02-23-2023, 03:15 | #946 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | a10s Starting Reset FRP (Brom mode) Selected model: SM-A107M Please connect powered-on device, or via Brom mode. If for some reason Soft Bricking doesn`t work, you will have to connect your device via Brom mode by Test Point. Searching for devices... Searching MTK device... Detected MediaTek PreLoader USB VCOM (Android) HW Chip : MT6765 HW Version : 8a00.ca00.0.0 Reconnecting... OK Reading preloader... OK Mobile Status: brom Sending bootloader info... Initializing memory flash... Initializing successfully completed Detected EMMC flash Initializing memory flash... Initializing successfully completed Getting paritions info... Reading phone model name... Restoring bootloader... Getting paritions info... Reset FRP (Brom mode) done Execution time 38 second(s) Performed by 4.0.9.2 Software version. |
The Following User Says Thank You to turca For This Useful Post: |
02-28-2023, 20:35 | #947 (permalink) | |
No Life Poster Join Date: Apr 2013 Location: PT
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Samsung Galaxy Tab Pro SM-T545 FRP done Samsung Galaxy Tab Pro SM-T545 FRP done fully Quote:
The Following User Says Thank You to Rui Romano For This Useful Post: |
03-01-2023, 18:50 | #948 (permalink) | |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Samsung A23 SM-A236B FRP Done Samsung A23 SM-A236B FRP Done Quote:
03-07-2023, 12:27 | #949 (permalink) |
No Life Poster Join Date: Dec 2005 Location: India
Member: 213808 Status: Offline Sonork: 100.1615441 Thanks Meter: 126 | Work ID: 0000000001DBAE69 Platform: Samsung Android Selected port: COM1 Selected model: SGH-T399N Operation: Read Codes - General Please, press "OK" button on the phone to allow USB debugging. Detected phone model: SGH-T399N Firmware compiled date: Fri Nov 7 11:00:40 KST 2014 PDA version: T399NUVUANK3 CSC version: T399NTMBANK3 SW version: T399NUVUANK3 Build number: UNKNOWN Phone IMEI: 358765061052961 Phone SN: RV8G50CE1HN Android version: 4.4.2 (KOT49H) Sales code: TMB Country: USA HW platform: exynos3 HW Chip: exynos3470 HW Modem: SS222 SIM 1 status: absent Codename: gardalteMetroPCS Checking Root: Phone is Rooted. Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 30594628 MCK unlock code: 16817516 NCK unlock code: 00000000 NSCK unlock code: 05729583 SPCK unlock code: 00000000 CPCK unlock code: 00000000 Work time: 0:00:55 |
The Following User Says Thank You to drbilal For This Useful Post: |
03-07-2023, 23:58 | #950 (permalink) | |
Member: 1919025 Status: Offline Sonork: 100.1657804 Thanks Meter: 417 | Samsung Galaxy A51 (SM-A515F) FRP Done Samsung Galaxy A51 (SM-A515F) FRP fully done using samsung tool Quote:
04-14-2023, 09:57 | #951 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | S9+ (G965F) in Android 10 FRP REMOVED 1 click W/O TP or Combination by Octopus Hello, Tested this version 4.2.1 with a S9 Plus (G965F) w/o combination or Test Point. Here Log: Quote:
Br Allumts | |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
04-15-2023, 05:06 | #952 (permalink) |
Freak Poster Join Date: Nov 2016 Location: Vietnam
