11-21-2014, 18:12 | #61 (permalink) | |
Freak Poster Join Date: May 2013 Location: Turkey
Member: 1941192 Status: Offline Thanks Meter: 57 | Quote:
There are two types of i9500 without changing the type and the type of problems happen Null Null | |
11-22-2014, 10:02 | #62 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @mestoo1, No there are any 2 type of I9500. What you are seeing of strange?, it's a easy Imei Repair with "Service imei" in the list, not is Original imei and there isn't nothing of strange in this. Default/Corrupt imei repaired with "service imei" it's all. BR allumts |
01-14-2015, 00:24 | #65 (permalink) |
Crazy Poster Join Date: Jul 2005 Location: Colombia Age: 44
Member: 160485 Status: Offline Thanks Meter: 12 | Versión del SW: I9500UBUGNI1 IMEI del teléfono: 004999010640000 Phone SN: RF1D45EJGGR Android version: 4.4.2 (KOT49H) Checking Root: Phone is Rooted. Checking Certificate file... Certificate file successfully checked Writing Certificate... Executing exploit... Exploit has been executed successfully Writing Certificate failed |
01-30-2015, 16:28 | #67 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2080963 Status: Offline Thanks Meter: 0 | Repairing IMEI ... Repairing network. Please wait, this can take some time... Network is successfully repaired Imei is right, but Repairing network is not work. PDA version: I9500XXUFNB3. |
02-04-2015, 07:44 | #69 (permalink) |
Junior Member Join Date: Dec 2014 Location: kisumu,kenya
Member: 2312470 Status: Offline Thanks Meter: 1 | This is what worked for me: -disable knox -root phone -repair imei using sevice imei from list -if imei appers null -Perform "Repair Security" operation -restart phone from phone menu |
The Following User Says Thank You to rabbzvicta For This Useful Post: |
02-05-2015, 00:07 | #70 (permalink) |
Crazy Poster Join Date: May 2013
Member: 1934800 Status: Offline Thanks Meter: 1 | The support of Octoplus says: Do EXACTLY the next: 1. Make Repair EFS. 2. Re-flash the phone again. 3. Make Repair IMEI (write service IMEI from the Software list, not any IMEI). 4. Re-flash the phone again. 5. Re-start the phone, search and select network manually. 6. Post here full Software log with all of these actions. And it works..! thanks.. |
02-06-2015, 08:19 | #72 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | @ pat1980 Create new thread with the problem, read out phone's info via ADB (turn on USB Debugging Mode in the phone and press "Read info" button at "Android / EFS manager" tab in the Software) and post there full Software log with this info. We will look and say You, what to do the next. |
02-12-2015, 10:17 | #73 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | Quote:
I just want to ask you sir If i get i9500 with Unknown Baseband and i flashed all or most of firmwares available and the Baseband doesn't come back , what is the problem? Firmware Flashed: Code: I9500XXUBMEA_I9500OJVBMEA_EGY I9500XXUBMF8 Factory image I9500XXUBMG9 I9500XXUEMJ5_I9500OJVEMJ5_XSG-android.4.3 I9500XXUEMJ8-20131113153502 I9500XXUFNB4-20140310163629 I9500XXUFNE7-20140617154003 I9500XXUGNH2-20140829163324 Download reach till 99 % then i get Server Error ( i am working with IDM) so i have to start downloading again . | |
02-12-2015, 10:45 | #74 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
02-12-2015, 11:14 | #75 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
