04-20-2016, 16:38 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | S4 M919 Bricked, wont flash, help If I power on phone normally, appears a screen that says: "Device Memory Damaged The data partition has been corrupted. you need to reset your device to factory defaults. this will erase all your date." when I enter into download mode, appears: ODIN MODE PRODUCT NAME: SGH-M919 CURRENT BINARY: Samsung Official SYSTEM STATUS: Official KNOX Kernel Lock: 0x0 KNOX WARRANTY VOID: 0x0 CSB-CONFIG-LSB: 0x30 WRITE PROTECTION: Enable eMMC BURST MODE: enabled I tried flash 4 files lower ship and failed I tried flash with pit file and failed too |
04-20-2016, 16:56 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to make Factory Reset and Wipe cache partition from Recovery Mode, then try to write "M919UVUFOH3_M919TMBFOH3_TMB_Android_4.4.4" firmware from the Support Area. Post here result and full Software log of "Write Firmware" operation. |
04-21-2016, 17:09 | #3 (permalink) |
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | if i try to flash with octopus with file you todl me, stuck: Selected firmware file: M919UVUFOH3_M919TMBFOH3_TMB_Android_4.4.4.oct Please put the phone into Download Mode and connect USB cable. To put SGH-M919 into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing ABOOT section... ABOOT section has been written successfully. Writing SBL1 section... SBL1 section has been written successfully. Writing SBL2 section... SBL2 section has been written successfully. Writing SBL3 section... SBL3 section has been written successfully. Writing RPM section... RPM section has been written successfully. Writing TZ section... TZ section has been written successfully. Writing BOOT section... BOOT section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing MDM section... MDM section has been written successfully. Writing APNHLOS section... APNHLOS section has been written successfully. Firmware writing successfully completed. Performed by 2.2.4 software version ODIN MODE PRODUCT NAME: SGH-M919 CURRENT BINARY: Samsung Official SYSTEM STATUS: Official KNOX Kernel Lock: 0x0 KNOX WARRANTY VOID: 0x0 CSB-CONFIG-LSB: 0x30 WRITE PROTECTION: Enable eMMC BURST MODE: enabled START [224,1440] ODIN: flash write failure and here you can check, whats appear in recovery mode when i try to do a factory reset or wipe cache: video |
04-21-2016, 17:47 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Unfortunately video link is not valid. Please explain in what state is phone exactly after writing of a firmware and what errors appear in Recovery Mode. |
04-21-2016, 18:00 | #5 (permalink) | |
Member: 1239608 Status: Offline Sonork: dombronx Thanks Meter: 53 | Quote:
https://www.youtube.com/watch?v=S_798KcxImk | |
04-21-2016, 18:14 | #7 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | bro u need to disable ''write protection'' then retry flash...good luck Last edited by Octopus box; 04-21-2016 at 18:58. |
The Following User Says Thank You to bigjef1 For This Useful Post: |
