04-10-2019, 12:39 | #408 (permalink) | |
Banned Join Date: Jan 2017 Location: Algeria DZ
Member: 2669781 Status: Offline Thanks Meter: 1,839 | GT-E1150I Unlock Done GT-E1150I Unlock Done Quote:
04-15-2019, 07:34 | #409 (permalink) |
Banned Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung j500fn frp reset done samsung j500fn frp reset done Welcome to Octoplus Box Samsung software version 2.7.4 ----------------------------------------------------------------------------------- To connect SM-G925T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J500FN phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM5 Selected model: SM-J500FN Operation: Reset FRP - UserData Reset FRP/ Reactivation lock operation for SM-J500FN will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J500FN into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.7.4.3 Software version. |
04-15-2019, 07:36 | #410 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung j710f frp reset done with urt cable samsung j710f frp reset done with urt cable Welcome to Octoplus Box Samsung software version 2.7.9 ----------------------------------------------------------------------------------- To connect GT-N7100 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Go to dial window. 10. Enter "*#7284#" number. 11. Set "UART" radio button to "MODEM" value. 12. Set "USB" radio button to "PDA" value 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3. Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Operation: Reset FRP - UART EMMC Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait... Upload Mode interface not found! Operation was failed! Performed by 2.7.9.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Operation: Reset FRP - UART EMMC Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..unsuccessful Searching for UART interface.. COM5 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (2/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 2.7.9.4 Software version. |
04-15-2019, 07:39 | #411 (permalink) |
Member: 2765424 Status: Offline Thanks Meter: 1,039 | samsung g920f frp reset done samsung g920f frp reset done PHP Code: |
04-15-2019, 08:24 | #412 (permalink) |
Freak Poster Join Date: Feb 2006 Location: B D S Age: 40
Member: 237628 Status: Offline Sonork: 100.1668254 Thanks Meter: 140 | sam-A750fn can u tell me plz Sam-A750fn bsi line conection? plz let me know or send diagram Last edited by ss.com; 04-15-2019 at 08:32. |
04-15-2019, 12:28 | #413 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | SM-A520W unlocked Welcome to Octoplus Box Samsung software version 2.7.9 (Lite) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM90 Selected model: SM-A520W Operation: Read Codes - Server Detected phone model: SM-A520W Firmware compiled date: Thu Mar 7 12:44:38 KST 2019 PDA version: A520WVLS6CSC1 CSC version: A520WOYA6CSC1 SW version: A520WVLS6CSC1 Phone SN: R58J718PPSN Android version: 8.0.0 (R16NW) Sales code: VMC Country: Canada HW platform: exynos5 HW Chip: exynos7880 HW Modem: SHANNON325 Security patch level: 2019-03-01 Warranty Void: 0 SIM 1 status: absent Codename: a5y17ltevl ----------------------------------------------------------------------------------- Connecting to server .. Username: arafathadji1 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 50 credits. ----------------------------------------------------------------------------------- Checking operation...OK Initializing...OK Rebooting phone Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Can't kill external ADB references. Please, close all programs that use ADB server.OK Please keep phone's screen active! Initializing exploit...OK Initializing...OK Reading HWID...OK Reading NV Data...OK Security checking...OK "Read Codes" operation will take 50 credits. Continue? Sending request... Calculating codes. Please wait... FREEZE: 75241315 NET LOCK: 47507183 SUB LOCK: 00000000 SP LOCK: 00000000 CP LOCK: 00000000 Performed by 2.7.9.4 (Lite) Software version. |
