Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 12-22-2013, 18:40   #1 (permalink)
Member: 2089535
Repair imei gt-i9505 [Solved]
Hello everyone I have a box octopus, who changed imei to a gt-i9505 (s4) with firmware 4.3?
Old 12-22-2013, 20:05   #2 (permalink)
Member: 955311
Thanks Meter: 233
I try but it don't work
Old 12-22-2013, 20:30   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 19,841
@ gioele2012
Hello.
At first, please try to connect the device and Read phone's info.
Old 12-22-2013, 22:08   #4 (permalink)
Member: 2089535
prejudice the box recognizes the phone but the operation is not successful change imei
Old 12-23-2013, 07:28   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
Please post here full Software log with all of your actions.
Old 12-25-2013, 09:52   #6 (permalink)
Member: 2089535
ello I'm sorry I find these sh INFORMATION registry
Old 12-25-2013, 10:06   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Sorry, I don't understand, what You mean exactly. Please explain in more details.
Do you still have this GT-I9505 in your hands? Can You repeat the operation once again and post here new Software log?:
Old 12-26-2013, 21:46   #8 (permalink)
Member: 2089535
but this registry software Where am I?
Old 12-26-2013, 21:59   #9 (permalink)
Member: 1146942
Sonork: 100.1587278
All Software logs are saved here: "c:\Program Files\Octoplus\Octoplus_Samsung\LOG\".
Old 12-27-2013, 23:09   #10 (permalink)
Member: 2089535
Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\26-12-2013_21-35-18.log" created (26/12/2013 21:35:21).
INFO : 26/12/2013 21:35:22 > Set up system language English (file: English.ini)
INFO : 26/12/2013 21:35:22 > Welcome to Octoplus/Octopus Box Samsung software version 1.4.3
INFO : 26/12/2013 21:35:22 > -----------------------------------------------------------------------------------
INFO : 26/12/2013 21:35:22 > To connect GT-S7560 phone you have to perform the following steps:
INFO : 26/12/2013 21:35:22 > 1. Disconnect USB cable from phone.
INFO : 26/12/2013 21:35:22 > 2. Go to Menu->Settings->Applications->Development.
INFO : 26/12/2013 21:35:22 > 3. Turn on "USB Debugging" option.
INFO : 26/12/2013 21:35:22 > 4. When message is appear press "Yes".
INFO : 26/12/2013 21:35:22 > 5. Go to dial window.
INFO : 26/12/2013 21:35:22 > 6. Enter "*#9090#" number.
INFO : 26/12/2013 21:35:22 > 7. Set "Diag config" to "USB" value.
INFO : 26/12/2013 21:35:22 > 8. Restart phone.
INFO : 26/12/2013 21:35:22 > 9. Press "Read Info" in software.
INFO : 26/12/2013 21:35:32 > -----------------------------------------------------------------------------------
INFO : 26/12/2013 21:35:32 > To connect GT-I9505 phone you have to perform the following steps:
INFO : 26/12/2013 21:35:32 > 1. Disconnect USB cable from phone.
INFO : 26/12/2013 21:35:32 > 2. Go to Menu->Settings->More->About Device.
INFO : 26/12/2013 21:35:32 > 3.Tap on "Builds numbers" 7 times to enable developer options.
INFO : 26/12/2013 21:35:32 > 4. Go to Menu->Settings->More->Developer options.
INFO : 26/12/2013 21:35:32 > 5. Turn on "USB Debugging" option.
INFO : 26/12/2013 21:35:32 > 6. Go to dial window.
INFO : 26/12/2013 21:35:32 > 7. Enter "*#0808#" number.
INFO : 26/12/2013 21:35:32 > 8. Select "DM+Modem+ADB".
INFO : 26/12/2013 21:35:32 > 9. Close window.
INFO : 26/12/2013 21:35:32 > 10. Go to dial window.
INFO : 26/12/2013 21:35:32 > 11. Enter "*#9090#" number.
INFO : 26/12/2013 21:35:32 > 12. Set "Diag config" to "USB" value.
INFO : 26/12/2013 21:35:32 > 13. Restart phone.
INFO : 26/12/2013 21:35:32 > 14. Press "Read Info" in software.
INFO : 26/12/2013 21:35:35 > -----------------------------------------------------------------------------------
INFO : 26/12/2013 21:35:35 > Platform: Samsung Android
INFO : 26/12/2013 21:35:35 > Selected port: COM1
INFO : 26/12/2013 21:35:35 > Selected model: GT-I9505
INFO : 26/12/2013 21:35:38 > Phone was not found on the selected port!
INFO : 26/12/2013 21:35:38 > Searching for USB diagnostic port...
