06-15-2018, 23:07 | #1 (permalink) |
Junior Member Join Date: May 2018
Member: 2836767 Status: Offline Thanks Meter: 2 | "Proper Android device not found" problem [Answered] Hello and thank you for your help. I am a phone n00be and am just beginning to learn to use the OctoPlus Box. That being said, I cannot get it to work with any phones I have: (2) SM-G935V (1) SM-G930V (1) SM-G900V - Octoplus Box Samsung software version 2.6.9 - Samsung USB Driver for Mobile Phones: - v1.5.45.0 - v1.5.65.0 - SMART CARD FIRMWARE updated: Searching for server... Server greeting: "Card updates server v.2.2" Searching installed cards... Found card with s/n 0000xxxx Selected card: 000000xxxx Updates count: 5 Updates limit: 8 Activations: - LG - NO - Samsung - FULL (ver 2.5) - JTAG - NO - FRP - NO Creating secure connection... Requesting firmware... Writing card firmware... Card firmware successfully updated! - Cable used: RX-AC108 CA101 Attempts to resolve: - "Developer options" activated - "USB debugging" on - "File Transfer" selected / set - Clicking on "Read info" from Actions, Main - No USB hubs - USB 3.0 and 2.0 ports - Completely different computers (both Win10 64-bit, fully updated) - Compatibility mode: Admin, Win7 - Tried with all phones (previously listed) - All available Options COM ports in software No matter what is attempted, this is always the Read info result for any phone used: Platform: Samsung Android Selected port: COM6 Selected model: SM-G935V Operation: Read info Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.6.9 Software version. Question: Is there a test / diagnostic program or procedure for testing the OctoPlus Box? I have tried everything I can think of. Please help. Thank you. Last edited by Octopus box; 06-16-2018 at 09:10. |
The Following 2 Users Say Thank You to DBVD For This Useful Post: |
06-16-2018, 07:39 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Here is some ways, you can try to fix it....Before try wit Octopus, install Minimal Adb, Open command and type “Adb Devices” nd check that you’re pc recognise ur device as Adb port, or Not.?2nd try, close all background apps which Auto ON after connect any Adb device, like kies,Hisuite...eg. Before connect device wit pc,Go to task manager and check if u found any Adb process than kill it. Make sure that u installed latest nd well Samsung Driver...after connect device check it, that it is connected or Not under Device Manger ... If need than Disable driver signature, if ur wit 64bit system... |
The Following 2 Users Say Thank You to -Mosin- For This Useful Post: |
06-16-2018, 12:21 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | For disable easy way in win 10 64 Bit use this procedure: http://forum.gsmhosting.com/vbb/f684...users-2121543/ |
The Following User Says Thank You to allumts For This Useful Post: |
06-17-2018, 19:23 | #4 (permalink) |
Member: 2836767 Status: Offline Thanks Meter: 2 | Have I installed Octoplus Box correctly? Thanks for your replies so far. What is required to install the Octoplus Box? I only installed the Samsung USB drivers and the Octoplus Box software. Am I supposed to install some other drivers also? I have seen comments about installing SMART CARD drivers/software, which I never installed before, or know which ones to install. Also, isn't there some installation instructions somewhere? I cannot find an "installation manual" for this Octoplus Box I have. If I knew HOW I was supposed to install it, and what software and drivers were needed, it seems like this would be simple. Still struggling, but thank you for all of your help. |
06-17-2018, 19:42 | #5 (permalink) |
Member: 2836767 Status: Offline Thanks Meter: 2 | Cannot find / install smart card driver. The smart card driver will not install. I cannot find the correct one. Here is the ID: SCFILTER\CID_80318065b0850201f312fffe829000 Thanks again. |
06-18-2018, 05:14 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | If Software starts (runs), this means, that card driver is installed correctly. |
06-23-2018, 00:03 | #7 (permalink) | |
Member: 2836767 Status: Offline Thanks Meter: 2 | Quote:
Thank you for your suggestions and help. I had to take a break from working on this, but back at it now. I installed the ADB drivers and when I run at the command prompt, I get this: List of devices attached ca5c8dd6 unauthorized ^^^ This is the phone I'm trying to work on. An SM-G930V List of devices attached f1c2bad1 device ^^^ This is my old SM-G900V, with no problems. List of devices attached c0bdde88 device ^^^ This is my working SM-G935V So.... what does unauthorized mean? This phone had a bad IMEI (not for payment or billing issues), and I paid $80 to have it "cleaned". When I check the IMEI on swappa dot com, it now says it's fine (it was not fine before the cleaning). Thank you again for your much needed help! I'm trying to get this phone working for my mom. | |
06-23-2018, 00:15 | #8 (permalink) | |
p.s. I'm still getting the "Proper android device not found. Make shure that "USB debug" option on the device is turned on." I get that UNLESS I connect my old SM-G900V, then I don't get that error. Thanks. | |
