03-18-2016, 04:35 | #1 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | [report] a510f 2016 failed to unlock Quote:
03-18-2016, 05:46 | #5 (permalink) | |
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | Quote:
what is your problem? i know what i did, and i am just reporting on octopus so they can see what is the problem. i am talking to octopus support. even in another box this phone is not unlocked via "recovery mode" and yes i have rooted it properly and i will not share how i root it because that is not the issue. Last edited by Octopus box; 03-18-2016 at 12:09. | |
03-18-2016, 12:16 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Hello. Please upload *.log and *.logx files of performed operations to any file-sharing service and post here download link. *.log and *.logx files can be found in "C:\Program Files (x86)\Octoplus\Octoplus_Samsung\LOG" folder. |
03-29-2016, 23:19 | #7 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Paraguay
Member: 308730 Status: Offline Thanks Meter: 15 | i'm trying to unlock A510F whe i try to flash the a510f_rootedboot.oct always give error. the other method. i cant do file conversion software say "unsuported model". how can i root it??? thanks WARN : 29/03/2016 05:24:57 p.m. > Please put the phone into Download Mode and connect USB cable. WARN : 29/03/2016 05:24:57 p.m. > To put SM-A510F into Download Mode, You have to perform the following steps: WARN : 29/03/2016 05:24:57 p.m. > 1. Reconnect the battery. WARN : 29/03/2016 05:24:57 p.m. > 2. Press and hold "Volume-" + "Home" + "Power ON" keys. WARN : 29/03/2016 05:24:57 p.m. > 3. When phone turns on, press "Volume+" key. INFO : 29/03/2016 05:25:16 p.m. > Found phone on INFO : 29/03/2016 05:25:16 p.m. > Firmware write started. INFO : 29/03/2016 05:25:16 p.m. > Writing BOOT section... ERROR : 29/03/2016 05:26:11 p.m. > Writing Firmware Failed INFO : 29/03/2016 05:26:12 p.m. > Performed by 2.2.2 software version |
03-30-2016, 10:15 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Please install the latest Software version and try to use first root method again. |
03-30-2016, 16:40 | #9 (permalink) | |
Member: 308730 Status: Offline Thanks Meter: 15 | Quote:
Bienvenido en Octoplus/Octopus Box Samsung software versión 2.2.3 Seleccione el archivo de firmware: twrp_3.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.2.3 software version Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing Firmware Failed Performed by 2.2.3 software version No luck again another way to try??? PD: i select pda to convert the .tar file. Last edited by Pilarense; 03-30-2016 at 16:48. | |
03-30-2016, 16:42 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,412 | Most likely these root methods are not compatible with your phone (phone's firmware). Try to use another root solution to root the phone. |
