05-26-2015, 11:09 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: ivory coast
Member: 801805 Status: Offline Sonork: 1618365 Thanks Meter: 24 | repair imei S5 G00P wipe security ok but imei B0000000 -------------------------------- INFO : 26/05/2015 11:24:05 > Platform: Samsung Android INFO : 26/05/2015 11:24:05 > Selected port: COM6 INFO : 26/05/2015 11:24:05 > Selected model: SM-G900P INFO : 26/05/2015 11:24:07 > Detected phone model: SM-G900P INFO : 26/05/2015 11:24:07 > Firmware compiled date: Wed Mar 12 13:42:42 KST 2014 INFO : 26/05/2015 11:24:07 > PDA version: G900PVPU1ANCB INFO : 26/05/2015 11:24:08 > CSC version: G900PSPT1ANCB INFO : 26/05/2015 11:24:09 > SW version: G900PVPU1ANCB INFO : 26/05/2015 11:24:10 > Phone IMEI: B0000000 INFO : 26/05/2015 11:24:10 > Phone SN: 00000000000 INFO : 26/05/2015 11:24:10 > Android version: 4.4.2 (KOT49H) INFO : 26/05/2015 11:24:10 > Reading info... INFO : 26/05/2015 11:24:10 > Mode: Normal INFO : 26/05/2015 11:24:10 > Firmware compiled date: Feb 26 2014 INFO : 26/05/2015 11:24:11 > Firmware compiled time: G900P.00 INFO : 26/05/2015 11:24:11 > Firmware released date: Mar 12 2014 INFO : 26/05/2015 11:24:11 > Firmware released time: 13:02:54 INFO : 26/05/2015 11:24:11 > SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 INFO : 26/05/2015 11:24:11 > Checking Root: INFO : 26/05/2015 11:24:11 > Phone is Rooted. INFO : 26/05/2015 11:24:11 > Reading security backup, please wait... INFO : 26/05/2015 11:25:27 > Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-G900P-B0000000-26-05-2015_11-24-11-.asec file INFO : 26/05/2015 11:25:27 > Wiping EFS... INFO : 26/05/2015 11:26:17 > EFS wipe successfully WARN : 26/05/2015 11:26:18 > Phone will restart now. Please don't disconnect cable! INFO : 26/05/2015 11:26:18 > Searching for a phone. Please wait... INFO : 26/05/2015 11:26:48 > Reading info... INFO : 26/05/2015 11:26:48 > Mode: Normal INFO : 26/05/2015 11:26:48 > Firmware compiled date: Feb 26 2014 INFO : 26/05/2015 11:26:48 > Firmware compiled time: G900P.00 INFO : 26/05/2015 11:26:48 > Firmware released date: Mar 12 2014 INFO : 26/05/2015 11:26:48 > Firmware released time: 13:02:54 INFO : 26/05/2015 11:26:48 > SW Version: MPSS.DI.2.0.1.c2.2-00006-M8974AAAAANRZM-1 INFO : 26/05/2015 11:26:48 > Wipe security successfully complete. WARN : 26/05/2015 11:26:48 > Phone will restart now. Please don't disconnect cable! Log file "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG\26-05-2015_11-23-37.log" closed (26/05/2015 |
05-26-2015, 11:15 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try perform "Wipe Security" several times. If problem will remain - make Factory Reset and Wipe Cache partition, then repeat "Wipe Security" operation. Also You can try to Wipe Security/EFS via phone's menu: 1. Write any 4.4.2 firmware (don't root the phone after, this is important!). 2. Type *#9090#. 3. Press at right corner MENU + select "Back". 4. Press at right corner MENU + input Q. 5. Press at right corner MENU + input 0000. Look this video manual: https://www.youtube.com/watch?v=1DtPT2MmNhg. |
05-26-2015, 11:44 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try perform "Wipe Security" several times. If problem will remain - make Factory Reset and Wipe Cache partition, then repeat "Wipe Security" operation several times. Try to re-flash the phone with another firmware and then try to perform "Wipe Security" again. |
05-26-2015, 16:27 | #5 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | Why are you trying to repair the IMEI? The phone cannot be unlocked for US use, and even if it's blacklisted, the blacklist does not apply once you're out of the US. No need to repair. Only unlock |
