01-15-2017, 13:32 | #1 (permalink) |
Insane Poster Join Date: Feb 2011
Member: 1512076 Status: Offline Thanks Meter: 4 | Problem with SM-J105B Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 Old log files will be deleted Totally 22 files were deleted ----------------------------------------------------------------------------- To connect SM-J105B phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. Selected firmware file: J105BUBU0APL1_J105BUUB0APK1 _COO_Android_5.1.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-J105B into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing KERNEL section... KERNEL section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing wfixnv2 section... wfixnv2 section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing MODEM section... MODEM section has been written successfully. Writing WDSP section... WDSP section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing Firmware Failed Performed by 2.4.7 Software version. Last edited by Octopus box; 01-18-2017 at 08:22. |
01-16-2017, 08:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Try to re-flash the phone with another firmware and post here the result. Last edited by Octopus box; 01-16-2017 at 09:05. |
01-18-2017, 08:21 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Yes, currently we have only one firmware for this phone model. We will try to find another firmwares and, if we find, we will upload them into the Support Area. |