Member: 2643704 Status: Offline Sonork: Zalo:0932606079 Thanks Meter: 135 | Samsung A13 frp done Welcome to Octoplus Samsung Software v.4.2.0 Downloading installer file install_octoplus_samsung_4.2.1.exe Failed to open file install_octoplus_samsung_4.2.1.exe Work ID: 0000000001E5C60C Starting Reset FRP (Apr 2022) Selected model: SM-A137F Connect powered-on phone on first page of activation stage to PC via USB. Tap Emergency call on the first settings screen, then type *#0*#. Searching modem port... OK Read Info failed! Please wait... Please type *#0*#. Wait until the HW Test screen appears. Then press 'Ok' to continue... Failed, trying second method... OK Searching ADB devices... Press "OK" button on the device to allow USB debugging OK ADB connected Rebooting device... OK Perform Factory Reset from phone menu. Reset FRP (Apr 2022) done Execution time 1 minute(s) 24 second(s) Performed by 4.2.0 Software version. |
The Following 2 Users Say Thank You to Tien Dung GSM For This Useful Post: |
04-20-2023, 12:43 | #953 (permalink) |
Junior Member Join Date: Jul 2020 Location: Colombia-Magdalena Age: 33
Member: 2962319 Status: Offline Thanks Meter: 29 | Unlock MDM Kg Locked A035M BIT 1 Full DOne 2023-04-18 15:13:32.753 [I] Work ID: 0000000001942ACA 2023-04-18 15:13:32.776 [I] Starting Unlock MDM (Apr.2023) 2023-04-18 15:13:32.801 [I] Selected model: SM-A035M 2023-04-18 15:13:32.853 [W] Make factory data reset and connect the phone on first page of activation stage to PC via USB. 2023-04-18 15:13:37.927 [I] Input device IMEI and serial number 2023-04-18 15:13:37.927 [I] Phone must be in Setup Wizard mode 2023-04-18 15:14:43.115 [I] Input IMEI: 3510 2023-04-18 15:14:43.116 [I] Input SN: R9YT 2023-04-18 15:14:43.117 [I] Connecting to server... 2023-04-18 15:14:43.117 [I] Username: oct_WpVgvQs 2023-04-18 15:14:52.251 [I] Your balance: 110 credits 2023-04-18 15:14:52.252 [I] Sending device information.. 2023-04-18 15:14:52.740 [I] OK 2023-04-18 15:14:53.625 [I] Follow these steps : 2023-04-18 15:14:53.625 [I] 1. In Android Setup Wizard mode tap on the blank space 6 times. 2023-04-18 15:14:53.625 [I] 2. Scan this QR code to install MDM Guard service on your device. 2023-04-18 15:14:53.625 [I] 3. Connect to Wi-Fi. 2023-04-18 15:14:53.626 [I] 4. Follow the instructions on the screen. 2023-04-18 15:14:53.626 [I] 5. Allow USB debugging mode when prompt appears on the screen. 2023-04-18 15:14:53.633 [I] Searching ADB devices... 2023-04-18 15:16:00.644 [I] Press "OK" button on the device to allow USB debugging 2023-04-18 15:16:03.885 [I] OK 2023-04-18 15:16:03.886 [I] QR Code is scanned 2023-04-18 15:16:03.886 [I] Reading info... 2023-04-18 15:16:03.989 [I] Detected model: SM-A035M 2023-04-18 15:16:03.990 [I] Fingerprint: samsung/a03ub/a03:12/SP1A.210812.016/A035MUBU1BVH6:user/release-keys 2023-04-18 15:16:03.990 [I] Firmware compiled date: Fri Aug 26 06:55:56 KST 2022 2023-04-18 15:16:03.990 [I] PDA version: A035MUBU1BVH6 2023-04-18 15:16:03.990 [I] CSC version: A035MOWO1BVH6 2023-04-18 15:16:03.990 [I] SW version: A035MUBU1BVH6 2023-04-18 15:16:03.990 [I] Build number: BASE Version: 2023-04-18 15:16:03.990 [I] Phone SN: R9Y 2023-04-18 15:16:03.990 [I] Android version: 12 (SP1A.210812.016) 2023-04-18 15:16:03.990 [I] Sales code: COO 2023-04-18 15:16:03.990 [I] Carrier Id: COO 2023-04-18 15:16:03.990 [I] Country: Colombia 2023-04-18 15:16:03.990 [I] HW platform: ums9230_25c10 2023-04-18 15:16:03.990 [I] HW Chip: ums9230 2023-04-18 15:16:03.990 [I] HW Modem: REV1.0 2023-04-18 15:16:03.990 [I] Security patch level: 2022-07-01 2023-04-18 15:16:03.990 [I] Warranty Void: 0 2023-04-18 15:16:03.990 [I] Codename: a03ub 2023-04-18 15:16:03.990 [I] SIM 1 status: ABSENT 2023-04-18 15:16:03.990 [I] SIM 2 status: ABSENT 2023-04-18 15:16:03.990 [I] Modem board: T606 2023-04-18 15:16:05.074 [I] Your account will be charged for 100 credits. Do you want to continue? 