09-23-2013, 17:53 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | i9300 XXEMG4 back to older firmware |
09-23-2013, 21:28 | #2 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Israel
Member: 1563247 Status: Offline Thanks Meter: 57 | If you are downgrade the fitmware, then doing unlock (on the 00499 imei) and then restoring the modem with this file, I think is asking for the code again. Did you managed to unlock in this way? (Without need to repair imei) |
09-24-2013, 13:01 | #4 (permalink) |
Member: 1563247 Status: Offline Thanks Meter: 57 | I will try and update. Just to be sure that i'm doing the right steps. 1. Flash a full older firmware. (Which one?) 2. Root manually. 3. Unlock. 4. Flash the new modem back. (MG2 or MG4?) Is that correct? |
09-24-2013, 13:03 | #5 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | first uplod root(with recovery) after uplaod baseband in recovery after upload sample ı uploading I9300XXEMD3 after make again root after what u want.. |
09-24-2013, 13:11 | #6 (permalink) |
Member: 1563247 Status: Offline Thanks Meter: 57 | I do not understead. The phone alerdy came with XXEMG4 firmware. (Pda and modem) What to do first? Downgrade to MD3 and then unlock, or first unlock and then downgrade. |
The Following User Says Thank You to avicohh For This Useful Post: |
09-26-2013, 14:21 | #7 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | if u want downgrade first baseband downgrade after firmware downgrade https://hotfile.com/dl/247417575/447...bands.zip.html |
