02-13-2015, 16:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Repair imei fail i9300 ----------------------------------------------------------------------------------- To connect SCH-I535 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#22745927" number. 7. In Hidden Menu select "enable" radio button. 8. Go to dial window. 9. Enter "*#7284#" number. 10. Set "UART" radio button to "PDA" value. 11. Go to "Qualcomm USB Settings". 12. Select "RNDIS+DM+MODEM". 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SCH-I545 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM54 Mode: Normal Phone model: SCH-I545 Firmware compiled date: Oct 11 2013 Firmware compiled time: vanke Firmware released date: Dec 11 2013 Firmware released time: 01:58:48 Phone IMEI: 357070-05-735669-5 SW version: M8960A-AAAANAZM-1.0.443090 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM54 Selected model: SCH-I545 Mode: Normal Phone model: SCH-I545 Firmware compiled date: Oct 11 2013 Firmware compiled time: vanke Firmware released date: Dec 11 2013 Firmware released time: 01:58:48 SW version: M8960A-AAAANAZM-1.0.443090 Old IMEI: 357070-05-735669-5 New IMEI: 351248-74-566633-9 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SCH-I545-357070057356695-13-02-2015_16-22- 44-.nvm file Firmware compiled date: Sat Jun 8 17:24:52 KST 2013 PDA version: I9300XXBMF1 CSC version: I9300XXBMF1 SW version: I535VRUCML1 Phone IMEI: 357070057356695 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SCH-I545-357070057356695-13-02-2015_16-26- 40-.asec file Erasing old IMEI. It can take some time. Please wait... Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM54 Selected model: SCH-I545 Mode: Normal Phone model: SCH-I545 Firmware compiled date: Oct 11 2013 Firmware compiled time: vanke Firmware released date: Dec 11 2013 Firmware released time: 01:58:48 Phone IMEI: 357070-05-735669-5 SW version: M8960A-AAAANAZM-1.0.443090 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM54 Selected model: SCH-I545 Mode: Normal Phone model: SCH-I545 Firmware compiled date: Oct 11 2013 Firmware compiled time: vanke Firmware released date: Dec 11 2013 Firmware released time: 01:58:48 SW version: M8960A-AAAANAZM-1.0.443090 Old IMEI: 357070-05-735669-5 New IMEI: 351248-98-666322-7 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SCH-I545-357070057356695-13-02-2015_16-29- 45-.nvm file Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- To connect SCH-I535 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#22745927" number. 7. In Hidden Menu select "enable" radio button. 8. Go to dial window. 9. Enter "*#7284#" number. 10. Set "UART" radio button to "PDA" value. 11. Go to "Qualcomm USB Settings". 12. Select "RNDIS+DM+MODEM". 13. Go to dial window. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: SCH-I535 Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM54 Mode: Normal Phone model: AAAAANAZ Phone model is not supported Phone connection failed Connecting to phone on COM55 Mode: Emergency ----------------------------------------------------------------------------------- To connect GT-N7000 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "USB" radio button to "PDA" value. 8. Press Home button. 9. Go to dial window. 10. Enter "*#9090#" number. 11. Set "Diag config" to "USB" value. 12. Restart phone. 13. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: GT-I9300 Searching for a phone. Please wait... Phone found. Firmware compiled date: Sat Jun 8 17:24:52 KST 2013 PDA version: I9300XXBMF1 CSC version: I9300XXBMF1 SW version: I535VRUCML1 Phone IMEI: 357070057356695 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM55 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Sat Jun 8 17:24:52 KST 2013 PDA version: I9300XXBMF1 CSC version: I9300XXBMF1 SW version: I535VRUCML1 Phone IMEI: Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Checking Root: Phone is Rooted. Reading security backup, please wait... Write IMEI failed Last edited by Octopus box; 02-13-2015 at 16:45. |
02-13-2015, 16:44 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | As You can see, there modem firmware from I535 in your device, not from I9300: Quote:
02-14-2015, 14:51 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Unfortunately, we have no EFS backup for I535. |