INFO : 26/12/2013 21:35:38 > Connecting to phone on COM5
INFO : 26/12/2013 21:35:38 > Mode: Normal
INFO : 26/12/2013 21:35:38 > Phone model: GT-I9505
INFO : 26/12/2013 21:35:38 > Firmware compiled date: Nov 01 2013
INFO : 26/12/2013 21:35:38 > Firmware compiled time: 11:00:00
INFO : 26/12/2013 21:35:38 > Firmware released date: Nov 19 2013
INFO : 26/12/2013 21:35:38 > Firmware released time: 18:15:03
INFO : 26/12/2013 21:35:38 > Phone IMEI: 358661-05-554753-0
INFO : 26/12/2013 21:35:38 > SW Version: M9615A-CEFWTAZM-4.0.17125
INFO : 26/12/2013 21:35:58 > -----------------------------------------------------------------------------------
INFO : 26/12/2013 21:35:58 > Platform: Samsung Android
INFO : 26/12/2013 21:35:58 > Selected port: COM5
INFO : 26/12/2013 21:35:58 > Selected model: GT-I9505
INFO : 26/12/2013 21:35:58 > Mode: Normal
INFO : 26/12/2013 21:35:58 > Phone model: GT-I9505
INFO : 26/12/2013 21:35:58 > Firmware compiled date: Nov 01 2013
INFO : 26/12/2013 21:35:58 > Firmware compiled time: 11:00:00
INFO : 26/12/2013 21:35:58 > Firmware released date: Nov 19 2013
INFO : 26/12/2013 21:35:58 > Firmware released time: 18:15:03
INFO : 26/12/2013 21:35:58 > SW Version: M9615A-CEFWTAZM-4.0.17125
INFO : 26/12/2013 21:35:58 > Old IMEI: 358661-05-554753-0
INFO : 26/12/2013 21:35:58 > New IMEI: 358661-05-554754-8
INFO : 26/12/2013 21:35:58 > Repairing NVM for GT-I9505 phone...
INFO : 26/12/2013 21:36:15 > NVM repair completed successfully
ERROR : 26/12/2013 21:36:15 > Write IMEI failed
INFO : 26/12/2013 21:47:59 > -----------------------------------------------------------------------------------
INFO : 26/12/2013 21:47:59 > Platform: Samsung Android
INFO : 26/12/2013 21:47:59 > Selected port: COM5
INFO : 26/12/2013 21:47:59 > Selected model: GT-I9505
INFO : 26/12/2013 21:47:59 > Mode: Normal
INFO : 26/12/2013 21:47:59 > Phone model: GT-I9505
INFO : 26/12/2013 21:47:59 > Firmware compiled date: Nov 01 2013
INFO : 26/12/2013 21:47:59 > Firmware compiled time: 11:00:00
INFO : 26/12/2013 21:47:59 > Firmware released date: Nov 19 2013
INFO : 26/12/2013 21:47:59 > Firmware released time: 18:15:03
INFO : 26/12/2013 21:47:59 > SW Version: M9615A-CEFWTAZM-4.0.17125
INFO : 26/12/2013 21:47:59 > Old IMEI: 358661-05-554753-0
INFO : 26/12/2013 21:47:59 > New IMEI: 359661-05-554754-7
INFO : 26/12/2013 21:47:59 > Repairing NVM for GT-I9505 phone...
INFO : 26/12/2013 21:48:16 > NVM repair completed successfully
ERROR : 26/12/2013 21:48:16 > Write IMEI failed
Old 12-28-2013, 09:09   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
To perform "Repair IMEI" operation, please do the next:
1. Root your phone manually.
2. Make "Repair Security".
3. Connect powered-on phone to PC via Samsung Micro UART cable.
4. Enter correct IMEI.
5. Press "IMEI fix" button in Software.
6. Follow software instructions (prompts).
7. Post here full Software log with all of your actions.
Old 12-28-2013, 15:22   #12 (permalink)
Member: 2089535
the phone with uart cable is not recognized, I'm going crazy please help me thank you very much
Old 12-28-2013, 15:52   #13 (permalink)
Member: 1146942
Sonork: 100.1587278
Some firmwares with Android 4.3 don't let to connect the device. Please try to write new firmware ("I9505XXUEMI8_I9505OXAEMI8_I9505XXUEMI8_OXA"), which we've uploaded into the Support Area, and then perform all the steps 1-7 written above.
Old 12-28-2013, 16:20   #14 (permalink)
Member: 2089535
sorry can not find it give me the link of the page thanks
Old 12-28-2013, 16:27   #15 (permalink)
Member: 1146942
Sonork: 100.1587278
You can find this firmware in the Support Area in folder "Samsung/GT-I9505/" - just press "Go to Support" button at "Support & Options" tab in Software.
Page generated in 0.35327 seconds with 7 queries
