07-13-2014, 09:15 | #1 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1777468 Status: Offline Thanks Meter: 10 | Q|Help unlock I9301I Im trying to unlcok I9301i and I get the folloeing error Platform: Samsung Android Selected port: COM1027 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 31 2014 Firmware compiled time: 12:00:00 Firmware released date: May 12 2014 Firmware released time: 14:40:53 Phone IMEI: 352750-06-062193-9 SW version: M8626A-AAAANAZM-1.0.4050 Unlock for GT-I9301I phone in normal mode can’t be done What should I do? |
07-13-2014, 09:27 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please use this the latest Software version and post here the result: https://mega.co.nz/#!jgIW1Q4Y!NICPMi...VOoMxLUYuyFOqI. |
07-13-2014, 16:52 | #3 (permalink) |
Member: 1777468 Status: Offline Thanks Meter: 10 | Ok thx It helped : Platform: Samsung Android Selected port: COM537 Selected model: GT-I9301I ADB server killed. Detected phone model: GT-I9301I Firmware compiled date: Mon May 12 18:04:33 KST 2014 PDA version: I9301IXXUANE3 CSC version: I9301IOXXANE2 SW version: I9301IXXUANE3 Phone IMEI: 352750060621939 Phone SN: RV1F531HZYE Android version: 4.4.2 (KOT49H) Cheking Root Phone is not rooted Phone unlocking failed but now I need to root the device and I cand seem to find a working way, I tried vroot kingo geohot v3+ supersu. Any other way to go about it ? |
07-13-2014, 20:19 | #4 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: ajman U.A.E Age: 34
Member: 1805549 Status: Offline Sonork: 100.1620595 Thanks Meter: 45 | Quote:
07-14-2014, 08:10 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to use TowelRoot to root the device. Also try to re-flash the phone with other 4.4.2 firmwares and try to root the device by using TowelRoot and the latest versions of VRoot and Kingo Root Softwares. |
07-14-2014, 08:39 | #7 (permalink) |
Member: 1777468 Status: Offline Thanks Meter: 10 | I have tried vroot,kingo and towl root on :XXUANE3, XXUANC6, XXUAND3 but no sucsses. I get|: Cheking Root Phone is not rooted Phone unlocking failed every time. Do you know what firmware must work ? thank you |
07-14-2014, 08:50 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to find and write "I9301IXXUANC6_I9301IITVAND2_I9301IXXUANC6" for Italy and root it by using TowelRoot. |
07-14-2014, 12:20 | #9 (permalink) | |
Member: 1777468 Status: Offline Thanks Meter: 10 | Quote:
And if I try 3g/4g fix I get : Platform: Samsung Android Selected port: COM537 Selected model: GT-I9301I Mode: Normal Phone model: GT-I9301I Firmware compiled date: Mar 03 2014 Firmware compiled time: 12:00:00 Firmware released date: Mar 20 2014 Firmware released time: 00:54:10 Incorrect IMEI SW version: M8626A-AAAANAZM-1.0.4044 Repairing 3G/4G... Reading nv... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\NV-GT-I9301I-004400152020000-14-07-2014_14-07-03-.nv file Critical error has encounted. Error message: Access violation at address 007AE246 in module 'OctoplusSamsung.exe'. Read of address 00000000 What will be the next step for me ?? | |
07-14-2014, 13:44 | #12 (permalink) | ||
Member: 1777468 Status: Offline Thanks Meter: 10 | Ok so now after clicking imei repair I get : Quote:
p.s after the first fail atempt I need to approve the pc on the device every time Im trying to run a command from software and I need to revoke usb debug authorization to make it run again | ||
07-14-2014, 14:59 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Do the next: 1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Run Octoplus Samsung Software. 3. Root the phone again. 4. Re-start the device. 5. Perform the "Repair IMEI" operation. 6. Make "Repair 3G/4G". 7. Close the Software. 8. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" and post here links, we will check, where can be the problem with the device. |
07-14-2014, 17:52 | #14 (permalink) | |
Logs: | |
