07-19-2014, 09:58 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Honolulu Hawaii
Member: 2091124 Status: Offline Thanks Meter: 15 | S4 Active SGH-I537 IMEI Failed Write NVM Failed [Solved] I have a properly connected S4 active direct unlock failed after reboot it gave me a 0049 IMEI and it will not restore the NVM backup or rewrite a new IMEI. Phone is rooted and I have cleared logs and old backups and it still will not rewrite it. Phone is on 4.4.2 Last edited by Octopus box; 07-20-2014 at 09:34. |
07-19-2014, 10:51 | #2 (permalink) | |
Member: 2091124 Status: Offline Thanks Meter: 15 | Quote:
Welcome to Octoplus/Octopus Box Samsung software version 1.6.2 ----------------------------------------------------------------------------------- To connect SGH-I537 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17138 ----------------------------------------------------------------------------------- To connect SM-N900T phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SM-N900A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- To connect SGH-I537 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17138 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 SW version: M9615A-CEFWTAZM-4.0.17138 Old IMEI: 004400-15-202000-0 New IMEI: 357507-05-008552-4 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SGH-I537-004400152020000-18-07-2014_23-28- 23-.nvm file Firmware compiled date: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 SW version: I537UCUCNE3 Phone IMEI: Unknown Phone SN: R31D818HR2T Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-I537-18-07-2014_23-31-08-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 SW version: M9615A-CEFWTAZM-4.0.17138 Found phone on COM78 Repairing NVM for SGH-I537 phone... Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17138 Creating NVM backup Reading NVM done! Repairing NVM for SGH-I537 phone... NVM repair completed successfully To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 Incorrect IMEI SW version: M9615A-CEFWTAZM-4.0.17138 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 SW version: M9615A-CEFWTAZM-4.0.17138 Old IMEI: 004400-15-202000-0 New IMEI: 357507-05-008552-4 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SGH-I537-004400152020000-18-07-2014_23-36- 10-.nvm file Proper android device not found. Make shure that "USB debug" option on the device is turned on. Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 SW version: M9615A-CEFWTAZM-4.0.17138 Old IMEI: 004400-15-202000-0 New IMEI: 357507-05-008552-4 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SGH-I537-004400152020000-18-07-2014_23-39- 20-.nvm file Firmware compiled date: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 SW version: I537UCUCNE3 Phone IMEI: Unknown Phone SN: R31D818HR2T Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-I537-18-07-2014_23-41-42-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 SW version: M9615A-CEFWTAZM-4.0.17138 Found phone on COM78 Repairing NVM for SGH-I537 phone... Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM78 Selected model: SGH-I537 Mode: Normal Phone model: SGH-I537 Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 SW version: M9615A-CEFWTAZM-4.0.17138 Old IMEI: 004400-15-202000-0 New IMEI: 357507-05-008552-4 Creating NVM backup Reading NVM done! Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\NVM-SGH-I537-004400152020000-18-07-2014_23-43- 00-.nvm file Firmware compiled date: Fri May 16 14:53:09 KST 2014 PDA version: I537UCUCNE3 CSC version: I537ATTCNE3 SW version: I537UCUCNE3 Phone IMEI: Unknown Phone SN: R31D818HR2T Android version: 4.4.2 (KOT49H) Cheking Root Phone is Rooted Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-SGH-I537-18-07-2014_23-45-11-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Jan 28 2014 Firmware compiled time: 02:00:00 Firmware released date: May 16 2014 Firmware released time: 15:36:39 SW version: M9615A-CEFWTAZM-4.0.17138 Found phone on COM78 Repairing NVM for SGH-I537 phone... Write IMEI failed | |
07-19-2014, 18:33 | #4 (permalink) |
Member: 2091124 Status: Offline Thanks Meter: 15 | There is no Odin firmware for NE3 at the moment I checked everywhere XDA, Sammobile the only thing that exists is an OTA. I Did do a hard reset and I am still getting the exact same errors |
