10-20-2015, 10:50 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Belarus
Member: 1684963 Status: Offline Thanks Meter: 20 | Problem with unlock SM-G920F Welcome to Octoplus/Octopus Box Samsung software version 2.0.8 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G920F Reading info, please wait... Warning: Selected model (SM-G920F) differs from the detected one (G9200)! If you want select (G9200) as (SM-G920F) model, please check "manual select". ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G920F Warning: Selected model (SM-G920F) differs from the detected one (G9200)! If you want select (G9200) as (SM-G920F) model, please check "manual select". Read codes failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM9 Selected model: SM-G920F Detected phone model: G9200 Firmware compiled date: Tue Jul 28 16:26:58 CST 2015 PDA version: Unknown CSC version: Unknown SW version: Unknown Phone IMEI: 358152805405237 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Reading security backup, please wait... Read codes failed |
10-20-2015, 10:56 | #2 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Ponkunnam, Kottayam. KERALA Age: 35
Member: 1800292 Status: Offline Sonork: 100.1668763 Thanks Meter: 122 | From your log- "PDA version: Unknown CSC version: Unknown SW version: Unknown" You need to re-flash with stock ROM |
10-20-2015, 11:09 | #3 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What phone model do You have exactly? SM-G920F, or SM-G9200? As You can see from Software log, phone's firmware is damaged: Quote:
10-20-2015, 11:28 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Reflash the phone, then try to read phone's info again. Repeat "Read Codes" operation only after phone's info will be read fully and correctly. |