2023-04-18 15:16:10.235 [I] Starting exploit... 2023-04-18 15:16:23.975 [I] Activating service... 2023-04-18 15:16:39.647 [I] MDM Guard service was activated. Your device will finish the installation and reboot. 2023-04-18 15:16:39.647 [I] Continue to follow instructions on the device 2023-04-18 15:16:39.648 [W] MDM Guard service will restrict OTA updates on your device to prevent relock. 2023-04-18 15:16:39.710 [I] Unlock MDM (Apr.2023) done 2023-04-18 15:16:39.732 [I] Execution time 3 minute(s) 6 second(s) 2023-04-18 15:16:39.750 [I] Performed by 4.2.1 Software version. |
The Following 2 Users Say Thank You to ArielTDH For This Useful Post: |
04-20-2023, 19:02 | #954 (permalink) |
Insane Poster Join Date: May 2013 Location: Earth
Member: 1948180 Status: Offline Thanks Meter: 36 | Samsung A41 SM-A415F Reset FRP Done Samsung A41 SM-A415F (Android security patch level 1 February 2023) Reset FRP Done Work ID: 000000000195840E Starting Reset FRP (Apr 2022) Selected model: SM-A415F Connect powered-on phone on first page of activation stage to PC via USB. Tap Emergency call on the first settings screen, then type *#0*#. Searching modem port... OK Detected device model: SM-A415F Product name: SEB HW Version: A415FXXU2DWB3/A415FOXM2DWB4/A415FXXU2DWB3/A415FXXU2DWB3 PDA version: A415FXXU2DWB3 CSC version: A415FOXM2DWB4 CP version: A415FXXU2DWB3 Device SN: R58N64AXXXX Device IMEI: 354146-11-######-# Please wait... Please type *#0*#. Wait until the HW Test screen appears. Then press 'Ok' to continue... Failed, trying second method... OK Searching ADB devices... Press "OK" button on the device to allow USB debugging OK ADB connected Rebooting device... OK Perform Factory Reset from phone menu. Reset FRP (Apr 2022) done Execution time 1 minute(s) 19 second(s) Performed by 4.2.1 Software version. |
The Following User Says Thank You to exploit69 For This Useful Post: |
05-02-2023, 17:09 | #955 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Samsung A21s (A217F), MDM (Knox Guard) SUCCESS REMOVED by OCTOPUS Samsung A21S (A217F), with "Pattern Lock" entered in FRP when Hard reset for "Pattern Unlock" and MOST IMPORTANT device Had "KNOX GUARD", (MDM), Removed with FULL SUCCESS by "Octopus Samsung Tool". Lets go, here how first Step "FRP Removed" LOG FRP: Code: Work ID: 0000000001ED0DA0 Searching for device. Please wait... Waiting for device... Found device on COM12 Reading info... Detected device model: SM-A217F HW Version: TIM PDA version: A217FXXU7CUI7 CSC version: A217FOXM7CUJ4 CP version: A217FXXU7CUI6 Device SN: R58xxxxxxxxxx Device IMEI: 35xxxxxxx Android version: 11 Enabling "USB Debugging" mode... Please, press "OK" button on the phone to allow USB debugging.. Searching for a phone (waiting for ADB / Fastboot device)... Phone found. Resetting FRP lock.. Perform factory reset to complete operation! Performed by 2.2.8.0 Software version. Now Must remove "Knox Guard" MDM LOG MDM: Code: Work ID: 00000000019161F4 Starting Unlock MDM (Feb.2022) Selected model: SM-A217F Make factory data reset and connect the phone on first page of activation stage to PC via USB. Input device IMEI and serial number Phone must be in Setup Wizard mode Input IMEI: 356XXXXXXXXXX Input SN: R58XXXXXXXX Connecting to server... Username: ripgsm Your balance: 123 credits Sending device information.. OK Follow these steps : 1. In Android Setup Wizard mode tap on the blank space 6 times. 2. Scan this QR code to install MDM Guard service on your device. 3. Connect to Wi-Fi. 4. Follow the instructions on the screen. 