12-16-2017, 21:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: tunisie
Member: 248024 Status: Offline Thanks Meter: 58 | Reset FRP on Samsung SM-A320F/DS successfully done (Android 7) unlock account google android 7 Welcome to Octoplus Box Samsung software version 2.6.3 ----------------------------------------------------------------------------------- To connect SM-J700H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J700H Reset FRP/ Reactivation lock operation for SM-J700H will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Writing Firmware Failed Operation was failed! Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G925F Reset FRP/ Reactivation lock operation for SM-G925F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Writing firmware Canceled Operation was canceled Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G925F Reset Screen Lock operation for SM-G925F will delete all user data on the phone (contacts, pictures and others)! Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Writing Firmware Failed Reset Screen Lock failed. Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- To connect SM-N930S phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-T715 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-T715 Reset FRP/ Reactivation lock operation for SM-T715 will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-T715 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Writing Firmware Failed Operation was failed! Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J330F Searching for a phone (waiting for ADB device)... Operation was canceled Connecting to server.. Username: Authorization.. Login error: Wrong username! Performed by 2.6.3 Software version. Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- To connect SM-J320AZ phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J200M Reset FRP/ Reactivation lock operation for SM-J200M will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200M into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.3 Software version. unlock account google android 7 Last edited by Octopus box; 12-26-2017 at 06:56. |
The Following 2 Users Say Thank You to gsmalaa For This Useful Post: |
12-25-2017, 18:24 | #2 (permalink) |
Member: 248024 Status: Offline Thanks Meter: 58 | Reset FRP successfully done again (SM-A320F/DS) Welcome to Octoplus Box Samsung software version 2.6.3 Connecting to server.. Username: Authorization.. Login error: Wrong username! Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J200M Reset FRP/ Reactivation lock operation for SM-J200M will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200M into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Please select firmware with PIT Writing Firmware Failed Operation was failed! Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J200M Reset FRP/ Reactivation lock operation for SM-J200M will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200M into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Operation was canceled Performed by 2.6.3 Software version. Connecting to server.. Username: Authorization.. Login error: Wrong username! Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J200F Reset Screen Lock operation for SM-J200F will delete all user data on the phone (contacts, pictures and others)! Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Reset Screen Lock failed. Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J200F Reset FRP/ Reactivation lock operation for SM-J200F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Writing Firmware Failed Operation was failed! Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- To connect SM-G920F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-G925F Reset FRP/ Reactivation lock operation for SM-G925F will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-G925F into Download Mode, You have to perform the following steps: 1. Press and hold "Volume-" + "Home" + "Power ON" keys. 2. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Writing Firmware Failed Operation was failed! Performed by 2.6.3 Software version. ----------------------------------------------------------------------------------- To connect SM-J700H phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM12 Selected model: SM-J700H Reset FRP/ Reactivation lock operation for SM-J700H will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J700H into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.3 Software version. Last edited by Octopus box; 12-26-2017 at 07:00. |
04-01-2018, 16:19 | #3 (permalink) |
Freak Poster Join Date: Jan 2016
Member: 2512807 Status: Offline Sonork: uzbestgsm Thanks Meter: 28 | Reset FRP successfully done again (SM-A320F/DS) Android v7.0 Firmware A320FXXU3BRA1 Welcome to Octoplus Box Samsung software version 2.6.5 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200M Reset FRP/ Reactivation lock operation for SM-J200M will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200M into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. Writing Firmware Failed Operation was failed! Performed by 2.6.5 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J200M Reset FRP/ Reactivation lock operation for SM-J200M will delete all user data on the phone (contacts, pictures and others)! NOTE: You can reset FRP/ Reactivation without losing user data via Factory Reset FRP/ Reactivation service. Connecting to server... Connecting to server...Ok! Checking resource files... Resource files already downloaded. Please put the phone into Download Mode and connect USB cable. To put SM-J200M into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and make "Factory data reset" Performed by 2.6.5 Software version. |
The Following 3 Users Say Thank You to uzbestgsm For This Useful Post: |
