03-06-2015, 17:45 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post here full Software log with this info. |
03-06-2015, 18:33 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Re-flash the phone and try to write QCNs from the Support Area one by one. After writing each QCN, insert SIM card, wait 5-7 minutes, try to find and select network manually and check 3G. All QCN files, which we have, are present in the Support Area (press "Go to Support" button at "Support & Options" tab in the Software) in the folder "Samsung/FOR UNLOCK ANDREPAIR/QCN". |
03-06-2015, 19:47 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Disconnect the phone from PC and perform the steps, required for connection and repeat "Write QCN" operation. Try to perform the operation on different COM ports with enabled "Manual select" option. |
03-09-2015, 11:54 | #7 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2056468 Status: Offline Thanks Meter: 11 | I updated again again re- root the phone and tried cm you told me even popping manual select port , also tried on different port , but I always say -------------------- -------------------------------------------------- ------------- Platform : Android Samsung Selected port : COM171 Selected model: GT - I9505 Reading info ... Phone was not found on the selected port ! Send SPC ... |
03-09-2015, 11:59 | #8 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Of course, as You can see from your Software log, uploaded above, Software can find the phone, becouse phone's modem part is damaged and the phone doesn't answer to Software's CMDs: Quote:
You should re-flash the device with different firmwares and check, whether modem is correct (SW version is not Unknown). It is not possible to connect the phone via diagnostic port, if phone's modem part is damaged. | |
03-10-2015, 09:59 | #9 (permalink) |
Member: 2056468 Status: Offline Thanks Meter: 11 | ok friend'll try with various versions and lighthouse to know, instead I have another s4 that after repair imei repair and 3g-4g when unlocking the screen I see who was with bullet cut the network. how can I solve it? |