5. Allow USB debugging mode when prompt appears on the screen. Searching ADB devices... Failed Searching ADB devices... Press "OK" button on the device to allow USB debugging OK QR Code is scanned Reading info... Detected model: SM-A217F Fingerprint: samsung/a21snseea/a21s:11/RP1A.200720.012/A217FXXU7CUI7:user/release-keys Firmware compiled date: Wed Sep 29 12:08:59 +07 2021 PDA version: A217FXXU7CUI7 CSC version: A217FOXM7CUJ4 SW version: A217FXXU7CUI6 Build number: QB20417173 Phone SN: R58XXXXX Android version: 11 (RP1A.200720.012) Sales code: TIM Carrier Id: EUX Country: ITALY HW platform: exynos850 HW Chip: universal3830 HW Modem: MP 0.500 Security patch level: 2021-09-01 Warranty Void: 0 Codename: a21snseea SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SHANNON318 Your account will be charged for 100 credits. Do you want to continue? Starting exploit... Activating service... MDM Guard service was activated. Your device will finish the installation and reboot. Continue to follow instructions on the device MDM Guard service will restrict OTA updates on your device to prevent relock. Warning: Unlock MDM operation works for security patch level up to 2022-02-01. If you update your phone to security patch level 2022-03-01 or higher - device will be relocked. Unlock MDM (Feb.2022) done Execution time 9 minute(s) 31 second(s) Performed by 4.2.1 Software version. ALL DONE BR Allumts |
05-08-2023, 18:51 | #956 (permalink) |
Junior Member Join Date: Jan 2020 Location: Maxixe
Member: 2945769 Status: Offline Sonork: http://forum.gsmhosting.c Thanks Meter: 32 | A035f frp done Welcome to Octoplus Samsung Software v.4.2.2 Work ID: 0000000001F22071 Starting Reset FRP (SPRD Diag) Selected model: SM-A035F Connect phone via Test Point. Searching serial port... Serial port not found! Reset FRP (SPRD Diag) failed Execution time 20 second(s) Performed by 4.2.2 Software version. Work ID: 0000000001F22090 Starting Reset FRP (SPRD Diag) Selected model: SM-A035F Connect phone via Test Point. Searching serial port... Sending FDL1... OK Sending FDL2... OK Resetting FRP... Rebooting... OK Reset FRP (SPRD Diag) done Execution time 2 minute(s) 23 second(s) Performed by 4.2.2 Software version. |
The Following User Says Thank You to Chissaservices For This Useful Post: |
05-11-2023, 00:37 | #957 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Brasil,Fortaleza-Ce
Member: 729325 Status: Offline Sonork: 1581738 Thanks Meter: 890 | Mdm samsung sm-a736b Welcome to Octoplus Samsung Software v.4.2.2.1 Loading account information.. Your balance: *** credit(s) Work ID: 0000000001F36115 Starting Unlock MDM (Apr.2023) Selected model: General_Qualcomm Make factory data reset and connect the phone on first page of activation stage to PC via USB. Input device IMEI and serial number Phone must be in Setup Wizard mode Input IMEI: 35377537******* Input SN: RXCTB****** Connecting to server... Username: eletrico Your balance: *** credits Sending device information.. OK Follow these steps : 1. In Android Setup Wizard mode tap on the blank space 6 times. 2. Scan this QR code to install MDM Guard service on your device. 3. Connect to Wi-Fi. 4. Follow the instructions on the screen. 