01-20-2015, 17:07 | #1 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2056468 Status: Offline Thanks Meter: 11 | problem n9005 [Solved] are holding a n9005 not taking network. I noticed that imei and already been changed by someone if I type * ° ° 0011 imei and some fail. second thing you have done? for the moment I'm making copies of qcn .. I do well? then that certificate and if I riscivere always possible for this model. waiting thank you in advance .. Last edited by Octopus box; 01-21-2015 at 09:25. |
01-20-2015, 17:37 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. If *#0011# menu status of IMEI Certi is failed, then You need to write another IMEI cert into the phone. To write cert file, You need to do the next: 1. Root the phone. 2. Make Wipe Security. 3. Perform "Write Cert" operation. You can use N900, or N9000Q cert files from the Support Area for SM-N9005. |
01-20-2015, 19:23 | #4 (permalink) |
Member: 2056468 Status: Offline Thanks Meter: 11 | I'm doing repair security operation to change imei with the original but the operation seems to be locked up for a while wiping efe attedo............ log: Welcome to Octoplus/Octopus Box Samsung software version 1.8.1 ----------------------------------------------------------------------------------- To connect SM-N9005 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N9005 Selected file: C:\Users\LUIGI\Downloads\sm-n9000q_ 359542050950920_rf1f33cv0d.cert Detected phone model: SM-N9005 Firmware compiled date: Mon Jul 28 21:56:29 KST 2014 PDA version: N9005XXUGNG1 CSC version: N9005ITVGNG1 SW version: N9005XXUGNG1 Phone IMEI: 358588053930899 Phone SN: RF8F10RW1MX Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Phone connected successfully Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... Phone will restart now. Please don't disconnect cable! Certificate has been written successfully Please, restart the phone to apply changes ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N9005 To Repair IMEI of the device, do the next steps: 1. Root the phone. 2. Perform Wipe Security procedure ("Repair Security/Wipe Security" button). 3. Write Certificate ("Write Cert" button). ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N9005 Detected phone model: SM-N9005 Firmware compiled date: Mon Jul 28 21:56:29 KST 2014 PDA version: N9005XXUGNG1 CSC version: N9005ITVGNG1 SW version: N9005XXUGNG1 Phone IMEI: 359542050950920 Phone SN: RF8F10RW1MX Android version: 4.4.2 (KOT49H) Reading info... Mode: Normal Firmware compiled date: Apr 04 2014 Firmware compiled time: 16:00:00 Firmware released date: Jul 28 2014 Firmware released time: 19:44:59 SW Version: M8974A-AAAANAZM-1.0.180102A Reading QCN... Send SPC... Reading mobile property... Mobile property read successfully Reading feature mask... Feature mask read successfully Reading roaming list 0 Reading roaming list 0 read successfully Reading NV items... NV items read successfully Reading NV SIM1 items... NV SIM1 items read successfully Reading NV SIM2 items... NV SIM2 items read successfully Reading NV items... NV items read successfully Reading EFS... EFS read successfully Reading provisioning items... Provisioning items read successfully Reading QCN done! Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\QCN-SM-N9005-359542050950920-20-01-2015_19-13- 10-.qcn file Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-SM-N9005-359542050950920-20-01-2015_19-15- 28-.asec file Wiping EFS... |
01-20-2015, 19:36 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Fully charge phone's battery by using external charger, make Factory data reset and wipe cache partition, reboot the PC, close all running applications on PC (antivirus, firewall, browsers) and then repeat Wipe Security operation once again. |
01-20-2015, 20:09 | #6 (permalink) |
No Life Poster Join Date: Jun 2007 Location: gsm word
Member: 525901 Status: Offline Sonork: 100.1607503 Thanks Meter: 47 | hello i have the same samsung sm-n9005 here do wipe and put another cert it but my problem is if i on the phone first is good but after few time not going call & not recive call how to soft this mater is it the cert i put not ok or what to do pls help |
01-20-2015, 20:15 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Try to use other IMEI Certificates, most likely, IMEI from the IMEI Cerificate file is in the black list of yout network operator. Also try to write QCN: https://mega.co.nz/#!6tRUHRRR!duCewd...Q9mUg7PonuYQb0. |
01-21-2015, 09:25 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Currently not exist the solution, how to write any IMEI and to get an active network. If You want to write original IMEI, write the first Security backup back into the phone to return the device into the previous state. |
