08-22-2016, 05:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Sri lanka Age: 43
Member: 454011 Status: Offline Sonork: 1656095 Thanks Meter: 147 | Replies: 0 samsung sm-j510L frp lock reset failed INFO : 8/19/2016 6:15:28 PM > Set up system language English (file: English.ini) INFO : 8/19/2016 6:15:28 PM > Welcome to Octoplus/Octopus Box Samsung software version 2.3.0 INFO : 8/19/2016 6:15:57 PM > ----------------------------------------------------------------------------------- INFO : 8/19/2016 6:15:57 PM > To connect SM-J500F phone you have to perform the following steps: INFO : 8/19/2016 6:15:57 PM > 1. Disconnect USB cable from phone. INFO : 8/19/2016 6:15:57 PM > 2. Go to Menu->Settings->More->About Device. INFO : 8/19/2016 6:15:57 PM > 3.Tap on "Build number" 7 times to enable developer options. INFO : 8/19/2016 6:15:57 PM > 4. Go to Menu->Settings->More->Developer options. INFO : 8/19/2016 6:15:57 PM > 5. Turn on "USB Debugging" option. INFO : 8/19/2016 6:15:57 PM > 6. Go to dial window. INFO : 8/19/2016 6:15:57 PM > 7. Enter "*#0808#" number. INFO : 8/19/2016 6:15:57 PM > 8. Select "DM+Modem+ADB". INFO : 8/19/2016 6:15:57 PM > 9. Press Home button. INFO : 8/19/2016 6:15:57 PM > 10. Press "Read Info" in software. INFO : 8/19/2016 6:16:50 PM > ----------------------------------------------------------------------------------- INFO : 8/19/2016 6:16:51 PM > Platform: Samsung Android INFO : 8/19/2016 6:16:51 PM > Selected port: COM1 INFO : 8/19/2016 6:16:51 PM > Selected model: SM-J500F WARN : 8/19/2016 6:16:51 PM > To put SM-J500F into Download Mode, You have to perform the following steps: WARN : 8/19/2016 6:16:51 PM > 1. Reconnect the battery. WARN : 8/19/2016 6:16:51 PM > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 8/19/2016 6:16:51 PM > 3. When phone turns on, press "Volume+" key. INFO : 8/19/2016 6:16:51 PM > Searching for a phone. Please wait... INFO : 8/19/2016 6:16:51 PM > Phone found. INFO : 8/19/2016 6:16:51 PM > Initializing.. INFO : 8/19/2016 6:16:52 PM > Resetting FRP lock.. SUCC : 8/19/2016 6:16:52 PM > success INFO : 8/19/2016 6:16:52 PM > Resetting EE lock.. SUCC : 8/19/2016 6:16:52 PM > success INFO : 8/19/2016 6:16:52 PM > Resetting Samsung Account lock.. ERROR : 8/19/2016 6:16:52 PM > not supported WARN : 8/19/2016 6:16:52 PM > Reset operation completed! INFO : 8/19/2016 6:16:58 PM > Performed by 2.3.0 software version Log file "C:\Program Files\Octoplus\Octoplus_Samsung\LOG\19-08-2016_18-15-13.log" closed (8/19/2016 6:19:50 PM). j510lklu1apcc_luc1apcc_android_5.1.1 i flash this file but same j510L octopus interface not showing frp reset i select j500f help me any solution i try z3x , chimira tool , miracle box and flash with odin sboot no result |
08-22-2016, 11:24 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Currently Reset Reactivation (Samsung Account) Lock works only for Galaxy S6/S6+. You can try to remove the lock via corresponding service in Octoplus Suite Software. |
