Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 11-23-2016, 19:16   #1 (permalink)
Member: 238466
Thanks Meter: 18
Problem after reset screen lock SM-G935F
After the software writes the recovery and restart the device gets stuck on the same written samsung
Old 11-24-2016, 06:37   #2 (permalink)
yudi_ar's Avatar
Member: 2155369
Thanks Meter: 706
try to write file with another version
Old 11-24-2016, 09:01   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,405
Hello.
Please post here full Software log of performed operations.
Old 11-24-2016, 16:32   #4 (permalink)
Member: 238466
Thanks Meter: 18
Originally Posted by Octopus box View Post
Hello.
Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\23-11-2016_19-12-14.log" created (23/11/2016 19:12:18).
INFO  : 23/11/2016 19:12:22 > Set up system language English (file: English.ini)
INFO  : 23/11/2016 19:12:22 > Welcome to Octoplus/Octopus Box Samsung software version 2.4.5
INFO  : 23/11/2016 19:12:25 > -----------------------------------------------------------------------------------
INFO  : 23/11/2016 19:12:25 > To connect SM-G935F phone you have to perform the following steps:
INFO  : 23/11/2016 19:12:25 > 1. Disconnect USB cable from phone.
INFO  : 23/11/2016 19:12:25 > 2. Go to Menu->Settings->More->About Device.
INFO  : 23/11/2016 19:12:25 > 3.Tap on "Build number" 7 times to enable developer options.
INFO  : 23/11/2016 19:12:25 > 4. Go to Menu->Settings->More->Developer options.
INFO  : 23/11/2016 19:12:25 > 5. Turn on "USB Debugging" option.
INFO  : 23/11/2016 19:12:58 > -----------------------------------------------------------------------------------
INFO  : 23/11/2016 19:12:58 > Platform: Samsung Android
INFO  : 23/11/2016 19:12:58 > Selected port: COM1
INFO  : 23/11/2016 19:12:58 > Selected model: SM-G935F
WARN  : 23/11/2016 19:12:58 > Connecting to server...
INFO  : 23/11/2016 19:13:00 > Connecting to server...Ok!
INFO  : 23/11/2016 19:13:00 > Checking resource files...
INFO  : 23/11/2016 19:13:00 > Resource files already downloaded.
WARN  : 23/11/2016 19:13:00 > Please put the phone into Download Mode and connect USB cable.
WARN  : 23/11/2016 19:13:00 > To put SM-G935F into Download Mode, You have to perform the following steps:
WARN  : 23/11/2016 19:13:00 > 1. Reconnect the battery.
WARN  : 23/11/2016 19:13:00 > 2. Press and hold "Volume-" + "Home" + "Power ON" keys.
WARN  : 23/11/2016 19:13:00 > 3. When phone turns on, press "Volume+" key.
INFO  : 23/11/2016 19:13:00 > Waiting for phone...
INFO  : 23/11/2016 19:13:21 > Firmware write started.
INFO  : 23/11/2016 19:13:21 > Writing Boot section...
INFO  : 23/11/2016 19:13:25 > Boot section has been written successfully.
INFO  : 23/11/2016 19:13:25 > Searching for a phone. Please wait...
ERROR : 23/11/2016 19:15:26 > timeout
ERROR : 23/11/2016 19:15:26 > Phone not found.
INFO  : 23/11/2016 19:15:26 > Performed by 2.4.5 Software version.
Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\23-11-2016_19-12-14.log" closed (23/11/2016 19:17:08).
Old 11-24-2016, 16:41   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to reflash the phone with older firmware, then repeat "Reset Screen Lock" operation.
Old 11-24-2016, 17:00   #6 (permalink)
Member: 238466
Thanks Meter: 18
but if I rewrite a new firmware lose all data ......
Old 11-24-2016, 17:05   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Writing of firmware shouldn't affect the data.
Old 11-24-2016, 17:41   #8 (permalink)
Member: 238466
Thanks Meter: 18
installed new firmware with Odin. I lost everything ...........
Old 11-25-2016, 21:41   #9 (permalink)
Member: 1815016
Thanks Meter: 77
Next time, use "HOME" CSC file and data will not be lost
Old 11-26-2016, 08:16   #10 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 292
if you want to flash your mobile without loss data , so its possible but , for that , MOST IMPORTANT think ,
you should flash your mobile with those FW , which one already installed
or you can installed latest , but don,t installed older FW
example
AP:G500HXX12345
so you flash with same this one FW
AP:G500HXX12345
and after that don,t restore you mobile , ( i think every software person know that)
incase you flashed with older FW so you must loss you date ,
Page generated in 0.24081 seconds with 8 queries
