12-16-2014, 16:28 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | Currently no solution. As soon as we will manage to find solution for "Repair IMEI" of GT-S7275R it will be added. |
01-14-2015, 16:05 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,389 | You can write IMEI Certificate, if You has it. IMEI will be changed to the IMEI from the Certificate file. |
01-21-2015, 16:49 | #10 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 441775 Status: Offline Thanks Meter: 22 | the phone by typing * # 9090 # the string "does not go into USB mode. I have the certificate To connect GT-S7275R phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+MODEM+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "DM/DUM over HSIC" value. 13. Restart phone. 14. Press "Read Info" in software. Platform: Samsung Android Selected port: COM3 Selected model: GT-S7275R Reading info, please wait... Please, press "OK" button on the phone to allow USB debugging.. Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: GT-S7275R Firmware compiled date: Wed Dec 4 17:38:48 KST 2013 PDA version: S7275RXXUAML1 CSC version: S7275RTIMAML1 SW version: S7275RXXUAML1 Phone IMEI: 358654053469393 Phone SN: R21DB3N4M7Y Android version: 4.2.2 (JDQ39) Platform: Samsung Android Selected port: COM3 Selected model: GT-S7275R Selected file: C:\Documents and Settings\Cinzia\Desktop\SM-G357M_353283060318578_R28F608RG8E.cert Powered on perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Writing Certificate failed |
