02-02-2015, 15:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | repair imei G530H [Solved] thanx Last edited by Octopus box; 02-18-2015 at 16:17. |
The Following User Says Thank You to rai14 For This Useful Post: |
02-02-2015, 15:10 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Did You try to use "Search" button? Do the next: 1. Install the latest Software version (Software). 2. Root the phone. 3. Make Wipe Security. 4. Block highlighted pin with a tape. 5. Write IMEI Certificate. Also, look here: http://forum.gsmhosting.com/vbb/f684...100-a-1909650/, http://forum.gsmhosting.com/vbb/f684...55/index2.html, http://forum.gsmhosting.com/vbb/f684...fully-1909286/, http://forum.gsmhosting.com/vbb/f684...i-log-1909429/, http://forum.gsmhosting.com/vbb/f684...-done-1909357/, http://forum.gsmhosting.com/vbb/f684...-done-1909331/. |
The Following 5 Users Say Thank You to Octopus box For This Useful Post: |
02-18-2015, 14:18 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | cant write cert file Welcome to Octoplus/Octopus Box Samsung software version 1.8.4 ----------------------------------------------------------------------------------- To connect SM-G530H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G530H Selected file: C:\Documents and Settings\Ali\My Documents\Downloads \Cert-SM-G530H_00000001585678_0000000000.cert Select Certificate2... Selected file: C:\Documents and Settings\Ali\My Documents\Downloads \Cert-SM-G530H_00000001585678_0000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM3 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-G530H Selected file: C:\Documents and Settings\Ali\My Documents\Downloads \Cert-SM-G530H_00000001585678_0000000000.cert Select Certificate2... Selected file: C:\Documents and Settings\Ali\My Documents\Downloads \Cert-SM-G530H_00000001585678_0000000000.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Found phone on COM3 Phone connected successfully Checking Certificate file... Certificate file successfully checked Writing new phone IMEI... Checking certificate compatibility... Certificate is compatible Writing Certificate... i try to Block highlighted pin with a tape.but still failed |
02-18-2015, 14:54 | #7 (permalink) |
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | in support two file i try with both can u give me another file sir |
The Following User Says Thank You to ali_imran For This Useful Post: |
02-18-2015, 15:10 | #8 (permalink) |
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | problem solve by another tool but i am very sad cant solve by octopus bx but octopus team is really help full thnx again |
The Following 2 Users Say Thank You to ali_imran For This Useful Post: |
