Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 03-05-2015, 13:13   #1 (permalink)
Member: 1463928
Thanks Meter: 11
Post Problem with I9500 new security can't get signal [Solved]
Hi, i'm from Argentina, got 2 I9500 new security, but when trying to put new imei from software, always get null.
Followed all intructions:
1. Make Repair EFS.
2. Re-flash the phone again.
3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI).
4. Re-flash the phone again.
HERE IMEI COMES TO 0499....xxx
5. Re-start the phone, search and select network manually.
OS 4.4.2, any way to do this and get full signal?
Old 03-05-2015, 13:26   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
Hello.
To Repair IMEI, try to write IMEI Certificate from the Support Area (root the phone, make Wipe Security and Write Cert). Post here full Software log with all of your actions.
Old 03-05-2015, 18:02   #3 (permalink)
Member: 1463928
Thanks Meter: 11
I've done what u told me but same result imxx, what can i do now?
Platform: Samsung Android
Selected port: COM3
Selected model: GT-I9500
Detected phone model: GT-I9500
Firmware compiled date: Tue Oct 28 00:38:58 KST 2014
PDA version: I9500UBUGNJ1
CSC version: I9500UUBGNJ1
SW version: I9500UBUGNJ1
Phone IMEI: 004999010640000
Phone SN: 00000000000
Android version: 4.4.2 (KOT49H)
Repairing network. Please wait, this can take some time...
Phone will restart now. Please don't disconnect cable!
Selected port: COM3
Selected file: C:\Users\Gas\Downloads\Certificados\Cert-GT-I9500_
357138052400196_RF1D46DB4A.cert
Checking Root:
Phone is Rooted.
Checking Certificate file...
Checking Certificate failed
Writing Certificate failed
Selected port: COM3
Selected file: C:\Users\Gas\Downloads\Certificados\Cert-GT-I9500-
358851056213287_RV1D969EZT.cert
Checking Root:
Phone is Rooted.
Certificate file successfully checked
Writing Certificate...
Executing exploit...
Exploit has been executed successfully
Checking for compatible Certificate and phone...
Certificate is not compatible
Certificate is compatible
Certificate has been written successfully
Please, restart the phone to apply changes
Old 03-05-2015, 18:17   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
You have not performed "Wipe Security" operation before to write IMEI Certificate. Perform "Wipe Security" (IMEI should become Unknown) and only then write IMEI Certificate. Post here full Software log with all of these actions.
Old 03-05-2015, 19:37   #5 (permalink)
Member: 1463928
Thanks Meter: 11
Button say "Repair security/Wipe security", same button, or i need to click exactly where says "wipe"?
Old 03-05-2015, 19:42   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
Simply click the button.
Old 03-05-2015, 19:44   #7 (permalink)
Member: 1463928
Thanks Meter: 11
Want to make teamviewer? I've done that check here log:
Selected port: COM3
Now i'm doing again.
Same result, still in please don't disconnect cable but nothing, no more operation. imxx still 0044xxx. how much should i wait?
Welcome to Octoplus/Octopus Box Samsung software version 1.8.6
To connect GT-I9500 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
Selected port: COM3
Old 03-05-2015, 19:58   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
You need to perform "Wipe Security" operation, not "Repair Network".
Do exactly the next:
1. Perform "Wipe Security" operation (press "Repair Security/Wipe Security" button in Software and follow Software prompts).
2. Perform "Write Cert" operation (press "Write Cert" button in Software and follow Software prompts).
3. Post here full Software log of performed operations.
Old 03-05-2015, 20:19   #9 (permalink)
Member: 1463928
Thanks Meter: 11
Are u joking with me? I press Repair Security in the software and give me this result:
Can u please make me teamviwer now and check it by yourself? info sent by pm
Selected port: COM3
Old 03-05-2015, 20:34   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to do the next:
1. Make "Repair EFS".
2. Re-flash the phone with any 4.4.2 firmware from the Support Area.
3. Repeat "Write Cert" operation.
Check IMEI after these steps and post results.
Old 03-05-2015, 21:08   #11 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
Unlocking I9500 4.4.2 no need write cert with octopus
octopus have support for unlock this model with os KITKAT without lose imei
1. root ur phone (cfroot/kingroot)
2. just click unlock and follow sofware intruction
i will post my log tomorow
i have done many phone i9500 4.4.2 unlock with octopus
Old 03-05-2015, 21:12   #12 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
try this method for null
1.repair imei (phone show null)
2.reflash to 4.4.2 (imei ok)
3.unlock
4.done
Old 03-06-2015, 17:05   #13 (permalink)
Member: 1463928
Thanks Meter: 11
Finally i'd a solution.
Didn't work.
1. Make "Wipe security".
2. Any firmware flashed.
3. Repeat "Write Cert" operation with another tool (Chim...) WORKED (cert from octopus support)
Thanks, can close this
Page generated in 0.22542 seconds with 8 queries
