10-26-2014, 06:05 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: world
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | query sm-n750 and sm-n7505 certificate same [Solved] i have a n750 not register network. Last edited by Octopus box; 11-03-2014 at 13:23. |
10-26-2014, 10:54 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Most likely, certificates for these devices are different, but You can try to write - Software will check they compatibility automaticaly. Also, we have sent You to PM one certificate file for SM-N750, try to write this certificate and say the result. |
10-26-2014, 11:20 | #3 (permalink) |
Member: 573962 Status: Offline Sonork: 100.1603021 Thanks Meter: 480 | THANK FOR REPLY PLS CHECK NOW SHOW Welcome to Octoplus/Octopus Box Samsung software version 1.7.3 ----------------------------------------------------------------------------------- To connect SM-N750 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N750 Selected file: C:\Documents and Settings\sameerkhan\Desktop\Cert-SM- N750_351665064994960_RF1F31XNCC.cert Proper android device not found. Make shure that "USB debug" option on the device is turned on. Writing Certificate failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N750 Selected file: C:\Documents and Settings\sameerkhan\Desktop\Cert-SM- N750_351665064994960_RF1F31XNCC.cert Detected phone model: SM-N750 Firmware compiled date: Thu Jul 24 22:13:02 KST 2014 PDA version: N750XXUCNG6 CSC version: N750ODDCNG5 SW version: N750DDUCNG3 Phone IMEI: 004999010640000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Unknown security Writing Certificate failed ----------------------------------------------------------------------------------- To connect SM-G900H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N900 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-N750 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-N750 Selected file: C:\Documents and Settings\sameerkhan\Desktop\Cert-SM- N750_351665064994960_RF1F31XNCC.cert Detected phone model: SM-N750 Firmware compiled date: Thu Jul 24 22:13:02 KST 2014 PDA version: N750XXUCNG6 CSC version: N750ODDCNG5 SW version: N750DDUCNG3 Phone IMEI: 004999010640000 Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Unknown security Writing Certificate failed |
10-26-2014, 11:32 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | As You can see from your Software log, security is damaged in your device: Quote:
1. Delete all files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\". 2. Take our SIM and SD cards from the phone. 3. Root the phone. 4. Perform the "Unlock" operation (even it will not successfully completed). 5. Read out EFS from the phone. 6. Read out Security from the phone. 7. Close the Software. 8. Upload somewhere the latest created "*.log" and "*.logx" files from the folder "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\" together with read out backups of EFS and Security and post here links, we will check, where can be the problem with the device. | |
10-27-2014, 13:39 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Try to re-flash the device with another 4.4.2 Android firmware and repeat the operation once again. Post here the result. |
11-03-2014, 10:24 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | We have prepared and sent You test Software version to PM. Try to write certificate by using this Software and post here the result. |
