11-08-2014, 18:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1893471 Status: Offline Thanks Meter: 25 | [Q]SM-G900f phone diabled by EE solution? Today I have received phone with message , Phone disabled by EE , which is obviously some stolen case, At the moment phone is not in U.K, It is out of country I write new certificate and change imei but message still showing on the screen, Is there any solution to fix it, br |
11-08-2014, 19:16 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Have You performed "Wipe Security" operation before "Write Cert"? Post here full Software logs of all performed operations. |
11-11-2014, 16:59 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Have You performed "Wipe Security" operation before "Write Cert"? Post here full Software logs of all performed operations. In some cases, is necessary to repeat the "Wipe Security" operation several times or re-flash the phone. Try to do the next: 1. Fully charge phone's battery. 2. Make Factory data reset and wipe cache partition. 3. Make Wipe Security several times and check, whether IMEI becomes "Unknown". Also try to re-flash the phone and make Wipe Security. 4. When IMEI becomes "Unknown", Write Certificate. 5. Post here the result. |
11-11-2014, 18:23 | #5 (permalink) | |
Member: 1893471 Status: Offline Thanks Meter: 25 | Quote:
I could not set all setting like *#0808# enable debug mode, disable knox etc because disable message appears soon after phone complete power on, plus If I could success than I have to write certificate which result in changed imei which I donot want, so is there no way to disable this message by not changing imei? | |
11-11-2014, 18:25 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Quote:
11-15-2014, 09:23 | #7 (permalink) |
Freak Poster Join Date: Jul 2013 Location: sialkot
Member: 1972648 Status: Offline Thanks Meter: 45 | phone disabled by ee hello dear plz some one try with omega rom just finde aap name wich use samsung for blocking mybe help someone just tell me aap name i want to remove that aap from samsung system aap i sure in system |
11-15-2014, 09:45 | #8 (permalink) |
Member: 1972648 Status: Offline Thanks Meter: 45 | phone disabled by ee uk dear i have idea for bypass phone disabled by ee i think samsung s5 software store in system file i dont think in bootloder knox so posibal with custom rom i m 100% sure becoz samsung dont have online server plz plz omga rom do something i have 6 galaxy s 5 who tell me that app name i remove in system plz findet sorry for bed write |
