Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 02-26-2014, 08:09   #1 (permalink)
Member: 2087262
Problem! How to repair IMEI in GT-I8190 with octoplus? [Solved]
cant restore imei..
i want link full guide for repair that..
this is a new box. i need to check my work and then write here what execly problem.
Old 02-26-2014, 08:17   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Please explain the problem in more details, step by step. What is your device exactly? What was the problem with your device? Which actions You have performed with it? Also post here full Software log with all of your actions.
Old 03-02-2014, 17:23   #3 (permalink)
Member: 2087262
Welcome to Octoplus/Octopus Box Samsung software version 1.4.3
To connect GT-I8190 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Applications->Development.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Go to dial window.
6. Enter "*#7284#" number.
7. Set "UART" radio button to "Modem" value.
7. Set "USB" radio button to "PDA" value.
8. Restart phone.
9. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM1
Selected model: GT-I8190
Searching for a phone. Please wait...
Phone found.
Firmware compiled date: Tue Jul 2 23:51:29 KST 2013
PDA Version: I8190XXAMG1
PDA Version: Unknown
Phone IMEI: Unknown
Android version: 4.1.2 (JZO54K)
Old IMEI: Unknown
New IMEI: 356265-15-145455-9
Reading data from phone...
Can't root Android version 2.3.3 and higer. Please Root the phone, or
flash phone using firmware with lower version of Android or rooted
firmware and repeat operation.
Can't root Android version 4.1.2 and higer. Please Root the phone, or
Can't get root privileges.
Write IMEI failed
MY PHONE IS ROOTED AND I USE SU IN ANOTHER APPS..
I DELETE ALL MY DATA AND CASH AND IT IS NOT CHANGE THE PROBLEM
Old 03-02-2014, 18:19   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
As You can see from this Software log, modem part (and other parts) is damaged in your device:
This can be Software (modem firmware is damaged or You have written unsuitable firmware) or HW problem.
At first, try to re-flash the device with different firmwares and check whether modem is correct (not Unknown) and only then (when phone's modem part will be correct) try to perform "Repair IMEI" operation. It is not possible to repair IMEI, if phone's modem part is damaged.
Also please install the latest Software version (Octopus Box Downloads - Software, Drivers, Manual), You use old version.
Old 03-05-2014, 08:58   #5 (permalink)
Member: 2087262
Tnx , check it and back here
Old 03-05-2014, 09:28   #6 (permalink)
Member: 2087262
8. Restart phone.
Selected port: COM1
Phone found.
CSC Version: I8190OXXAMG1
SW Version: I8190XXAMG1
Phone IMEI: 354784055368600
Phone SN: R21CB5GMFPP
Old IMEI: 354784-05-536860-0
New IMEI: 356235-14-511525-1
Data read successfully.
Please conect phone to BOX via UART cable.
Phone found.
Writing new IMEI. Please wait...
Write IMEI failed
Selected port: COM1
Phone found.
Phone found.
IMEI successfully repaired.
To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!)
TNX!!!
the u-art cable wasnt work,
The Following User Says Thank You to sniroded05 For This Useful Post:
Page generated in 0.15762 seconds with 8 queries