The Following User Says Thank You to namos23 For This Useful Post: |
05-26-2015, 20:08 | #6 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Guatemala
Member: 2273678 Status: Offline Thanks Meter: 293 | True, it may not be unlocked for domestic use, but the phone may be flashed for it to be used in the US again after the imei repair. Keep in mind that the meid and imei must match for cert to pass. As for the efs, try to wipe efs with a sim card, if that doesn't work take the sim card off and try again until you have /00 imei. |
The Following User Says Thank You to F_X For This Useful Post: |
05-26-2015, 21:18 | #7 (permalink) | |
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
05-26-2015, 23:27 | #8 (permalink) |
Member: 2273678 Status: Offline Thanks Meter: 293 | For Verizon it's true, it's never recommended to wipe the efs just write cert. Since both are cdma based phones, it's a slippery slope to say that sprint can also be served correspondingly as Verizon. thank you for your helpful advise. |
05-27-2015, 13:24 | #9 (permalink) |
Member: 801805 Status: Offline Sonork: 1618365 Thanks Meter: 24 | thanks you for all advise but now i need to repair imei for leaving in normal imei because because imei phone is B0000000 instead back of battery is 99000467330074 there is the probleme when i wipe it success but imei not change |
05-27-2015, 13:33 | #10 (permalink) |
Freak Poster Join Date: Feb 2011 Location: nowhere
Member: 1511582 Status: Offline Thanks Meter: 74 | ok when you reset the efs on the sprint version it don't show 00 imei all the time go head and repair the imei first then write matching meid and check cert after that and see if it pass |
The Following User Says Thank You to mounirson For This Useful Post: |
05-27-2015, 14:02 | #11 (permalink) |
Member: 801805 Status: Offline Sonork: 1618365 Thanks Meter: 24 | i wrote cert file its ok when i check imei its same B0000000 but when i enter in setting-about-status imei is change and correct see the log: INFO : 27/05/2015 14:43:01 > ----------------------------------------------------------------------------------- INFO : 27/05/2015 14:43:01 > Platform: Samsung Android INFO : 27/05/2015 14:43:01 > Selected port: COM6 INFO : 27/05/2015 14:43:01 > Selected model: SM-G900P INFO : 27/05/2015 14:43:35 > Selected file: D:\OCTO\SM-G900F_353110060712411_R58F0SFT2T.cert WARN : 27/05/2015 14:43:37 > Perform the following steps: WARN : 27/05/2015 14:43:37 > 1. Connect phone via UART cable to the Box. WARN : 27/05/2015 14:43:37 > 2. Note: phone screen must be active INFO : 27/05/2015 14:43:37 > Connecting to phone, please wait... INFO : 27/05/2015 14:43:42 > Found phone on COM6 INFO : 27/05/2015 14:43:42 > Phone connected successfully INFO : 27/05/2015 14:43:42 > Checking Certificate file... INFO : 27/05/2015 14:43:42 > Certificate file successfully checked INFO : 27/05/2015 14:43:42 > Writing new phone IMEI... INFO : 27/05/2015 14:43:54 > Checking certificate compatibility... INFO : 27/05/2015 14:43:54 > Certificate is compatible INFO : 27/05/2015 14:43:54 > Writing Certificate... INFO : 27/05/2015 14:44:03 > Certificate has been written successfully INFO : 27/05/2015 14:44:03 > Please, restart the phone to apply changes INFO : 27/05/2015 14:46:46 > -------------------------------------------------------------------- |
05-27-2015, 19:02 | #12 (permalink) | |
Member: 2273678 Status: Offline Thanks Meter: 293 | Quote:
