04-07-2014, 22:00 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Marruecos Age: 44
Member: 39250 Status: Offline Thanks Meter: 64 | Problem to unlock I9305 [Solved] 1.5.1 ----------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM110 Selected model: GT-I9305 Mode: Emergency Unlock for GT-I9305 phone in emergency mode can’t be done ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM110 Selected model: GT-I9305 Mode: Emergency Unlock for GT-I9305 phone in emergency mode can’t be done ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1882 Selected model: GT-I9305 Mode: Emergency Unlock for GT-I9305 phone in emergency mode can’t be done ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1881 Selected model: GT-I9305 Mode: Normal Phone model: GT-I9305 Firmware compiled date: Dec 21 2012 Firmware compiled time: 03:00:00 Firmware released date: Jun 1 2013 Firmware released time: 13:13:15 Phone IMEI: 356297-05-554166-0 SW version: M9615ACEHWMAZD179599 Unlocking phone... Reading security failed Phone unlocking failed Last edited by Octopus box; 04-08-2014 at 15:09. |
04-08-2014, 00:40 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | of samsung octo suite after C:\Program Files\Octoplus\Octoplus_Samsung\LOG deleted all log file ---C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP deleted all backup backup other copy-after octo samsung suite open. after please rooted after USB Debugging" open connect usb select port try unlock.... |
04-08-2014, 06:39 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Root the phone manually and repeat the "Unlock" operation. Also try to connect the phone via Samsung Micro UART C3300k/C3303k cable and make "Read codes". Also, please look here: http://forum.gsmhosting.com/vbb/f684.../#post10142232, http://forum.gsmhosting.com/vbb/f684...2/#post9677951. |
04-08-2014, 14:29 | #4 (permalink) | |
Member: 39250 Status: Offline Thanks Meter: 64 | Quote:
1.5.1 ----------------------------------------------------------------------------- To connect GT-I9305 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "MODEM" value. 8. Go to "Qualcomm USB Settings". 9. Select "RNDIS+DM+MODEM". 10. Enter "*#9090#" number. 11. Select DM/DUM over HS-USB. 12. Close window. 13. Go to dial window. 14. Press "Read Info" in software. Selected firmware file: Root_GT-I9305.oct Please switch your phone to the download mode and connect it to a PC. To put GT-I9305 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Found phone on Firmware write started. Writing RECOVERY section... RECOVERY section has been written successfully. Firmware writing successfully completed. ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1882 Selected model: GT-I9305 Mode: Emergency Unlock for GT-I9305 phone in emergency mode can’t be done ----------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1881 Selected model: GT-I9305 Mode: Normal Phone model: GT-I9305 Firmware compiled date: Dec 21 2012 Firmware compiled time: 03:00:00 Firmware released date: Jun 1 2013 Firmware released time: 13:13:15 Phone IMEI: 356297-05-554166-0 SW version: M9615ACEHWMAZD179599 Unlocking phone... Reading security failed Phone unlocking failed PHONE ROOTED AND ERROR IS SOME | |
04-08-2014, 14:42 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | If after of rooting the device, error is the same, this means, there is new (currently not supported) security type in your device. Please, read backups of EFS and Security from your device and send us. We will research and prepare test Software version for You, that supports this new security type. |