04-15-2019, 19:05 | #414 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 593061 Status: Offline Thanks Meter: 19 | this problem good afternoon, I had a prosses to read codes to one samsung G610M by server with 20 credits and the program don't gave me de codes and consumption the credit, the username is: u3ixr92 please reply me at this email [email protected] here the log Welcome to Octoplus Box Samsung software version 2.7.7 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM118 Selected model: SM-G610M Operation: Read Codes - Server Detected phone model: SM-G610M Firmware compiled date: Wed Nov 28 00:17:28 KST 2018 PDA version: G610MUBU3CRK2 CSC version: G610MUUB3CRK1 SW version: G610MUBU3CRK2 Phone SN: R28HA3AK1SM Android version: 8.1.0 (M1AJQ) Sales code: TPA Country: PANAMA HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2018-11-01 Warranty Void: 0 SIM 1 status: absent Codename: on7xelteub ----------------------------------------------------------------------------------- Connecting to server .. Username: u3ixr92 Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 25 credits. ----------------------------------------------------------------------------------- Checking operation...OK Rebooting phone Searching for a phone. Please wait...OK Please keep phone's screen active! Initializing exploit...OK Initializing...OK Reading HWID...OK Reading NV Data...OK Security checking...OK "Read Codes" operation will take 20 credits. Continue? Reading phone unlock codes. This can take some time, please wait... Can't find code! Performed by 2.7.7.1 Software version. |
04-16-2019, 18:07 | #415 (permalink) |
Freak Poster Join Date: Mar 2014 Location: all over the world Age: 27
Member: 2152577 Status: Offline Sonork: knowlogyman Thanks Meter: 20 | huawei fig-la1 frp fail to reset Welcome to Octoplus FRP Tool v.1.6.8.0 Platform: HUAWEI Selected model: FIG-LA1 Put the phone in FastBoot Mode: 1. Remove SD and SIM cards from the phone 2. Power phone OFF 3. Press and hold "Vol-" and insert USB cable 4. Wait until the phone enter in FastBoot Mode Searching for a phone. Please wait... Detected phone model: FIG-LA1 Phone SN: 35P4C18131002310 Phone IMEI: 865840032404736 Phone IMEI2: 865840032436746 SW version: FIG-LA1 8.0.0.144(C185) Connecting to server.. Connecting to server.. Operation was failed! Performed by 1.6.8.0 Software version. |
04-17-2019, 07:11 | #416 (permalink) |
Freak Poster Join Date: Jul 2012 Location: The Golden State Punjab, India Age: 38
Member: 1788939 Status: Offline Sonork: 100.1625853 Thanks Meter: 307 | Samsung j4 plus frp remove done Samsung SM-J415F 8.1.0 FRP Remove Done Via Pre Enabled ADB Interface With..., ..::OCTOPLUS::.. BR, INDER |
04-17-2019, 07:16 | #417 (permalink) |
Member: 1788939 Status: Offline Sonork: 100.1625853 Thanks Meter: 307 | Samsung j7 (2016) frp done Samsung SM-J710F 8.1.0 FRP Remove Done Via Pre Enabel ADB Interface With..., ..::OCTOPLUS::.. BR, INDER |
04-17-2019, 19:58 | #418 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Welcome to Octoplus Box Samsung software version 2.7.9 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM120 Selected model: SM-J106F Operation: Repair IMEI A Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J106F Firmware compiled date: Mon Jun 18 19:59:59 KST 2018 PDA version: J106FJVS0ARF2 CSC version: J106FXFV0ARC1 SW version: J106FJWU0ARB3 Phone SN: RV8KA06CP9B Android version: 6.0.1 (MMB29Q) Sales code: XFV Country: South Africa HW platform: sc8830 HW Chip: SC9830I HW Modem: SC9830i Security patch level: 2018-06-01 SIM 1 status: absent Codename: j1miniveltejv Checking Root: Phone is Rooted. Detecting security type...OK (1,4) Old IMEI A: Unknown New IMEI A: 356789075676575 Repairing IMEI. Please wait... Phone will restart now. Please don't disconnect cable! IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. Performed by 2.7.9.4 Software version. Platform: Samsung Android Selected port: COM120 Selected model: SM-J106F Operation: Repair Network Detected phone model: SM-J106F Firmware compiled date: Mon Jun 18 19:59:59 KST 2018 PDA version: J106FJVS0ARF2 CSC version: J106FXFV0ARC1 SW version: J106FJWU0ARB3 Phone SN: RV8KA06CP9B Android version: 6.0.1 (MMB29Q) Sales code: XFV Country: South Africa HW platform: sc8830 HW Chip: SC9830I HW Modem: SC9830i Security patch level: 2018-06-01 SIM 1 status: absent Codename: j1miniveltejv Checking Root: Phone is Rooted. Detecting MODEM type...OK Repairing network. Please wait, this can take some time... Phone will restart now. Please don't disconnect cable! Network is successfully repaired. Performed by 2.7.9.4 Software version. |
04-17-2019, 19:59 | #419 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Welcome to Octoplus Box Samsung software version 2.7.9 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM20 Selected model: SM-J701F Operation: Repair Network Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SM-J701F Firmware compiled date: Thu Aug 23 18:47:46 KST 2018 PDA version: J701FXXU6BRH9 CSC version: G965FOXM1BRF7 SW version: J701FXXU6BRJ2 Phone SN: RV8K70QSGVF Android version: 8.1.0 (M1AJQ) Sales code: XFA Country: SOUTH AFRICA HW platform: exynos5 HW Chip: exynos7870 HW Modem: SHANNON315 Security patch level: 2018-06-01 Warranty Void: 0 SIM 1 status: ready SIM 2 status: absent Codename: j7veltedx Checking Root: Phone is Rooted. ----------------------------------------------------------------------------------- Connecting to server .. Username: XXXXXX Connect to server successfull. Checking smart card... Smart card successfully checked. Your balance: 100 credits. Checking operation...OK ----------------------------------------------------------------------------------- Repairing network. Please wait, this can take some time...OK Searching for a phone. Please wait...OK Network will be available in 50 seconds after phone reboot! Network is successfully repaired. Performed by 2.7.9.4 Software version. |
04-18-2019, 09:15 | #420 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 661195 Status: Offline Thanks Meter: 31 | SCL24 network unlock successful successfully unlock scl24 with octopus box. To connect SM-G900A phone you have to perform the following steps: INFO : 4/18/2019 1:15:22 PM > 1. Disconnect USB cable from phone. INFO : 4/18/2019 1:15:22 PM > 2. Go to Menu->Settings->More->About Device. INFO : 4/18/2019 1:15:22 PM > 3. Tap on "Build number" 7 times to enable developer options. INFO : 4/18/2019 1:15:22 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 4/18/2019 1:15:22 PM > 5. Turn on "USB Debugging" option. INFO : 4/18/2019 1:15:22 PM > 6. Go to dial window. INFO : 4/18/2019 1:15:22 PM > 7. Enter "*#0808#" number. INFO : 4/18/2019 1:15:22 PM > 8. Select "DM+Modem+ADB". INFO : 4/18/2019 1:15:22 PM > 9. Press Home button. INFO : 4/18/2019 1:15:22 PM > 10. Restart phone. INFO : 4/18/2019 1:15:22 PM > 11. Press "Read Info" in software. INFO : 4/18/2019 1:18:31 PM > ------------------------------------------------------------------------------------------------ INFO : 4/18/2019 1:18:32 PM > Platform: Samsung Android INFO : 4/18/2019 1:18:32 PM > Selected port: COM539 INFO : 4/18/2019 1:18:32 PM > Selected model: SM-G900A INFO : 4/18/2019 1:18:32 PM > Operation: Unlock INFO : 4/18/2019 1:18:32 PM > Reading info... INFO : 4/18/2019 1:18:32 PM > Mode: Normal INFO : 4/18/2019 1:18:32 PM > Firmware compiled date: Aug 27 2015 INFO : 4/18/2019 1:18:32 PM > Firmware compiled time: 00:00:00 INFO : 4/18/2019 1:18:32 PM > Firmware released date: Jul 26 2016 INFO : 4/18/2019 1:18:32 PM > Firmware released time: 16:05:51 INFO : 4/18/2019 1:18:32 PM > SW Version: MPSS.DI.2.0.1.c2-00185-M8974AAAAANRZM-1 INFO : 4/18/2019 1:18:32 PM > Unlocking phone... INFO : 4/18/2019 1:18:32 PM > Phone is successfully unlocked WARN : 4/18/2019 1:18:32 PM > To finish the operation, please restart the phone via phone's menu. INFO : 4/18/2019 1:18:39 PM > Performed by 2.7.9.4 Software version. |
