Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-31-2014, 12:51   #1 (permalink)
Member: 1925902
Sonork: redlabel360
reparar imei n9005 octoplus 1.6.5 !!
hello good day !! friends'm having problems with repair imei samsung n9005! a box full OCTOPLUS success with repairing the appliance !! more to take the test he continues not registered on the network! imei changed and no longer registers on the network! someone help ??
forgiveness by the English ..
Old 08-31-2014, 12:53   #2 (permalink)
Member: 1925902
Sonork: redlabel360
remembering that I am using the most updated program OCTOPLUS !!
Old 08-31-2014, 12:55   #3 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
What is your phone's firmware version exectly? Please post here full Software log with the Repair IMEI operation.
Also, please look here: http://forum.gsmhosting.com/vbb/f684...-imei-1852513/.
Old 08-31-2014, 13:35   #4 (permalink)
Member: 1925902
Sonork: redlabel360
Originally Posted by Octopus box View Post
Hello.
I took a look at the link you posted and my problem is exactly the identical friend !! procedure and done without any error imei and repaired over the network device not registered !! ask if you have possibility to write an older firmware and redo the imei again?
Old 08-31-2014, 13:36   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
No, currently no solution.
Old 08-31-2014, 17:19   #6 (permalink)
Member: 1900730
Thanks Meter: 188
Same wirh NG1 CERT FAIL
*tip , to check if CERT FAIL , press *#0011# and check
Old 09-01-2014, 13:05   #7 (permalink)
Member: 1925902
Sonork: redlabel360
hello friend .. I typed the command and consisted IMEI CERTI: PASS
Old 09-01-2014, 18:55   #8 (permalink)
Member: 1900730
Thanks Meter: 188
before repair IMEI or after?, and what fw
Old 09-11-2014, 21:50   #9 (permalink)
Member: 1925902
Sonork: redlabel360
before doing the repair the unit or after whatever
Old 09-15-2014, 04:50   #10 (permalink)
Member: 1900730
Thanks Meter: 188
U use a service imei? Make repair again and post the log
Page generated in 0.24478 seconds with 8 queries
