 2. Full flash combination= Bootloader exception /rst_stat = 0x20000000/ Now with original soft with frp. Help from support ? |
10-11-2018, 05:15 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | @ MEF1 Please read attentively Software manual on how to reset FRP using Combination firmware and perform all steps written in there. Also please http://forum.gsmhosting.com/vbb/f103...wares-2336370/. |
10-11-2018, 08:04 | #11 (permalink) | |
Member: 1357771 Status: Offline Thanks Meter: 39 | log Quote:
Welcome to Octoplus Box Samsung software version 2.7.3 ----------------------------------------------------------------------------------- To connect SM-G930F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected AP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \COMBINATION_FA60_G930FXXU3ARI2_CL7964511_QB196355 01 _REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.7.3 Software version. Selected BOOT file: C:\Users\SERVICE CENTER\Desktop\930f S3 \BL_G930FXXS3ERI1_CL13895453_QB19639589_REV00 _user_low_ship.tar.md5 Selected AP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \AP_G930FXXS3ERI1_CL13895453_QB19639589_REV00 _user_low_ship_meta.tar.md5 Selected CP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \CP_G930FXXU3ERI1_CL878338_QB10686407_SIGNED.tar.m d5 Selected CSC file: C:\Users\SERVICE CENTER\Desktop\930f S3 \HOME_CSC_VFG_G930FVFG3ERI1_CL14094620_QB19715687 _REV00_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing PARAM section... PARAM section has been written successfully. Writing CM section... CM section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing Firmware Failed Performed by 2.7.3 Software version. Selected BOOT file: C:\Users\SERVICE CENTER\Desktop\930f S3 \BL_G930FXXS3ERI1_CL13895453_QB19639589_REV00 _user_low_ship.tar.md5 Selected AP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \AP_G930FXXS3ERI1_CL13895453_QB19639589_REV00 _user_low_ship_meta.tar.md5 Selected CP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \CP_G930FXXU3ERI1_CL878338_QB10686407_SIGNED.tar.m d5 Selected CSC file: C:\Users\SERVICE CENTER\Desktop\930f S3 \HOME_CSC_VFG_G930FVFG3ERI1_CL14094620_QB19715687 _REV00_user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.7.3 Software version. | |
10-11-2018, 08:31 | #14 (permalink) |
Member: 1357771 Status: Offline Thanks Meter: 39 | Frp off Selected AP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \COMBINATION_FA60_G930FXXU3ARI2_CL7964511_QB196355 01 _REV00_user_mid_noship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.7.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-G930F Operation: Reset FRP - UART UFS Please put the phone into Download Mode and connect USB cable. Waiting for phone... Reading PIT... PIT was read successfully. Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Checking operation...OK Resetting FRP lock.. FRP / Reactivation lock is successfully reseted! Performed by 2.7.3 Software version. Selected BOOT file: C:\Users\SERVICE CENTER\Desktop\930f S3 \BL_G930FXXS3ERI1_CL13895453_QB19639589_REV00 _user_low_ship.tar.md5 Selected AP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \AP_G930FXXS3ERI1_CL13895453_QB19639589_REV00 _user_low_ship_meta.tar.md5 Selected CP file: C:\Users\SERVICE CENTER\Desktop\930f S3 \CP_G930FXXU3ERI1_CL878338_QB10686407_SIGNED.tar.m d5 Selected CSC file: C:\Users\SERVICE CENTER\Desktop\930f S3 \CSC_VFG_G930FVFG3ERI1_CL14094620_QB19715687_REV00 _user_low_ship.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-G930F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Firmware writing successfully completed. Performed by 2.7.3 Software version. Thanks ! |
03-08-2019, 14:09 | #15 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2799425 Status: Offline Thanks Meter: 1 | I HAVE THE SAME PROBLEM MY FIRMWARE IS g930F..XXXS3 . S3 im wndering is the combinationfile that fits with this stockrom is U3 ????' HELP ME FIGURE THAT OUT IF SO ANYONE HAVE u3 COMBINATION FOR G930F please |
