12-10-2017, 08:55 | #1 (permalink) |
Insane Poster Join Date: Apr 2015 Location: iran Age: 42
Member: 2385552 Status: Offline Thanks Meter: 15 | Reset FRP SM-J710F successfully done whit Octoplus Samsug ----------------------------------------------------------------------------------- To connect SM-J700F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..unsuccessful Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Operation was canceled Performed by 2.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 2.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Searching for a phone. Please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Operation was failed! Performed by 2.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Operation was canceled Performed by 2.6.1 Software version. Selected firmware file: combination_a710f_a710fxxu1apg2_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Selected file is declared for SM-A710F model! File has been created for a different phone model. Performed by 2.6.1 Software version. Selected firmware file: combination_a710f_a710fxxu1aol6_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Selected file is declared for SM-A710F model! File has been created for a different phone model. Performed by 2.6.1 Software version. Selected firmware file: combination_a710f_a710fxxu1apg2_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Selected file is declared for SM-A710F model! File has been created for a different phone model. Performed by 2.6.1 Software version. Selected AP file: D:\1file flash\samsung\J\J710\J710F\Android 6.0.1 \parsi\J710FXXU1API4_J710FOJV1API1_THR\J710FXXU1AP I4 _J710FOJV1API1_J710FXXU1APH4_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-J710F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Advanced mode! Firmware write started. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing CM section... CM section has been written successfully. Writing Firmware Failed Performed by 2.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Operation was canceled Performed by 2.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Searching for a phone (waiting for ADB device)... Operation was canceled Performed by 2.6.1 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-J710F Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM6 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 2.6.1 Software version. Last edited by Octopus box; 12-10-2017 at 12:33. |
The Following User Says Thank You to siavash.radan For This Useful Post: |
12-16-2017, 12:39 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: Shaker-Telecom BaNgLaDeSh
Member: 1296389 Status: Offline Sonork: 100.1618052 Thanks Meter: 268 | Welcome to Octoplus Box Samsung software version 2.6.2 ----------------------------------------------------------------------------------- To connect SM-G925F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- To connect SM-J710F phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM29 Selected model: SM-J710F Searching for UART interface.. COM29 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation...OK Searching for UART interface.. COM29 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/4 attempt)..success FRP / Reactivation lock is successfully reseted! Performed by 2.6.2 Software version. |
The Following User Says Thank You to saker2050 For This Useful Post: |
