06-18-2018, 10:54
#1 (permalink)
Member: 2155369
Thanks Meter: 706 | Reset FRP Samsung Galaxy J1 Ace Neo SM-J111F With Octopus, Successed Terima kasih Octopus Quote:
MyExceptionEAccessViolationAccess violation at address 0063E493 in
module 'OctoplusSamsung.exe'. Read of address 00000000
TsComboEdit
Welcome to Octoplus Box Samsung software version 2.6.9
To connect SM-J500G phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Press "Read Info" in software.
To connect SM-J111F phone you have to perform the following steps:
Platform: Samsung Android
Selected port: COM1
Selected model: SM-J111F
Operation: Reset FRP - UserData
Reset FRP/ Reactivation lock operation for SM-J111F will delete all user
data on the phone (contacts, pictures and others)!
NOTE: You can reset FRP/ Reactivation without losing user data via
Factory Reset FRP/ Reactivation service.
Connecting to server...
Connecting to server...Ok!
Checking resource files...
Resource files already downloaded.
Please put the phone into Download Mode and connect USB cable.
To put SM-J111F into Download Mode, You have to perform the
following steps:
1. Reconnect the battery.
2. Press and hold "Volume-" + "Home" + "Power ON" keys.
3. When phone turns on, press "Volume+" key.
Waiting for phone...
Firmware write started.
Writing Custom section...
Custom section has been written successfully.
FRP lock is successfully reseted!
Wait 3-4 min then goto "Menu -> Settings -> Backup and reset" and
make "Factory data reset"
Performed by 2.6.9 Software version.
