07-16-2013, 14:02 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Spain
Member: 590554 Status: Offline Sonork: 100.1618739 Thanks Meter: 127 | problems with S4 Solved just have to read carefully the help of the soft, it´s dosen´t matter how many time you have to do, if you do it the first time and dont work, just close the soft, do the procedure one more time, open octopus again and try one more time use micro uart usb cable with 525/530 ohms resistor (come with octopus cable set) Bienvenido en Octoplus/Octopus Box Samsung software versión 1.2.4 ----------------------------------------------------------------------------------- To connect GT-I9000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Close window. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: May 2 2013 Firmware released time: 23:44:49 Phone IMEI: 357197-05-958309-9 SW Version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: May 2 2013 Firmware released time: 23:44:49 Phone IMEI: 357197-05-95xxxxxx SW Version: M9615A-CEFWTAZM-4.0.17062 Reading phone unlock codes. It can take some time, please wait... Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked NCK unlock code: *#7465625*638*31583169# NSCK unlock code: *#7465625*782*00000000# SPCK unlock code: *#7465625*77*00000000# ----------------------------------------------------------------------------------- Plataforma: Samsung Android Puerto seleccionado: COM3 Modelo seleccionado: GT-I9505 Modo: Normal Modelo del teléfono: GT-I9505 Fecha de creación del firmware: Mar 28 2013 Tiempo de compilación del firmware: 09:00:00 Fecha de salida del firmware: May 2 2013 Tiempo de salida del firmware: 23:44:49 IMEI del teléfono: 357197-05-95xxxxxx Versión del SW: M9615A-CEFWTAZM-4.0.17062 Leyendo los códigos de liberación del teléfono. Esto puede llevarle un cierto tiempo, por favor, espere… Connecting to server... Connect successfully to server Checking smart card... Smart card successfully checked Checking operation... Operation successfully checked NCK unlock code: *#7465625*638*31583169# NSCK unlock code: *#7465625*782*00000000# SPCK unlock code: *#7465625*77*00000000# hope can help |
The Following User Says Thank You to jamert_92 For This Useful Post: |
07-16-2013, 23:17 | #2 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1980366 Status: Offline Thanks Meter: 0 | Hi, I tried many times to unlock my S4, but no luck. Can you guys please help ? Thanks in advance Welcome to Octoplus/Octopus Box Samsung software version 1.2.1 ----------------------------------------------------------------------------------- To connect SGH-I337 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to dial window. 9. Enter "*#9090#" number. 10. Select "[4] DM over UART(*)". 11. Restart phone. 12. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM3 Mode: Emergency |
07-16-2013, 23:34 | #3 (permalink) |
Member: 1980366 Status: Offline Thanks Meter: 0 | sorry, wrong screen ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I337 Mode: Emergency Unlock for SGH-I337 phone in emergency mode can’t be done |
07-17-2013, 06:00 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Please carefully perform all the steps from software manual to connect the phone. You need to use Samsung Micro UART C3300k/C3303k cable with 525-530 kOhm resistor inside. Please try carefully again. If You still can't connect the phone, please contact us to Sonork or to Yahoo! Messenger, we will try to help You remotely. Our contacts You can find in out profile. |
07-17-2013, 09:53 | #5 (permalink) | |
Member: 590554 Status: Offline Sonork: 100.1618739 Thanks Meter: 127 | Quote:
you are ussing usb cable or uart cable, remove battery, then insert battery again and power on the phone when completly on go to dial and press *#7284# and select PDA, then go one more time to dial and press *#9090# and now selct option 4, automaticli the phone will restart, and then conent with uart cable to your octopus box and open the sotf, press read info and then unlock or read code hope help | |
07-18-2013, 05:41 | #6 (permalink) |
Member: 1980366 Status: Offline Thanks Meter: 0 | hi all, Thanks so much for your help. First, I followed the 12 steps instruction. Then, I tried to read info via USB cable ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SGH-I337 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM3 Mode: Emergency Finally, I tried to unlock it with UART cable ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SGH-I337 Mode: Emergency Unlock for SGH-I337 phone in emergency mode can’t be done I was able to read info, unlock 2 Galaxy S2 T989 But when it comes to this Galaxy S4 i337, I have no clue what I did wrong |
07-18-2013, 06:08 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ azn6929 Please contact us to Sonork or to Yahoo! Messenger, we will look what You do incorrectly and try to help You remotely |
07-20-2013, 10:37 | #8 (permalink) | |
07-25-2013, 15:57 | #9 (permalink) |
Freak Poster Join Date: May 2002 Location: dubai
Member: 11945 Status: Offline Thanks Meter: 76 | Welcome to Octoplus/Octopus Box Samsung software version 1.2.5 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "MODEM" value. 8. Go to dial window. 9. Enter "*#9090#" number. 10. Select "[4] DM over UART(*)". 11. Restart phone. 12. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Firmware compiled time: Firmware released date: ~ Firmware released time: SW Version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 35xxxx-xx-xxxxxx-x New IMEI: 35xxxx-xx-xxxxxx-x Repairing NVM for GT-I9505 phone... NVM repair completed successfully New IMEI successfully written. Please, restart the phone to apply changes but the IMEI still original,no changes was done :-( |
07-25-2013, 16:13 | #10 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. What is the state of your device? As I see, some phone's info was not read out correctly: Quote:
07-25-2013, 16:33 | #11 (permalink) | |
Member: 11945 Status: Offline Thanks Meter: 76 | Quote:
----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 18:40:16 SW Version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 356843-05-468708-5 New IMEI: 359420-03-224342-7 Repairing NVM for GT-I9505 phone... NVM repair completed successfully New IMEI successfully written. Please, restart the phone to apply changes nothing changed,same IMEI and there's no Repair EFS option in software. | |
07-26-2013, 05:45 | #14 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | @ badi Quote:
Read carefully software manual ("Help" button) how to make Repair IMEI, perform all the steps from software manual and then post here full software log with all of your actions. | |
