03-27-2015, 18:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 238466 Status: Offline Thanks Meter: 18 | s4 network problem [Solved] Last edited by Octopus box; 03-30-2015 at 11:48. |
03-27-2015, 19:35 | #4 (permalink) |
Member: 238466 Status: Offline Thanks Meter: 18 | Welcome to Octoplus/Octopus Box Samsung software version 1.8.9 ----------------------------------------------------------------------------------- To connect GT-I9505 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Go to dial window. 11. Enter "*#9090#" number. 12. Set "Diag config" to "USB" value. 13. Restart phone. 14. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM77 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 Phone IMEI: 356xxx-xx-671xxx-x SW version: M9615A-CEFWTAZM-4.0.17062 ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM77 Selected model: GT-I9505 Mode: Normal Phone model: GT-I9505 Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Old IMEI: 356845-05-671216-7 New IMEI: 352168-06-251905-2 Creating NVM backup Reading NVM done! Firmware compiled date: Thu Feb 13 20:47:45 KST 2014 PDA version: I9505XXUFNB8 CSC version: I9505ITVFNB2 SW version: I9505XXUAMDC Phone IMEI: 356xxx056712xxx Phone SN: RF1D71CEQGZ Android version: 4.4.2 (KOT49H) Cheking Root Reading security backup, please wait... Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9505-356845056712167-27-03-2015_19-28- 03-.asec file Erasing old IMEI. It can take some time. Please wait... Phone will restart now. Please don't disconnect cable! Firmware compiled date: Mar 28 2013 Firmware compiled time: 09:00:00 Firmware released date: Apr 12 2013 Firmware released time: 00:04:45 SW version: M9615A-CEFWTAZM-4.0.17062 Found phone on COM77 Repairing NVM for GT-I9505 phone... IMEI successfully repaired. To finish the operation, please restart the phone via phone's menu (don't disconnect the battery!) |
03-27-2015, 19:45 | #5 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Check whether IMEI Certi passed in *#0011#. If it passed - write QCN from the Support Area and reflash the phone with any 4.4.2 firmware. |
03-27-2015, 21:02 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to write "I9505XXUFNA1-MODEM.oct" modem (available in Support Area), then insert SIM card, wait 5-7 minutes and try to find and select network manually. |
03-28-2015, 10:27 | #10 (permalink) |
Freak Poster Join Date: Sep 2013 Location: PaKiStAn & KSA
Member: 2023768 Status: Offline Sonork: 100.1661054 Thanks Meter: 76 | i think your set was unlocked by certificate so you change imei therefore this problem came reflash .4.4.2 and write certi again |
03-28-2015, 12:14 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Try to do the next: 1. Root the phone. 2. Write the special firmware "GT-i9505_for_Unlock_and_IMEI_repair". 3. Re-boot the phone and make "Repair IMEI" again. 4. Write QCNs from the Support Area. 5. Insert SIM card, wait 5-7 minutes and try to find and select network manually. |
03-30-2015, 11:38 | #13 (permalink) | |
Member: 238466 Status: Offline Thanks Meter: 18 | Quote:
thanks for support | |
