07-16-2017, 19:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Read Codes SM-J320AZ done ----------------------------------------------------------------------------------- To connect SM-J120AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J320AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM80 Selected model: SM-J320AZ Searching for a phone. Please wait... Found phone on COM840 Reading info... Detected phone model: SM-J321AZ HW Version: SM-J321AZDZAIO PDA version: J321AZTUU2APJ2 CSC version: J321AZAIZ2APJ2 CP version: J321AZTUU2APJ2 Phone SN: R28HC2QWKDR Phone IMEI: 356518-07-191673-9 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 07164240 NET LOCK unlock code: 09692609 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:15 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- To connect SM-J321AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM840 Selected model: SM-J321AZ Searching for a phone. Please wait... Found phone on COM841 Reading info... Detected phone model: SM-J321AZ HW Version: SM-J321AZDZAIO PDA version: J321AZTUU2APJ2 CSC version: J321AZAIZ2APJ2 CP version: J321AZTUU2APJ2 Phone SN: R28HC2QVZET Phone IMEI: 356518-07-191014-6 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 80259085 NET LOCK unlock code: 82739520 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:13 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM841 Selected model: SM-J321AZ Searching for a phone. Please wait... Found phone on COM842 Reading info... Detected phone model: SM-J321AZ HW Version: SM-J321AZDZAIO PDA version: J321AZTUU2APJ2 CSC version: J321AZAIZ2APJ2 CP version: J321AZTUU2APJ2 Phone SN: R28HC2QT58F Phone IMEI: 356518-07-189058-7 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 57036161 NET LOCK unlock code: 47575914 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:37 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM842 Selected model: SM-J321AZ Searching for a phone. Please wait... Found phone on COM842 Reading info... Detected phone model: SM-J321AZ HW Version: SM-J321AZDZAIO PDA version: J321AZTUU2APJ2 CSC version: J321AZAIZ2APJ2 CP version: J321AZTUU2APJ2 Phone SN: R28HC2QT58F Phone IMEI: 356518-07-189058-7 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 57036161 NET LOCK unlock code: 47575914 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:36 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM842 Selected model: SM-J321AZ Searching for a phone. Please wait... Port busy Phone was not found on the selected port! Read codes failed Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM842 Selected model: SM-J321AZ Searching for a phone. Please wait... Port busy Phone was not found on the selected port! Read codes failed Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM842 Selected model: SM-J321AZ Searching for a phone. Please wait... Found phone on COM843 Reading info... Detected phone model: SM-J321AZ HW Version: SM-J321AZDZAIO PDA version: J321AZTUU2APJ2 CSC version: J321AZAIZ2APJ2 CP version: J321AZTUU2APJ2 Phone SN: R28HC2QWLZA Phone IMEI: 356518-07-191725-7 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 52846161 NET LOCK unlock code: 03706183 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:08 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM843 Selected model: SM-J321AZ Searching for a phone. Please wait... Found phone on COM843 Reading info... Detected phone model: SM-J321AZ HW Version: SM-J321AZDZAIO PDA version: J321AZTUU2APJ2 CSC version: J321AZAIZ2APJ2 CP version: J321AZTUU2APJ2 Phone SN: R28HC2QWLZA Phone IMEI: 356518-07-191725-7 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 52846161 NET LOCK unlock code: 03706183 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:08 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- To connect SM-J320A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM843 Selected model: SM-J320A Searching for a phone. Please wait... Found phone on COM844 Reading info... Detected phone model: SM-J320A HW Version: SM2J320AZACATT PDA version: J320AUCU2APJ2 CSC version: J320AATT2APJ2 CP version: J320AUCU2APJ2 Phone SN: R28J1040MTN Phone IMEI: 357417-07-883917-7 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 13942509 NET LOCK unlock code: 03640819 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:23 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM844 Selected model: SM-J320A Searching for a phone. Please wait... Found phone on COM845 Reading info... Detected phone model: SM-J320A HW Version: SM2J320AZACATT PDA version: J320AUCU2APJ2 CSC version: J320AATT2APJ2 CP version: J320AUCU2APJ2 Phone SN: R28J103Z36E Phone IMEI: 357417-07-882213-2 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 15058270 NET LOCK unlock code: 58184790 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:25 Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM845 Selected model: SM-J320A Searching for a phone. Please wait... Found phone on COM846 Reading info... Detected phone model: SM-J320A HW Version: SM2J320AZACATT PDA version: J320AUCU2APJ2 CSC version: J320AATT2APJ2 CP version: J320AUCU2APJ2 Phone SN: R28J103Z0VP Phone IMEI: 357417-07-882136-5 Reading HWID...OK Reading NV data...OK Reading phone unlock codes. This can take some time, please wait... FREEZE unlock code: 16284035 NET LOCK unlock code: 62097130 SUB LOCK unlock code: 00000000 SP LOCK unlock code: 00000000 CP LOCK unlock code: 00000000 SIM LOCK unlock code: 00000000 Work time: 0:00:27 Performed by 2.5.4 Software version. Last edited by Octopus box; 07-17-2017 at 06:24. |
The Following User Says Thank You to Gambitv01 For This Useful Post: |
