09-27-2014, 08:08 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: bannu
Member: 1508215 Status: Offline Thanks Meter: 47 | plz help me n7100 imei and baseband null ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM76 Selected model: GT-N7100 Reading info, please wait... Detected phone model: GT-N7100 Firmware compiled date: Wed Apr 9 02:52:29 KST 2014 PDA version: N7100XXUFND3 CSC version: N7100ODDFND2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM76 Selected model: GT-N7100 Detected phone model: GT-N7100 Firmware compiled date: Wed Apr 9 02:52:29 KST 2014 PDA version: N7100XXUFND3 CSC version: N7100ODDFND2 SW version: Unknown Phone IMEI: Unknown Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-N7100-Unknown27-09-2014_11-59-01-.asec file Cheking security type... Old security type is detected Old IMEI: Unknown New IMEI: 356755-46-345365-3 Repairing IMEI ... Executing exploit... Exploit has been executed successfully Unknown security Write IMEI failed |
09-27-2014, 08:09 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. As You can see from your Software log, phone's modem part is damaged: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged. If after of writing all firmwares which You have, phone's baseband is still null (SW version is Unknown) - most likely, this is HW problem (problem with eMMC flash chip). | |
09-27-2014, 08:16 | #3 (permalink) |
No Life Poster Join Date: Dec 2013 Location: FRANCE
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | first try to write default EFS, then flash with 5 file firmware....after flash if imei become 00046***** try to write original imei..... if still baseband unknown - this is Flash IC problem....change flash IC and reflash....it will fix your problem |
