10-26-2013, 19:48 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: R474 5VS
Member: 176999 Status: Offline Thanks Meter: 32 | REPAIR IMEI GT-I8160 problem [Solved] writing sucessfuly use octopus samsung tool but still blank IMEI this log progress : Welcome to Octopus Box Samsung software version 1.9.4 ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM47 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 26 15:57:30 KST 2012 Android version: 2.3.6 (GINGERBREAD) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM47 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Wed Dec 26 15:57:30 KST 2012 Android version: 2.3.6 (GINGERBREAD) Old IMEI: Unknown New IMEI: 351795-05-632639-0 Reading data from phone... Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Writing new IMEI. Please wait... New IMEI successfully written. Please, restart the phone to apply changes thx for respons, regard alfindo Last edited by Octopus box; 01-25-2016 at 10:58. |
The Following User Says Thank You to alfin5557 For This Useful Post: |
10-26-2013, 21:47 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. After which actions phone's IMEI became "blank"? The problem can be with phone's modem. Try to re-flash the phone with different firmwares one by one and look whether phone's IMEI is not "blank". Also please use the latest software version. |
10-26-2013, 22:34 | #3 (permalink) |
Member: 176999 Status: Offline Thanks Meter: 32 | has been tried several times to flash the firmware on the support site IMEI phone is still in a state of blank / NULL, but when repair IMEI samsung octopus success when using the software, is there any other solution to this problem?? I think that a version of the latest software as I use in the repair process this IMEI for the record I am trying to write EFS failed ... EFS read from existing download in this forum |
10-27-2013, 08:40 | #4 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Quote:
10-27-2013, 22:06 | #5 (permalink) |
Member: 176999 Status: Offline Thanks Meter: 32 | I'm try flash use this firmware I8160XXLL2_I8160EVRMA1_EVR_Andoroid_4.1.2.oct from support site, but still IMEI NULL , u have idea for specific firmware ??? thx |
10-28-2013, 08:25 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write different firmwares for GT-I8160/P/L one by one, maybe, this will help to solve the problem. Currently we don't have another solution. |
10-28-2013, 22:53 | #7 (permalink) |
Member: 176999 Status: Offline Thanks Meter: 32 | already in trying to re-flash the firmware using all available on site support even from somewhere else, from the type of firmware GT-I8160/P/L 4.1.2 one by one has been tried yet remain IMEI NULL, if there is a bug in version 1.9.4 software samsung octopus for writing IMEI??? cooperation and its solutions please ... thx |
10-29-2013, 00:24 | #8 (permalink) |
Freak Poster Join Date: May 2011 Location: Turkey
Member: 1568803 Status: Offline Thanks Meter: 10 | No, this is not a bug, I had same problem with my customer's ace 2..You MUST FLASH STOCK COUNTRY Fırmware..Check phone's country then flash it again,it will be ok.. Last edited by Octopus box; 02-22-2014 at 08:36. |
The Following User Says Thank You to ertungan For This Useful Post: |
01-24-2016, 07:28 | #9 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2134278 Status: Offline Thanks Meter: 19 | Welcome to Octoplus/Octopus Box Samsung software version 2.1.7 ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect GT-I8160 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Applications->Development. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Go to dial window. 6. Enter "*#7284#" number. 7. Set "UART" radio button to "Modem" value. 7. Set "USB" radio button to "Modem" value. 8. Restart phone. 9. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8160 Searching for a phone. Please wait... Can't kill external ADB references. Please, close all programs that use ADB server. Phone found. ADB server killed. Firmware compiled date: Mon Feb 10 14:28:02 KST 2014 PDA version: I8160XXNB1 CSC version: I8160OXXNB4 SW version: I8160XXNB1 Phone IMEI: 355686051877873 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Old IMEI: 355686-05-187787-3 New IMEI: 355686-05-187787-3 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Feb 10 14:28:02 KST 2014 PDA version: I8160XXNB1 CSC version: I8160OXXNB4 SW version: I8160XXNB1 Phone IMEI: 355686051877873 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Old IMEI: 355686-05-187787-3 New IMEI: 355686-05-187787-3 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Feb 10 14:28:02 KST 2014 PDA version: I8160XXNB1 CSC version: I8160OXXNB4 SW version: I8160XXNB1 Phone IMEI: 355686051877873 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Old IMEI: 355686-05-187787-3 New IMEI: 355686-05-187787-3 Please, enter the new IMEI ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: GT-I8160 Searching for a phone. Please wait... Phone found. Firmware compiled date: Mon Feb 10 14:28:02 KST 2014 PDA version: I8160XXNB1 CSC version: I8160OXXNB4 SW version: I8160XXNB1 Phone IMEI: 355686051877873 Phone SN: 00000000000 Android version: 4.1.2 (JZO54K) Old IMEI: 355686-05-187787-3 New IMEI: 355686-05-187788-1 Reading data from phone... Cheking Root Phone is Rooted Data read successfully. Please conect phone to BOX via UART cable. Searching for a phone. Please wait... Phone found. Repairing IMEI. Please wait... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu. but imei neel poblam not solb |