5. Allow USB debugging mode when prompt appears on the screen. Searching ADB devices... Press "OK" button on the device to allow USB debugging OK QR Code is scanned Reading info... Detected model: SM-A736B Fingerprint: samsung/a73xqxx/a73xq:13/TP1A.220624.014/A736BXXU3CWC1:user/release-keys Firmware compiled date: Thu Mar 23 10:54:54 KST 2023 PDA version: A736BXXU3CWC1 CSC version: A736BOWO3CWC1 SW version: A736BXXU3CWC1 Build number: 2393**** Phone SN: RXCTB0***** Android version: 13 (TP1A.220624.014) Sales code: ZTO Carrier Id: ZTO Country: Brazil HW platform: qcom HW Chip: lahaina HW Modem: MP0.4 Security patch level: 2023-03-01 Warranty Void: 0 Codename: a73xqxx SIM 1 status: ABSENT SIM 2 status: ABSENT Modem board: SM7325 Your account will be charged for 100 credits. Do you want to continue? Starting exploit... Activating service... MDM Guard service was activated. Your device will finish the installation and reboot. Continue to follow instructions on the device MDM Guard service will restrict OTA updates on your device to prevent relock. Warning: After rebooting the device, a MDM lock may appear. MDM Guard service will turn off the screen and the MDM lock will disappear. This may happen a few times after reboot. Warning: If the phone doesn't receive calls when the screen is off, please open 'Help' and read software manual. Unlock MDM (Apr.2023) done Execution time 9 minute(s) 2 second(s) Performed by 4.2.2.1 Software version. |
The Following 2 Users Say Thank You to eletrico For This Useful Post: |
05-16-2023, 12:08 | #958 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Samsung Galaxy A53 5G (A536E) Lastest Security Remove MDM Done |
The Following 4 Users Say Thank You to Shensohau For This Useful Post: |
05-17-2023, 21:01 | #959 (permalink) |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 408 | SM-J250F RESET FRP done Work ID: 000XXXXXXXXXXX Starting Reset FRP (Apr 2022) Selected model: SM-J250F Connect powered-on phone on first page of activation stage to PC via USB. Tap Emergency call on the first settings screen, then type *#0*#. Searching modem port... OK Detected device model: SM-J250F Product name: DKR HW Version: J250FXXS2ATI1/J250FOJV2ASK1/J250FXXU2ASK1/J250FXXS2ATI1 PDA version: J250FXXS2ATI1 CSC version: J250FOJV2ASK1 CP version: J250FXXU2ASK1 Device SN: RZ8K61PGMMW Device IMEI: 358475XXXXXXXXXXXX Please wait... Please type *#0*#. Wait until the HW Test screen appears. Then press 'Ok' to continue... OK Searching ADB devices... Press "OK" button on the device to allow USB debugging OK ADB connected Rebooting device... OK Perform Factory Reset from phone menu. Reset FRP (Apr 2022) done Execution time 55 second(s) Performed by 4.2.0 Software version. |
The Following User Says Thank You to allttar For This Useful Post: |
05-23-2023, 10:43 | #960 (permalink) |
Freak Poster Join Date: Feb 2012 Location: iran
Member: 1724300 Status: Offline Thanks Meter: 41 | samsung A145pXXU1AWA3 frp done Work ID: 000000000196C2A5 Starting Reset FRP (Brom mode) Selected model: General_MTK Please connect powered-on device, or via Brom mode. If for some reason Soft Bricking doesn`t work, you will have to connect your device via Brom mode by Test Point. Searching for devices... Searching MTK device... Detected MediaTek PreLoader USB VCOM (Android) HW Chip : MT6768 HW Version : 8a00.ca00.0.0 Reconnecting... OK Reading preloader... OK Mobile Status: brom Sending bootloader info... Initializing memory flash... Initializing successfully completed Detected EMMC flash Initializing memory flash... Initializing successfully completed Getting paritions info... Reading phone model name... Restoring bootloader... Getting paritions info... Reset FRP (Brom mode) done Execution time 40 second(s) Performed by 4.2.2.1 Software version. |
The Following User Says Thank You to sajad0789 For This Useful Post: |
